browse
t57042
browse
Post by t57042 »
With the BROWSE command is it possible to edit the record in a separate window (so not inplace)?
Thanks Richard
Re: browse
You need to define your own window to edit data. You can also use InputWindow.
Edit procedure can be called from upper menu, context menu, bottom or hetkey.
Re: browse
t57042 wrote:With the BROWSE command is it possible to edit the record in a separate window (so not inplace)?
Demo prg of EDIT EXTENDED already works in this way ;)
Re: browse
Hola a Todos :
a pesar que en la referencia de HMG dice que puedo mirar los distintos ejemplos
hmg.3.0.46 no contiene dichos ejemplos : \hmg\samples\browse_5\ , donde puedo conseguir dichos ejemplos para no tener que recurrir a Minigui ext.
HMG Reference (c)2002-2010 Roberto Lopez httpsites.google.jpg (64.99 KiB) Viewed 8552 times
gracias /thanks
Google Translate
Hi Everyone:
although the HMG reference says that I can look at many examples
hmg.3.0.46 not contain these examples: \hmg\samples\browse_5\ , where I can get these examples to avoid resorting to MiniGUI ext.
I enter the data to browse do not come a .dbf
Re: browse
danielmaximiliano wrote: hmg.3.0.46 not contain these examples: \hmg\samples\browse_5\ , where I can get these examples to avoid resorting
Hola Daniel
Browse samples extracted from official HMG distribution for a long time ago :(
BROWSES.zip
BROWSE samples of HMG
(134.43 KiB) Downloaded 970 times
Re: browse
Thanks / Gracias Esgici.
klauskugel
Re: browse
Post by klauskugel »
Hola Daniel,
Is it this the sort of Code your looking for?
#include "minigui.ch" // Minigui 2.9.5
SET DELETED ON
DEFINE WINDOW Form_1 ;
WIDTH 640 HEIGHT 480 ;
TITLE 'MiniGUI Browse Demo)' ;
MAIN NOMAXIMIZE ;
ON INIT OpenTables() ;
ON RELEASE CloseTables()
DEFINE MAIN MENU
POPUP 'File'
ITEM 'Delete' ACTION Def_Excluir()
ITEM 'Refresh' ACTION Form_1.Browse_1.Refresh
SEPARATOR
ITEM 'Exit' ACTION Form_1.Release
END POPUP
END MENU
@ 10,10 BROWSE Browse_1 ;
WIDTH 610 ;
HEIGHT 390 ;
HEADERS { 'Code' , 'First Name' , 'Last Name', 'Birth Date', 'Married' , 'Biography' } ;
WIDTHS { 150 , 150 , 150 , 150 , 150 , 150 } ;
WORKAREA Test ;
FIELDS { 'Test->Code' , 'Test->First' , 'Test->Last' , 'Test->Birth' , 'Test->Married' , 'Test->Bio' } ;
TOOLTIP 'Browse Test' ;
DELETE ;
LOCK ;
EDIT APPEND
CENTER WINDOW Form_1
Form_1.Browse_1.SetFocus
ACTIVATE WINDOW Form_1
Procedure OpenTables()
Use Test Index Code
Go Top
Form_1.Browse_1.Value := RecNo()
Procedure CloseTables()
Use
Function Def_Excluir()
if MsgYesNo("Deseja excluir o registro corrente?",'')
TEST->(DBGoto(Form_1.Browse_1.Value))
While(TEST->(!RLOCK()))
enddo
TEST->(DBDelete())
TEST->(DBUnlock())
Form_1.Browse_1.Refresh()
MsgInfo(" Concluido! ",)
mybrowse295.zip
(3.54 KiB) Downloaded 604 times
klauskugel
Re: browse
Here the full set of browse in 2.9.5
So by now that's the full set of the past.
I just looked in Esgicis examples and thought
the 2.9.5 examples could be useful.
:D
Greetings klauskugel
brow295.zip
(97.29 KiB) Downloaded 638 times
Czarny_Pijar
Re: browse
Post by Czarny_Pijar »
Looks like the BROWSE command now is orphaned in favor of GRID. Only misleading echoes of those good times can be heard, among other in the priceless Esgici's guide to IDE, quote:
Step - 2 : Copy TEST.DBF and TEST.DBT from C:\hmg\SAMPLES\BROWSE_1 folder to your new folder.
Fortunately these files can be found elsewhere.
Also the Browse button hit the little honorable last place in the toolbox roster.
BTW, thank you folks for BROWSE examples, :roll: when I came here, these examples were kissed goodbay already.
Re: browse
klauskugel wrote: I just looked in Esgicis examples
FYI :
That are official samples of HMG, not mine.
