If I have a button, instead of changing the caption using code like this:
main_win.button_1.caption = '12345'
could I do something like this:
button_1 [x] = '12345'
Can I access the data in a control via an array?
Re: Can I access the data in a control via an array?
I don't know.metron9 wrote:If I have a button, instead of changing the caption using code like this:
But you can use it in this way:
SetProperty("Main_Win", "button_1","caption","'12345")
for i:=1 to 10
cButtonName := "button_"+alltrim(str(i))
SetProperty("Main_Win", cButtonName","caption", str(1,2))
Regards, Marek
Hi Mark
For an example please refer here.
For naming and assigning properties to controls, in addition to Marek's suggestion (using SetProperty() function), you may use also macro substitution (with & operator).metron9 wrote:If I have a button, instead of changing the caption using code like this:
Both replies I needed to implement.
I was trying to use a macro in the ACTION like this:
function anewbutton(parm1,Parm2,Parm3,Parm4)
N_Button= 'col'+ltrim(str(parm1))+'_B'
A_ct = 'virt_board.job_'+ltrim(str(Parm1))+'.caption'
DEFINE BUTTON &N_button
PARENT VIRT_BOARD
ROW Parm2
COL Parm3
WIDTH 80
HEIGHT 25
CAPTION parm4
ACTION virtbutton1(&A_ct)
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .T.
END BUTTON
return nil
So I changed the ACTION to
ACTION virtbutton1(Parm1)
and then changed the function virtbutton to:
function virtbutton1(parm1) /* Save last job button pushed */
lastBpushed := parm1
lastJpushed = GETProperty("virt_board", N_button,"caption")
msgbox(N_button+' '+lastJpushed)
return nil
I had actually wrote a program to generate the code to make the buttons and put it in a file.ch
then included it inside the window declaration.
got to go , dentist appointment
Thank you.
PARENT VIRT_BOARD
ROW Parm2
COL Parm3
WIDTH 80
HEIGHT 25
CAPTION parm4
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .T.
END BUTTON
return nil
return nil
Thank you.
