help opening the .hbd files...
Hi James
James wrote:Hi everybody! I'm trying to open the .hbd files in the HARBOUR\doc folder, with no success. Any pointers? Gracias!
( viewtopic.php?f=5&t=2488 )
Personally I don't know anything about .hbd files :(
Please could you explain what are and what you expect by opening they ?
If your expectation is gather documents / info on Harbour, did you tried \Harbour\extras\hbdoc\hbdoc.exe ?
Re: help opening the .hbd files...
Hi James
Found something :idea:
I don't know is this the answer of your question; I hope help you: Harbour documetation inside hdb
Carlos Britos
Post by Carlos Britos »
Hi James
files.hbd are the harbour docs.
If you are trying to read them, then,
you can use hbide
or getting the harbour doc folder with the files.txt
Carlos Britos wrote: files.hbd are the harbour docs.
you can use hbide
Hi Carlos
Thanks to info
Does it include undocumenteds ?
Is there a way to get a whole documentation ?
Carlos Britos
HI Esgici
Hbd files contain all the txt files with text enclosed between $DOC$ and $END$. These .txt files are in the different harbour folders. No luck for Undocumenteds :(
In the harbour (binary) folder you'll find only .hbd for those contrib that has some docs in the svn.
There are so many undocuments functions :cry:
The hbd has a format that enabled us to build htm, pdf, etc.. . I don't know if exist a tool to do this. Time ago I made something for hmg4 docs but is not strictly for harbour.
Hola Carlos
Thanks to clarification :)
Hi :
https://groups.google.com/forum/#!topic ... 3po2g6JYnY
Sivolasi 10/08/11
In the directory \ doc are files with the extension *. HBD. Which
program should I use to open these files?
vszakats 10/08/11
.hbd files are compiled, distributable form of NF docs.
They can be read/written by internal HBDOC API in Harbour core.
Currently HBIDE uses this API and .hbd files.
Viktor Z
This is the only function you need to use:
__HBDOC_LOADHBD( <cFileName> ) -> <hbdoc> | NIL
Returned hbdoc is an array of hash tables, each
hash contains the doc items, f.e.:
hbdoc[ 1 ][ "NAME" ] -> "EVAL()"
That's only API you need to know, the actual on-disk
format is also handled by this internal API.
HBD files in DOC - Grupos de Google - Mozilla Firefox_2012-09-27_14-54-26.jpg
HBD files in DOC - Grupos de Google - Mozilla Firefox_2012-09-27_14-54-26.jpg (40.42 KiB) Viewed 32063 times
