Dynamic Actions problem
giuper63
DBs Used: DBF, mysql, sqlite, PostgresSQL
Post by giuper63 »
Hi to all,
I have a problem using dynamic actions.
I hope someone can help me to solve the problem.
I usually create dynamic programs where the components are stored in arrays.
Here is an example:
FUNCTION Main()
	DEFINE WINDOW Win1 ;
		WIDTH 400 ;
		HEIGHT 300 ;
		TITLE 'Test Dynamic Actions from Array' ;
		MAIN
		DEFINE MAIN MENU
			POPUP "Test"
				MENUITEM "Test Dynamic Actions" ACTION TestButtons(7)
			END POPUP
		END MENU
		DEFINE BUTTON TEST
			ROW		10
			COL		10
			WIDTH		200
			CAPTION		'Click Me!'
			ACTION		TestButtons(5)
		END BUTTON
	Center Window Win1
	Activate Window Win1
Procedure TestButtons(nNum)
Local nMax:=20
Private nN, aTest:={}
For nN:=1 to nNum
	AAdd(aTest,{'Msg'+AllTrim(Str(nN)),'MsgBox("'+AllTrim(Str(nN))+'")'})
Next
DEFINE WINDOW HDWin ;
	WIDTH 200 ;
	HEIGHT 0 ;
	TITLE 'Test!' ;
	MODAL
	For nN:=1 to Len(aTest)-1
		nMax:=24*(nN-1)
		DEFINE BUTTON &("B"+AllTrim(Str(nN)))
			ROW 10+nMax
			COL 10
			WIDTH HDWin.WIDTH-20
			Height 22
			CAPTION aTest[nN,1]
//			ACTION &("aTest[nN,2]")                   // <<<<<<<<<<<< With this the procedure return nN variable error
//			ACTION &("aTest["+AllTrim(Str(nN))+",2]") // <<<<<<<<<<< With this the procedure do nothing!
//			ACTION aTest[nN,2]                        // <<<<<<<<<<< With this the procedure do nothing!
//			ACTION MsgBox(aTest[nN,2])                // <<<<<<<<<<< With this the procedure always return Len(aTest)+1!!!
			ACTION MsgBox(Str(nN))                    // <<<<<<<<<<< With this the procedure always return Len(aTest)+1!!!
		END BUTTON
	Next
	HDWin.Height:=nMax+40+GetTitleHeight()+GetBorderHeight()
CENTER WINDOW HDWin
ACTIVATE WINDOW HDWin
The procedures in the aTest array could change depending on parameters passed to the procedure.
The caption is taked correctly from the array, the action not!
I would like that pressing the Msg1 button the message would be "1" and not Len(aTest)+1.
I have tried using "&(aTest[nN,2])", which should solve the action at creation time of the component, but I notice that it solve the action at action time, when the variable is Len(aTest)+1.
Some solution?
Giuseppe
Italian developer
Re: Dynamic Actions problem
Hi Giuseppe
giuper63 wrote:...Some solution?...
I hope this will give you an idea :idea:
   For nN := 1 to Len( aTest )-1
      nMax:=24 * ( nN-1 )
         ACTION Test_2( this.name )         // new line
      END BUTTON
   Next
PROCEDURE Test_2( cBtnNam )             // New procedure
  LOCAL nBtnNo := VAL( SUBS( cBtnNam, 2 ) )
  MsgBox(  LTRIM( STR( nBtnNo  ) ) )
you should modify a little your function:
	nMax:=24*(nN-1)
	cAction := "MsgBox(str(" + Str(nN) + "))"
		ROW 10+nMax
		COL 10
		Height 22
		CAPTION aTest[nN,1]
		Action &cAction // <<<<<<<<<<< With this the procedure always return Len(aTest)+1!!!
	END BUTTON
Next
Regards, Marek
giuper63
Post by giuper63 »
Thanks esgici,
you give me the right idea!
This is the final code:
Request PlayAsterisk, Playexclamation, PlayBeep, PlayOK, PlayHand
FUNCTION Main()
Local nN, aTest1:={}, aTest2:={}
// Define an array for button creation
For nN:=1 to 5
	AAdd(aTest1,{'One'+AllTrim(Str(nN)),'{|| MsgBox("First : '+AllTrim(Str(nN))+'")}'})
Next
// Define a second array with different text and actions
AAdd(aTest2,{'First','{|| MsgBox("No sound!")}'}) // Only 1 procedure
AAdd(aTest2,{'Second','{|| PlayBeep(), MsgOkCancel("Simple beep")}'}) // 2 procedures!
AAdd(aTest2,{'Third','{|| PlayAsterisk(), MsgBox("Asterisk")}'})
AAdd(aTest2,{'..and..','{|| PlayExclamation(), MsgBox("Wow")}'})
AAdd(aTest2,{'..so..','{|| PlayOk(), MsgStop("OK?")}'})
AAdd(aTest2,{'..ON..','{|| PlayHand(), MsgYesNo("Hand")}'})
		WIDTH 400 ;
		HEIGHT 300 ;
		MAIN
		DEFINE MAIN MENU
			POPUP "Test"
				MENUITEM "Test Dynamic Actions" ACTION TestButtons(aTest1)
			END POPUP
		END MENU
		DEFINE BUTTON TEST
			ROW		10
			COL		10
			WIDTH		200
			CAPTION		'Click Me!'
			ACTION		TestButtons(aTest2)
		END BUTTON
	Center Window Win1
Procedure TestButtons(aTest)
Local nMax:=20, nN
	WIDTH 200 ;
	HEIGHT 0 ;
	TITLE 'Test!' ;
	MODAL
		nMax:=24*(nN-1)
			ROW 10+nMax
			COL 10
			Height 22
			CAPTION aTest[nN,1]
			ACTION Test_2(aTest) // <<< Pass the array to the second function
		END BUTTON
	Next
CENTER WINDOW HDWin
PROCEDURE Test_2(aTest)  // Execution Procedure
Local nEle:=Val(Subst(this.name,2))  // Retrive the element number
If nEle>0
	Eval(&(aTest[nEle,2]))  // Evaluate the code
Endif
Many, many, many thanks for the answer!
Also thanks to mol, but I was searching for a solution where I pass an array to a function (TestButtons).
This function can be called from different procedures with different arrays and different actions.
As you can see I declare 2 arrays in the first part of the program, so I can call the function with different arrays.
Now It's easy to add a button with linked procedure to the list. Just add an element to the array!
And It's easy to create a list of buttons in every part of the program.
Best regards
Giuseppe
Italian developer
Hi Giuseppe
I'm glad by your happiness :)
and good implementation, thanks to sharing :)
By the way, I have a few more suggestions :
- eliminating "request" for internal HMG functions,
- reducing '&' (macro evaluation) usages
I hope you will like :
* Request PlayAsterisk, Playexclamation, PlayBeep, PlayOK, PlayHand
FUNCTION Main()
For nN := 1 to 5
   AAdd( aTest1,{ 'One' + AllTrim( Str( nN ) ),;
                  { | nNo | MsgBox( "First : " + AllTrim( Str( nNo )) ) } } )
Next
AAdd( aTest2, {'First',   {|| MsgBox("No sound!")}}) // Only 1 procedure
AAdd( aTest2, {'Second',  {|| PlayBeep(), MsgOkCancel("Simple beep")}}) // 2 procedures!
AAdd( aTest2, {'Third',   {|| PlayAsterisk(), MsgBox("Asterisk")}})
AAdd( aTest2, {'..and..', {|| PlayExclamation(), MsgBox("Wow")}})
AAdd( aTest2, {'..so..',  {|| PlayOk(), MsgStop("OK?")}})
AAdd( aTest2, {'..ON..',  {|| PlayHand(), MsgYesNo("Hand")}})
      WIDTH 400 ;
      HEIGHT 300 ;
      MAIN
      DEFINE MAIN MENU
         POPUP "Test"
         END POPUP
      END MENU
      DEFINE BUTTON TEST
         ROW      10
         COL      10
         WIDTH      200
         CAPTION      'Click Me!'
      END BUTTON
   Center Window Win1
Local nMax:=20, nN
   WIDTH 200 ;
   HEIGHT 0 ;
   TITLE 'Test!' ;
   MODAL
      nMax:=24*(nN-1)
         ROW 10+nMax
         COL 10
         Height 22
         CAPTION aTest[nN,1]
      END BUTTON
   Next
CENTER WINDOW HDWin
Local nEle := Val(Subst(this.name,2))  // Retrive the element number
If nEle > 0
   Eval( aTest[ nEle, 2 ], nEle )  // Evaluate the code
Endif
I prefer using a function, which I can call ActionCenter, with one parameter pointing another function to call, eg:
function ActionCenter
  param xWhatToDo
  local xRetValue := .f.
  do case
  case xWhatToDo == 1
    MsgBox("Action no 1 - return an array")
    xRetValue := {1,2,3}
  case xWhatToDo == 2
    MsgBox("Action no 2")
  case xWhatToDo == 3
    MsgBox("Action no 3")
  case xWhatToDo == 4
    MsgBox("Action no 4")
  endcase
return xRetValue
IMO this code is easier to debug
Marek
