Object on Form can be move by user
Dear All,
It is possible by user to drag /move object like Text Box, Button etc. on Form
and we can know Screen position of said object
Example please
Re: Object on Form can be move by user
Do you think about something like IDE?
I was thinking about it too, but I have no idea.
Maybe Roberto could free the code of IDE? Maybe some piece of code for dragging controls?
Hi
Consider this small sample. Just 'ActivateDrag' and then select the control to drag. Then just drag the control to wherever you want inside the window and drop.
   define window sample at 0, 0 width 800 height 600 main on mousedrag mousedragged()
      define toolbar tool1
         toolbutton c1 caption 'Activate Drag' check .t.
      end toolbar
      define button b1
         row 200
         col 100
         caption 'Move it!'
         action b1action()
      end button
      define textbox t1
         row 200
         col 200
      end textbox
      define statusbar
         statusitem ''
         statusitem 'Row:'
         statusitem 'Col:'
      end statusbar
   end window
   sample.center
   sample.activate
function b1action
if sample.c1.value
   return nil
msginfo( 'Clicked' )
return nil
function mousedragged
   local cCtrlName := _GetFocusedControl ( 'sample' )
   sample.statusbar.item( 1 ) := 'Active Control: ' + cCtrlName
   sample.StatusBar.Item( 2 ) := "Row : " + LTRIM( STR( _HMG_SYSDATA [ 191 ] )) // Mouse Row
   sample.StatusBar.Item( 3 ) := "Col : " + LTRIM( STR( _HMG_SYSDATA [ 192 ] )) // Mouse Col
   if sample.c1.value
      setproperty( 'sample', cCtrlName, 'ROW', _HMG_SYSDATA [ 191 ] )
      setproperty( 'sample', cCtrlName, 'COL', _HMG_SYSDATA [ 192 ] )
return nil
Dear Rathi,
Excellant, thank you for example
Any improvement in code, on Activate Drag
We select Object, Object will move as per mouse movement
on Right Click it release
Dear Rathi,
On change from
to
define window sample at 0, 0 width 800 height 600 main on mousemove mousedragged()
Control moves as per mouse movement but how to release mouse / control
pl. guide
That is the problem. You can make escape key press to release. Use On Key ESCAPE.
Please don't indulge users :lol:
rathinagiri wrote:That is the problem. You can make escape key press to release. Use On Key ESCAPE.
There must be some solution
Is there mouse event / click related example ??
Hola a todos,
Creia yo que estaba inventando la rueda, si la rueda ya esta hecha. Pero se los comparto a ver si a alguien le sirve! :D
PROCEDURE DefWindow()
   DEFINE WINDOW frmMousDrag;
		AT 0, 0 ;
		WIDTH 620 HEIGHT 400 ;
		TITLE "Mouse drag sample" ;
		MAIN ;
		ON INIT NIL;
		ON MOUSEDRAG MueveControl()
		@ 10,200 LABEL Label_1 WIDTH 60 HEIGHT 12 VALUE "Trabajador" ACTION MiNombre(1)
		@ 70,20  LABEL Label_2 WIDTH 50 HEIGHT 12 VALUE "Nombre" ACTION MiNombre(2)
		@ 90,20  LABEL Label_3 WIDTH 50 HEIGHT 12 VALUE "Activo" ACTION MiNombre(4)
		@ 70,200 TEXTBOX TextBox_1 ;
		VALUE 'Hi All' ;
		TOOLTIP 'Character TextBox' ;
		HEIGHT 20 ;
		ON GOTFOCUS MiNombre(3) ;
		DISABLEDBACKCOLOR { 0,255,0 } ;
		DISABLEDFONTCOLOR { 255,255,255 }
		DEFINE CHECKBOX CheckBox_1
			ROW 90
			COL 200
			CAPTION ""
			VALUE .F.
			WIDTH 20
			HEIGHT 20
			ONGOTFOCUS MiNombre(5)
		END CHECKBOX
PROCEDURE MAIN()
PUBLIC cName := ''
PUBLIC nCursRow := 0
PUBLIC nCursCol := 0
   DefWindow()
   ON KEY ESCAPE OF frmMousDrag ACTION ThisWindow.Release
   frmMousDrag.Center
   frmMousDrag.Activate
RETURN  // Main()
PROCEDURE MueveControl()
	nCursRow := GetCursorPos()[ 1 ] - frmMousDrag.Row
	nCursCol := GetCursorPos()[ 2 ] - frmMousDrag.Col
	frmMousDrag.&(cName).Row := nCursRow
	frmMousDrag.&(cName).Col := nCursCol
PROCEDURE MiNombre(nControl)
	IF nControl = 1
		cName := "Label_1"
	ELSEIF nControl = 2
		cName := "Label_2"
	ELSEIF nControl = 3
		cName := "TextBox_1"
	ELSEIF nControl = 4
		cName := "Label_3"
	ELSEIF nControl = 5
		cName := "CheckBox_1"
P.D.: Solo el control debe de tener el foco! :D , después hacer Click en el Form-arrastrar y soltar.
Dear Javier Tovar,
Thank you for code
I have created attached sample code that can be compile in minigui
I want same code to compile in HMG
Any help
demo.rar
(537 Bytes) Downloaded 218 times
