hmg application in service mode, possible?
leslie_m
Post by leslie_m »
Hello Experts!
I was here a long time ago, welcome to everyone!
I wrote one client - server application, used a "Hmgtalk" sample.
I want to use the "Talkserver.exe" on Windows server 2003 SBS, in service mode.
Because in normal mode it's closed after the user logged off.
How can I compile my HMG project to service application?
I tried instsrv.exe from the "windows resource kit". It's working fine on Windows XP, but doesn't put my apps to service mode in win2003 server.
What's wrong in this procedure?
Any idea?
Thanks for help...
Leslie
jayadevu
Re: hmg application in service mode, possible?
Post by jayadevu »
May be the following link is of some help to you:
http://blog.super-networking.net/2008/0 ... rver-2003/
Hope that helps,
Warm regards,
Jayadev
leslie_m
Post by leslie_m »
Hallo Jayadev!
Thank you for your reply,
I have this description, I tried it already. The HMG program is started as service, but it is closed, when I logged out from the server console. Unfortunately only on Win server. Under windows XP is working fine, in service mode.
I want to know, how can I make direct service mode compiled file in HMG, if it's possible.
I do not find any info about it...
Leslie
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Post by karweru »
Hi Leslie,
Did you ever get a solution to this? If so, kindly share.
Gilbert.
Kind regards,
Gilbert.
leslie_m
Post by leslie_m »
Hi Karweru!
Unfortunately I did not find any good solution for this problem yet.
If I get it, I will share it.
Leslie
karweru
Post by karweru »
I found this https://github.com/vszakats/harbour-cor ... winsvc.prg by Victor. I havbent tried but will and report back
Gilbert
Kind regards,
Gilbert.
leslie_m
Post by leslie_m »
Wow,
Looks like it's a solution...
If you can try it, pls. share the result.
Thx
Leslie
karweru
Post by karweru »
Hi Leslie,
I finally got it going. Please have a look at the code attched. I've tested on Windows 7 professional. The actual functionality is based on code by Viktor (quoted above).
I still got some problems though. I cant start/Stop the server from my code. Also, while I can start the server from windows administrative tools window, I cant stop it. Maybe someone in this forum might point us to the right direction?.
hbNetIO_server.rar
(1.3 KiB) Downloaded 254 times
Kind regards,
Gilbert.
Hola a todos:
ya tengo la version modificada del ejemplo TalkServer con API REST, despues publico el codigo
Captura de pantalla 2026-08-19 184116.png (64.75 KiB) Viewed 169 times
Captura de pantalla 2026-08-19 183627.png (12.36 KiB) Viewed 169 times
Captura de pantalla 2026-08-19 183728.png (88.03 KiB) Viewed 169 times
Hola a todos, estoy casi terminando el nuevo TalkServer y Talkclient.
todavia tengo un error ya fue solucionado pero fue introducido de nuevo :roll:
Captura de pantalla 2026-08-20 183132.png (73.05 KiB) Viewed 139 times
Captura de pantalla 2026-08-20 183720.png (28.67 KiB) Viewed 139 times
