HMG 3.0.46
HMG 3.0.46
Hi all,
I have immense pleasure in announcing the new version of HMG.
In deed, this version has a radical change of almost all the source code files. Thanks to Claudio Soto, now most of the compiler warnings are vanished. Mass cleaning up of code helps to optimize the library, I think.
Again thanks to Claudio, HMG_HPDF is now complete, as you can include in the PDF any image (jpg or png) from resource also.
HMG 3.0.46 (2012-11-06) can be downloaded from here (40.70 MB)
Alternatively you can download from sourceforge.net too.
- HMG 3.0.46 (Test) 2012/11/06
   - Update to latest Harbour Nightly Build (18443 2012-11-05)
   - New
      - Print Barcode sample. See samples/printean13 folder for details. (Contributed by Marek Olszewski)
      - Desktop Make Shortcut for file/dir and URLs in HFCL. See sample at hfcl/samples/makeshortcut folder. (Contributed by B.P Dave and Esgici)
      - buildalllib.bat in the base directory to build all the libraries including hmg, hfcl, hmgsqlbridges, crypt, edit, editex, ini, graph, report etc with a single call.
      - Included hbvpdf library in HMG library folder. This library is required to compile all the samples in samples/report.advanced folders.
   - Update
      - Bos Taurus Graphics library 1.01. Author Claudio Soto had modified the source files to make it compatible for HFCL. (Thanks to Claudio Soto)
         - Updated BT_BitmapLoadFile() fuction, now load images in the formats: BMP, GIF, JPG, TIF and PNG.
         - Added Functions:
            - BT_BitmapInvert
            - BT_BitmapContrast
            - BT_BitmapModifyColor
            - BT_BitmapGammaCorrect
            - BT_BitmapConvolutionFilter3x3
         - Updated BosTaurus-FunctionsReferenceGuide.PDF with changes made.
         - Added Demo10
      - HMG_HPDF Library in HFCL. Now the image command accepts both jpg and png file formats from either file or resource location. (Contributed by Claudio Soto)
   - Fix
      - Number of warnings while compiling the HMG library is now reduced to only six. Great thanks to Claudio Soto.
      - Hardcoded Path name references in batch files. Now HMG can be installed any path (having no spaces).
Re: HMG 3.0.46
rathinagiri wrote:I have immense pleasure in announcing the new version of HMG. ...
We have immense pleasure in thanks to you Mr. Diamond :arrow:
Best regards :D
Re: HMG 3.0.46
Many thanks Rathi.
Claudio.
Re: HMG 3.0.46
Claudio, thanks a lot for your contribution.
Actually this version can be dedicated to Claudio Soto. :)
chrisjx2002
Re: HMG 3.0.46
Post by chrisjx2002 »
Thanks for this new release!!!
Re: HMG 3.0.46
rathinagiri wrote:Claudio, thanks a lot for your contribution.
Dear Rathi.
Wow, is an honor for me !!! :D
Thank you very much, you are very kind, in fact my contribution is very small.
Claudio.
Re: HMG 3.0.46
Hi all.
Error when compiling examples of HFCL.
SOLUTION: eliminate the incremental directive (-inc) in line 2 of the file:
C:\hmg.3.0.46\HFCL\Source\hfcl.hbp
and re-build the HFCL library
(execute C:\hmg.3.0.46\hfcl\Source\buildlib.bat).
Claudio Soto.
Re: HMG 3.0.46
Dear Rathi,
Thank you for upgraded version
Happy Diwali
Re: HMG 3.0.46
bpd2000 wrote:Happy Diwali
Congrats to Indian friends for festival of lights :)
Happy "garland of lights" :D
Diwali Shakra
Diwali Shakra
With my best regards
