Harbour nightly builds
Hi
Does we can use Harbour nightly builds for compiling HMG applications ?
Copying whole Harbour folder to Harbour sub-folder of HMG may be right, or will cause some objections ?
TIA
TIA
Re: Harbour nightly builds
Hola Esgici :
Creo que no habria problemas, solo algún caso que cambie alguna función de Harbour y este genere
algún error; sinceramente no probe o intente copiar las carpetas /Bin /Lib y /Include a sus respectivo lugares en HMG.
mas tarde intentaré que no se inunde el barco
Translate Google :
Hello Esgici:
I think there would be no problems, only some case you change some function of Harbour and this generates
an error; honestly do not probe or try to copy the folders / bin / lib and / Include their respective places in HMG.
later try to not flood the boat: lol:
Translate Google :
Hello Esgici:
Hola Daniel
By the way how is your sixth finger, does all right
You are so sweet as alwaysdanielmaximiliano wrote:...later try to not flood the boat
IMHO, copying the whole Harbour directory inside HMG harbour directory is not at all a problem. Actually that is what had been done in every release of HMG version.
Hi
Found another way; in <hmg>\build.bat :
Tested and affirmed working.
But not sure that this way if smooth and secure.
Any idea ?
TIA
rem ******************************************************************************
rem SET BINARIES PATHS
rem SET PATH=%HMGPATH%\harbour\bin;%HMGPATH%\mingw\bin;%PATH%
SET PATH=C:\harbour\bin;C:\Harbour\comp\mingw\bin;%PATH%But not sure that this way if smooth and secure.
Any idea ?
TIA
In another forum one user said Harbour in HMG folder is not the same, not like as original one. Saying:
Although I have stated that the Harbour is the same as the original version. He replied with:But surely it is not the official version.
Have left (my source code) standard to compile with / w3 / s2, and was ok in Harbour 3.0.
In Harbour HMG showed a 5 static functions that were not more in use.
If (compilation) done differently, then it is different.
What is the meaning with that ? Is Harbour diferent version in HMG folder ? Or is wrongly considering our compile way which HMG sets with its environment as amended version of Harbour ? I do not understand why he says HMG´s Harbour is different as oficial one. Some one could explain it ?The problem was not Harbour, although different from the official. The visible difference was this compiler detects static functions discarded
Hello Esgici:esgici wrote:Hi
Tested and affirmed working.Code: Select all
rem ****************************************************************************** rem SET BINARIES PATHS rem ****************************************************************************** rem SET PATH=%HMGPATH%\harbour\bin;%HMGPATH%\mingw\bin;%PATH% SET PATH=C:\harbour\bin;C:\Harbour\comp\mingw\bin;%PATH%
Any idea ?
TIA
I did a little more complicated, copy the respective folders Harbour Nightly
C:\HB32\Bin --------->C:\hmg.3.0.45\HARBOUR\bin
\Lib \Lib
\Doc \Doc
\Include \Include
The Harbour compiler performs the same function as CLIPPER.EXE (MR).
It has the advantage that it can generate C language code, making it compatible with virtually thousands of libraries and programs.
Work is the option to generate executables for each of the platforms.
converts
PRG files ---> File "C" (Harbour) ---------> MinGW--------->executables
BCC5.5
OpenWatcom One of the disadvantages is that MinGW executables are generated larger size than those generated by other compilers. This occurs when you include the header files for C + + standards (for example, # include <iostream>), and because the compiler links all libraries within the executable statically.
OpenWatcom Small executables for Harbour/xHarbour
This it means Harbour in HMG package is the same than original one. Right ?I did a little more complicated, copy the respective folders Harbour Nightly , works without any problem.
Ola Pablo
Moreover someone likes much to malign to people and systems even without any argument and even with mendacious claims
By the way, I'm admirant of your management skill as a forum moderator
Saudação
As far as know, there isn't any UNOFFICIAL Harbour anywhere and there isn't any difference between versions released by Harbour and embedded one in HMG.Pablo César wrote:I do not understand why he says HMG´s Harbour is different as oficial one. Some one could explain it ?
rathinagiri wrote:IMHO, copying the whole Harbour directory inside HMG harbour directory is not at all a problem. Actually that is what had been done in every release of HMG version.
esgici wrote:Tested and affirmed working.Code: Select all
Compiling / building process of both Harbour and HMG is quite complex and everybody can confuse something.danielmaximiliano wrote:I did a little more complicated, copy the respective folders Harbour Nightly , works without any problem.
Saudação
Yes amigo, there are people that prefers to say mendacious claims and without arguments, than recognize their own errorsMoreover someone likes much to malign to people and systems even without any argument and even with mendacious claims
Your words at this time makes me feel better. Thanks amigo !By the way, I'm admirant of your management skill as a forum moderator
