UNICODE Strings Functions
- srvet_claudio
Hi All.
Researching in the source files of Harbour I found strings functions that work with UNICODE/ANSI and only ANSI.
This list may be incomplete.
Claudio Soto.
Functions that support UNICODE and ANSI strings
* harbour/src/rtl/chruni.c
/* Unicode(character) and Binary(byte) string functions: */
HB_UCHAR( <nCode> ) -> <cText> // return string with U+nCode character in HVM CP encoding
HB_BCHAR( <nCode> ) -> <cText> // return 1 byte string with <nCode> value
HB_UCODE( <cText> ) -> <nCode> // return unicode value of 1-st character (not byte) in given string
HB_BCODE( <cText> ) -> <nCode> // return value of 1-st byte in given string
HB_ULEN( <cText> ) -> <nChars> // return string length in characters
HB_BLEN( <cText> ) -> <nBytes> // return string length in bytes
HB_UPEEK( <cText>, <n> ) -> <nCode> // return unicode value of <n>-th character in given string
HB_BPEEK( <cText>, <n> ) -> <nCode> // return value of <n>-th byte in given string
HB_UPOKE( [@]<cText>, <n>, <nVal> ) -> <cText> // change <n>-th character in given string to unicode <nVal> one and return modified text
HB_BPOKE( [@]<cText>, <n>, <nVal> ) -> <cText> // change <n>-th byte in given string to <nVal> and return modified text
HB_USUBSTR( <cString>, <nStart>, <nCount> ) -> <cSubstring>
HB_BSUBSTR( <cString>, <nStart>, <nCount> ) -> <cSubstring>
HB_ULEFT( <cString>, <nCount> ) -> <cSubstring>
HB_BLEFT( <cString>, <nCount> ) -> <cSubstring>
HB_URIGHT( <cString>, <nCount> ) -> <cSubstring>
HB_BRIGHT( <cString>, <nCount> ) -> <cSubstring>
HB_UAT( <cSubString>, <cString>, [<nFrom>], [<nTo>] ) -> <nAt>
HB_BAT( <cSubString>, <cString>, [<nFrom>], [<nTo>] ) -> <nAt>
* harbour/src/rtl/hbtoken.c
HB_TOKENCOUNT()
HB_TOKENGET()
HB_TOKENPTR() /* like HB_TOKENGET() but returns next token starting from passed position (0 based) inside string, f.e.: HB_TOKENPTR( cString, @nTokPos, Chr( 9 ) ) -> cToken */
HB_ATOKENS()
* harbour/src/rtl/memofile.c
MEMOREAD()
MEMOWRIT()
HB_MEMOREAD() // not limited to 64 KB as MEMOREAD()
HB_MEMOWRIT() // not limited to 64 KB as MEMOWRIT()
* harbour/src/rtl/mlcfunc.c
/* warning <nLineLength> is in bytes, <nLineLength> must be greater than the number of bytes of the longest line of text in UTF-8 */
MEMOLINE( <cString>, [ <nLineLength>=79 ], [ <nLineNumber>=1 ], [ <nTabSize>=4 ], [ <lWrap>=.T. ], [ <cEOL>|<acEOLs> ] ) -> <cLine>
MLCOUNT ( <cString>, [ <nLineLength>=79 ], [ <nTabSize>=4 ], [ <lWrap>=.T. ], [ <cEOL>|<acEOLs> ] ) -> <nLines>
MLPOS ( <cString>, [ <nLineLength>=79 ], [ <nLineNumber>=1 ], [ <nTabSize>=4 ], [ <lWrap>=.T. ], [ <cEOL>|<acEOLs> ] ) -> <nLinePos>
MLCTOPOS() // not support UTF-8
MPOSTOLC() // not support UTF-8
* harbour/src/rtl/mtran.c
MEMOTRAN()
* harbour/src/rtl/replic.c
REPLICATE() /* returns n copies of given string */
* harbour/src/rtl/strc.c
HB_STRDECODESCAPE ( <cEscSeqStr> ) -> <cStr> /* decode string with \ escape sequences */
HB_STRCDECODE ( <cStr> [, @<lCont> ] ) -> <cResult> | NIL /* decode string using C compiler rules */
/* If second parameter <lCont> is passed by reference then it allows to decode multiline strings.
In such case <lCont> is set to .T. if string ends with unclosed "" quoting.
Function returns decoded string or NIL on syntax error. */
* harbour/src/rtl/strmatch.c
HB_WILDMATCH (cPattern, cValue [, lExact] ) /* compares two strings */
/* Compares cValue with cPattern.
cPattern * may contain wildcard characters (?*)
When lExact is TRUE then it will check if whole cValue is covered by cPattern
else it will check if cPattern is a prefix of cValue */
HB_WILDMATCHI (cPattern, cValue) /* compares two strings */
Check if whole cValue is covered by cPattern */
HB_FILEMATCH (cFileName, cPattern)
/* eg. HB_FILEMATCH ("picture.bmp", "*.bmp") ---> return TRUE if file exist */
/* eg. HB_FILEMATCH ("c:\image\picture.bmp", "picture.bmp") ---> return TRUE if file exist */
* harbour/src/rtl/strtoexp.c
HB_STRTOEXP() /* convert string to valid macrocompiler expression */
* harbour/src/rtl/strtran.c
STRTRAN()
* harbour/src/rtl/trim.c
LTRIM()
RTRIM()
TRIM() /* synonymn for RTRIM */
ALLTRIM()
* harbour/src/vm/hvm.c
/* operator $ */
<cSubStr> $ <cStr> /* return TRUE if <cSubStr> is contained in <cStr> */
* harbour/src/rtl/cdpapihb.c
HB_STRTOUTF8 (<cStr> [, <cCPID> ] ) -> <cUTF8Str>
HB_UTF8TOSTR (<cUTF8Str> [, <cCPID> ] ) -> <cStr>
* <cCPID> is Harbour codepage id, f.e.: "EN", "ES", "ESWIN", "PLISO", "PLMAZ", "PL852", "PLWIN", ...
* When not given then default HVM codepage (set by HB_SETCODEPAGE()) is used.
HB_TRANSLATE ( <cSrcText>, [<cPageFrom>], [<cPageTo>] ) --> cDstText /* is used usually to convert between the Dos and the Windows code pages of the same language */
HB_UTF8CHR ()
HB_UTF8ASC ()
HB_UTF8AT ()
HB_UTF8RAT () /* NOTE: In HB_UTF8RAT we are still traversing from left to right, as it would be required anyway to determine the real string length */
HB_UTF8SUBSTR ()
HB_UTF8LEFT ()
HB_UTF8RIGHT ()
HB_UTF8PEEK ()
HB_UTF8POKE ()
HB_UTF8STUFF ()
HB_UTF8LEN ()
HB_UTF8STRTRAN() /* equal to STRTRAN() */
/* Miscellaneous Functions */
All functions STRINGS related to DATE and TIME
SPACE() /* returns n copies of a single space */
STR()
STRZERO ()
TYPE()
VAL()
HB_VALTOSTR() /* converts any data type to STR*/
VALTYPE()
HB_ISSTRING()
HB_ISCHAR()
HB_ISMEMO()
Claudio Soto.
HB_TOKENCOUNT()
HB_TOKENGET()
HB_ATOKENS()
MEMOREAD()
MEMOWRIT()
MEMOTRAN()
STRTRAN()
LTRIM()
RTRIM()
ALLTRIM()
/* operator $ */
HB_UTF8CHR ()
HB_UTF8ASC ()
HB_UTF8AT ()
HB_UTF8SUBSTR ()
HB_UTF8LEFT ()
HB_UTF8RIGHT ()
HB_UTF8PEEK ()
HB_UTF8POKE ()
HB_UTF8STUFF ()
HB_UTF8LEN ()
STR()
STRZERO ()
TYPE()
VAL()
VALTYPE()
HB_ISSTRING()
HB_ISCHAR()
HB_ISMEMO()
Re: UNICODE Strings Functions
Thanks a lot Claudio. It shows that there is a long way to go...
Thank you Claudio Soto for sharing
- srvet_claudio
Functions that support only ANSI strings
/* All these functions work with CodePages using custom character indexes (ANSI CodePage), do not support UNICODE. */
* harbour/src/rtl/at.c
HB_AT()
AT()
* harbour/src/rtl/ati.c
HB_ATI()
* harbour/src/rtl/hbstrsh.c
HB_STRSHRINK()
* harbour/src/rtl/left.c
LEFT()
* harbour/src/rtl/len.c
LEN()
* harbour/src/rtl/pad.c
PAD() /* synonymn for PADR */
* harbour/src/rtl/padc.c
PADC()
* harbour/src/rtl/padl.c
PADL()
* harbour/src/rtl/padr.c
PADR()
* harbour/src/rtl/rat.c
RAT()
HB_RAT()
* harbour/src/rtl/right.c
RIGHT()
* harbour/src/rtl/strcase.c
LOWER()
UPPER()
* harbour/src/rtl/stuff.c
STUFF()
* harbour/src/rtl/sub str.c
SUB STR()
* harbour/src/rtl/transfrm.c
TRANSFORM()
HB_AT()
AT()
HB_ATI()
HB_STRSHRINK()
LEFT()
LEN()
PADC()
PADL()
PADR()
RAT()
HB_RAT()
RIGHT()
LOWER()
UPPER()
STUFF()
SUB STR()
TRANSFORM()
- srvet_claudio
Dear Claudio, functions like these:
- All functions STRINGS related to DATE and TIME (DTOC,DTOS...)
- Trim, AllTrim, LTrim
- Str
Are not included in list of your instructions ?
- Str
srvet_claudio wrote:To develop applications that support ANSI and UNICODE, we must abandon those text functions that only support ANSI character set. Here is a partial list of equivalences:Code: Select all
ANSI/UNICODE ANSI Only - HMG_LEN() <=> LEN() - HMG_LOWER() <=> LOWER() - HMG_UPPER() <=> UPPER() - HMG_PADC() <=> PADC() - HMG_PADL() <=> PADL() - HMG_PADR() <=> PADR() - HMG_ISALPHA() <=> ISALPHA() - HMG_ISDIGIT() <=> ISDIGIT() - HMG_ISLOWER() <=> ISLOWER() - HMG_ISUPPER() <=> ISUPPER() - HMG_ISALPHANUMERIC() <=> RETURN (ISALPHA(c) .OR. ISDIGIT(c)) Harbour native functions: ------------------------- HB_USUBSTR() <=> SUBSTR() HB_ULEFT() <=> LEFT() HB_URIGHT() <=> RIGHT() HB_UAT() <=> AT() HB_UTF8RAT() <=> RAT() HB_UTF8STUFF() <=> STUFF()
You have to replace in the source code all functions which only supports ANSI character set for ANSI/UNICODE equivalent functions.
- srvet_claudio
Pablo,Pablo César wrote:Dear Claudio, functions like these:
- Str
this is only a partial list that is included in the changelog with the most used functions to prevent errors when developing programs.
Functions such as date and time, alltrim, etc., are the same for ANSI and for ANSI/Unicode and therefore does not make sense to put them here.
Just have to replace the functions that support only ANSI for functions that support ANSI/Unicode
Ok, It is clear now. Thank you !srvet_claudio wrote:Functions such as date and time, alltrim, etc., are the same for ANSI and for ANSI/Unicode and therefore does not make sense to put them here.
Claudio and rest,
Please note to be included as part of "Harbour native functions" in our DOC/HMG UNICODE:
hb_UPadL(), hb_UPadR() and hb_UPadC()
Please read this
Keeping informed
Please read this
Keeping informed
