definition controls problem in windows
dodogo
Post by dodogo »
Hi men.
I have still same problem. After definition window and show it, I try manipulate with control (grid, label..) Look picture from example.
I use HMG311 and minigui extended (2.1.9) with same results. "Control: xxx Of Winxxx Not defined. Program terminated,
Can You help me?
THX Dodogo
dodogo
Re: definition controls problem in windows
Post by dodogo »
sorry wrong extension in picture file..
dodogo wrote: sorry wrong extension in picture file..
you better post an example?
or just use GetProperty( Window, Control , value )
Ej :
 SendEmail.Text_1.Value := GetProperty( 'Incomming' , 'cUser' , 'value' )
dodogo wrote:Hi men.
Hi
Your problem might be this :
HMG Doc wrote: DECLARE WINDOW <WindowName>
A window must be declared using this command, if you need to refer to it prior
its definition in code, or when you refer to it in a different .prg file from
the one it was defined using semi-oop syntax.
Viva HMG :D
dodogo
Post by dodogo »
Hi.
Here is same example.
#include "minigui.ch"
    nWidth  := GetDesktopWidth() * 0.4
    nHeight := GetDesktopHeight() * 0.4
    WinMain(nWidth,nHeight)
Function WinMain(nWidth,nHeight)
       DEFINE WINDOW winMain ;
              WIDTH nWidth ;
              HEIGHT nHeight ;
              TITLE 'PackFlowEE ' ;
              MAIN;
              MDI;
              FONT 'System' SIZE 12
              DEFINE MAIN MENU
                     POPUP 'File'
                            ITEM 'Open'         ACTION WinStockFlow2()
                            ITEM 'Exit'         ACTION winMain.Release
                     END POPUP
              END MENU
       CENTER WINDOW winMain
       ACTIVATE WINDOW winMain
RETURN  Nil
FUNCTION WinStockFlow2()
	define window WinStockFlow at 0,0 width 200 height 200 title 'WinStockFlow'	MDICHILD ;
			font 'ms sans serif' size 8 ;
            DEFINE LABEL lblTest
                ROW    40
                COL    50
                WIDTH  120
                HEIGHT 20
                VALUE "Test:"
                FONTNAME "Arial"
                FONTSIZE 10
                FONTBOLD .T.
            END LABEL
        DEFINE BUTTON btnTest
            ROW    60
            COL    50
            WIDTH  100
            HEIGHT 28
            ACTION test()
            CAPTION "Test"
            FONTNAME "Arial"
            FONTSIZE 10
            FLAT .F.
            TABSTOP .T.
            VISIBLE .T.
        END BUTTON
	end window
*	WinStockFlow.center
*	activate window WinStockFlow
return Nil
function test()
    msgstop(WinStockFlow.lblTest.value)
return Nil
Hi dodogo
dodogo wrote:Here is same example.
Here fixed (and working) version of your program.
Problem points commented by "//" and test statements de-commented.
              WIDTH nWidth ;
              HEIGHT nHeight ;
              MAIN; //           MDI;
              DEFINE MAIN MENU
                     POPUP 'File'
                     END POPUP
              END MENU
RETURN  Nil
   define window WinStockFlow at 0,0 width 200 height 200 title 'WinStockFlow' ; //   MDICHILD ;
         font 'ms sans serif' size 8 // ;
                ROW    40
                COL    50
                WIDTH  120
                HEIGHT 20
                VALUE "Test:"
                FONTNAME "Arial"
                FONTSIZE 10
                FONTBOLD .T.
            END LABEL
            ROW    60
            COL    50
            WIDTH  100
            HEIGHT 28
            ACTION test()
            CAPTION "Test"
            FONTNAME "Arial"
            FONTSIZE 10
            FLAT .F.
            TABSTOP .T.
            VISIBLE .T.
        END BUTTON
   end window
   WinStockFlow.center
return Nil
function test()
return Nil
PS : HMG official doesn't support MDI windows .
dodogo
Post by dodogo »
but extended edition have MDI...
dodogo wrote:but extended edition have MDI...
You may find the reality on MDI here
By the way, your problem was not related to MDI ;)
PeteWG
Post by PeteWG »
Yes it's true.
The problem is that MDI support is not very good documented.
Now regarding your problem,
function test()
return Nil
try to use MsgStop( WinStockFlow_1.lblTest.value )
In other words, the '_DefineChildMDIWindow' creation routine adds "by design" an "_n" at the end of the name of child window, where "n" is an ascending integer which increments each time a child window is defined. Actually it corresponds to ActiveMDIChildIndex.
Keep this in mind when you utilize MDI's.
But, as already pointed out, MDI usage is tricky and not suggested. If you can, avoid it!
(BTW, since you're using minigui extended you might get better replies if you post you questions also in MiniGUI extended forum )
Pete
