Compilation problem with version 3.0.45
chrisjx2002
Hello,
I have theses errors messages with the last hmg version :
C:/DOCUME~1/CHRIST~1/LOCALS~1/Temp/hbmk_bwkvxc.dir/taxation27.o:taxation27.c:(.data+0x848): undefined reference to `HB_FUN_DBPACK'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x188): undefined reference to `HB_FUN_PDFINIT'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x1a8): undefined reference to `HB_FUN_PDFOPEN'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x2d8): undefined reference to `HB_FUN_PDFNEWPAGE'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x388): undefined reference to `HB_FUN_PDFCLOSE'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x458): undefined reference to `HB_FUN_PDFSETFONT'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x468): undefined reference to `HB_FUN_PDFATSAY'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x478): undefined reference to `HB_FUN_PDFTEXTWIDTH'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4a8): undefined reference to `HB_FUN_PDFIMAGE'
c:/hmg.3.0.45/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4c8): undefined reference to `HB_FUN_PDFBOX'
What is the solution to this problem?
Re: Compilation problem with version 3.0.45
What is the project you want to compile ?chrisjx2002 wrote:...What is the solution to this problem?
Hi Chris
It's difficult to explore the source of problem by given info
Please try add
line to your configuration ( "configuration" tab of IDE or .hbc file of your project ).
Please don't misunderstand, I want say "your project is one of HMG sample or not ?"chrisjx2002 wrote: I have theses errors messages with the last hmg version :
Please try add
libs=hbvpdfRegards
chrisjx2002
Hello,
The program was compiling with an old version of hmg : 3.0.35. I want to recompile it with the last version of hmg and I got these errors messages. Something has changed but I don't know what. For instance the function dbpack is no more recognize (first error message).
It is not an hmg sample.
Hi Chris
Does other errors ( other than "dbpack" ) fixed by "libs=..." ?
If so could you give the statement used "dbpack" in ?
This type of errors generally caused by changes in Harbour, not HMG.chrisjx2002 wrote: The program was compiling with an old version of hmg : 3.0.35. I want to recompile it with the last version of hmg and I got these errors messages. Something has changed but I don't know what. For instance the function dbpack is no more recognize (first error message).
- Carlos Reis
Hello!
I would like first to thank all those who have developed the HMG.
It has been a great help in my work.
To all of you my thanks
I recently downloaded the new version HMG 3.0.45
I work with databases in MYSQL
So I compiled the prg's that worked in previous versions with this new version,
but now I have a little problem.
Fields of type Tinyint in old versions return boolean values,
now with HMG 3.0.45 return a numeric value.
Do I have to change all my prg's or there is no way to resolve the problem ?
Thanks in advance
Thanks in advance
Best Regards
Carlos Reis, Portugal
39º 46' 47" N
08º 55' 45 W
39º 46' 47" N
08º 55' 45 W
Ola Carlos
Carlos Reis wrote:Hello!
To all of you my thanks![]()
Thanks in advance
SaudaçãoHarbour Changelog wrote:2011-10-24 01:40 UTC+0200 Viktor Szakats (harbour syenar.net)
* contrib/hbmysql/tmysql.prg
! tinyInt type in MySQL is now always regarded as numeric value (was bool)
Patch by Mitja Podgornik.
; This causes unavoidable INCOMPATIBILITY. [INCOMPAT]
Hi Chris
libs=hbxpp
line to your configuration ( "Configuration tab of IDE or .hbc file of your project )
or change dbPack() statements to Hb_dbPack() in your .prg files.
So you need addHarbour Changelog wrote: 2008-05-22 10:30 UTC+0100 Viktor Szakats (harbour syenar.net)
* source/rdd/dbcmdx.c
+ Added dbPack() and dbZap() Xbase++
compatibility functions.
2008-04-26 07:53 UTC+0100 Viktor Szakats (harbour syenar.net)
+ source/rdd/dbcmdhb.c
+ Added non-internal versions of __dbPack() and __dbZap(),
named: hb_dbPack() and hb_dbZap(). If group needs it I
can add dbPack() and dbZap() too in separate files to
lessen the problem of name collision with app code.
libs=hbxpp
Hi Carlos Reis,Carlos Reis wrote:Hello!
Thanks in advance
This is a fundamental change happened many versions before.
If you want to change all your prg's, you can do so. However, I did a workaround to revert back.
chrisjx2002
Hi Escigi,
Thanks for your help.
Regarding dbpack, I change it for hb_dbpack and the compilation is now OK.
For the lib to add, as I don't use IDE for programming, is it possible to add the lib directly at the beginning of the programm? Something like #include ...
