HbFoxPro library. Commands and functions foxpro for Harbour
Hi all,
This is the library that contains the implementation FoxPro command and functions.
in this version are:
SCATTER MEMVAR ...
SCATTER ...TO ARRAY
GATHER ....
SCAN ... ENDSCAN
_USE
minisql
CREATE TABLE
CREATE DBF
INSERT INTO ...
future plan:
UPDATE
SELECT
ALTER TABLE
http://code.google.com/p/santysoft/down ... akechanges
SCATTER MEMVAR ...
SCATTER ...TO ARRAY
GATHER ....
SCAN ... ENDSCAN
_USE
minisql
CREATE TABLE
CREATE DBF
INSERT INTO ...
future plan:
UPDATE
SELECT
ALTER TABLE
Oleksandr Antypenko
xHarbour 1.2.3 , Harbour 3.x + Mingw 4.x (HMG, minigui)
https://bitbucket.org/aantypenko
https://github.com/aantypenko
Oleksandr Antypenko
Re: HbFoxPro library. Commands and functions foxpro for Harb
Hi Alex
Thanks with hope to continue
что касается
Brilliant implementation, nice participationsanty wrote: This is the library that contains the implementation FoxPro command and functions.
что касается
Thank you esgici.
to be continued
to be continued
Oleksandr Antypenko
Oleksandr Antypenko
Really nice to hear. Thanks and please continue.
Update HbFoxLib library.
Added the following functions and commands:
http://code.google.com/p/santysoft/dow ... kechanges
GO TOP IN <cTableAlias>
GO BOTTOM IN <cTableAlias>
GOTO <nRecno> IN <cTableAlias>
RECCOUNT(<cTableAlias>)
FCOUNT(<cTableAlias>)
FILTER(<cTableAlias>)
USED(<cTableAlias>)
USED(<nWorkArea>)
SET FILTER TO <cFilter> IN <cTableAlias>
SEEK <eExpression> [<soft: SOFTSEEK>] [<last: LAST>] TAG
<cTagName> IN <cTableAlias>
Oleksandr Antypenko
Oleksandr Antypenko
Very nice !
Thanks Alex
Thanks Alex
Excellant
Continue
Continue
Gracias Santy por este muy buen trabajo, realmente me perdi este post
Santy Thanks for this very good work, I really lost this post
Gracias a todos, y mis felicitaciones a Santy Excelente trabajo. Estoy haciendo un pequeño proyecto para el control de asistencia y calificaciones con la nueva reforma educativa de México. pero en el grid de la lista de asistencia me gustaría poner una imagen "palomita" si asistió el alumno y cambiar la imagen por una "X" si no asistió, eso con un solo clic, y reportar las fechas de inasistencia.
como pueden ver solo soy un profesor de secundaria, pero que se dedicó un poco a la programación en vFoxpro ahora quiero aprender a usar HMG. estoy seguro que con ustedes lo voy a lograr.
Traductor de Google.
Thank you all, and congratulations to Santy Excellent work. I'm doing a small project for monitoring attendance and grades with the new educational reform in Mexico. but in the grid of the attendance I would add a "pop" image if the student attended and change the image by an "X" if not attended, that with one click, and report the dates of absence.
as you can see I'm just a high school teacher, but rather devoted to programming in vFoxpro now I want to learn how to use HMG. I'm sure with you I will achieve
- luisvasquezcl
Hola Santy,
gracias por tu aporte. voy a probarlo y comento.
saludos cordiales,
Luis Vásquez.
saludos cordiales,
Luis Vásquez.
