Window's Title to Center
How do I make the Window's Title align in “Center” not in “Left”.
How do I change the window's title alignment to center ? Like this:
I have tried to set Window's font to Courier New which is monospaced (fixed-width) but for title is not working.
Re: Window's Title to Center
Pablo César wrote:How do I make the Window's Title align in “Center” not in “Left”.
IMHO this is another unbreakable Windows rule : Window title must be left aligned ! :(
Pablo César wrote: How do I change the window's title alignment to center ?
Hello Pablo,
Please be so kind to try the following simple sample:
 * MiniGUI Window Demo
 * (c) 2012 Grigory Filatov
Procedure Main
	SET MULTIPLE OFF
	DEFINE WINDOW Form_1 ;
		WIDTH 640 ;
		HEIGHT 480 ;
		TITLE 'Main Window' ;
		MAIN ;
		ON INIT MoveTitle() ;
		ON MAXIMIZE MoveTitle() ;
		ON SIZE MoveTitle() ;
		BACKCOLOR GRAY
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Procedure MoveTitle()
	ThisWindow.Title := xPadC( 'Main Window', ThisWindow.Width * 1.2 - 40 )
function xPadC( cText, nPixels, cChar )
   local cRet    := If( Valtype( cText ) == "C", AllTrim( cText ), "" )
   local nLen    := Len( cText )
   local nPixLen
   local nPad
   DEFAULT cChar := Chr(32)
   nPixLen := GetTextWidth( , cText )
   nPad    := GetTextWidth( , cChar )
   if nPixels > nPixLen
      cRet := PadC( cRet, Int( nLen + ( nPixels - nPixLen ) / nPad ), cChar )
return cRet
Hope that helps :idea:
Wow Master ! Thank you for your indications, Mr. Grigory. It is almost quite 100% OK, but in order to avoid "..." as part of title shown, I have make some changings. Probably it is for my Windows is not main Window. Ssorry I have mentioned as main but in real is MODAL and with NOSIZE and NOSYSMENU. So I subtract -70 (wich is not exact value) but it approximally center aligned.
Could you please explain why in you code is subtracted 40 ?
I have adapted my STRU code like this:
DEFINE WINDOW MyAlert AT 0, 0  ;
    WIDTH 425 HEIGHT 155       ;
	TITLE cTitle MODAL         ;
	ON INIT MoveTitle(cTitle)  ;
	NOSIZE NOSYSMENU
Function MoveTitle(cTitle)
ThisWindow.Title := xPadC( cTitle, (ThisWindow.Width - 70) * 1.2 ) // please note here
If I do not change your code ,ThisWindow.Width * 1.2 - 40 ) for ,(ThisWindow.Width - 70) * 1.2 ) then my window is going to show these caracters "...", please see picture below:
I feel I am so near to reach a final solution regarding this value subtracted and I wish to avoid these points... so It will be very much appreciated your explanation about this subtracted value and why to multiply with 1.2 ?. Any way thanks again Mr. Grigory ! :D
Apparently, unbreakable is for novices like me; not for gurus ;)
Thanks Grigory :)
Hi Pablo.
Test with:
 ON INIT RTrim (MoveTitle(cTitle))  ;
Claudio.
srvet_claudio wrote:Hi Pablo.
Test with:
Claudio.
GRANDE, amigo ! Buena idea ! Muchas gracias.
