APPEND FROM DELIMITED WITH other char not comma ARE NOT IMPL
- arturo_lopesoria
Hello all
I'm Using hmg v3.0.25. I'm trying to append to a dbf from a delimited data txt file using:
APPEND FROM xcFile DELIMITED WITH optional clause
I can actually import data this way if the fields from file txt came delimited with commas.
But if data are separated with other different character as Pipe '|' APPEND FROM xcFile DELIMITED WITH '|' do not function as clipper/dbase original design was made
It seems like if nothing else was need this option with harbour actually..
or maybe I am doing something bad?
Thanks in advance
Arturo
Im Using hmg v3.0.25
C:\hmg.3.0.25\HARBOUR\bin>harbour
Harbour 2.0.0 (Rev. 13372)
Copyright (c) 1999-2010, http://www.harbour-project.org/
Arturo
Thanks in advance
Arturo
Arturo
- arturo_lopesoria
Re: APPEND FROM DELIMITED WITH other char not comma ARE NOT
I found the way this command is implemented in harbour:
APPEND FROM DELIMITED WITH PIPE
Is very usefull if comma may to be used inside a field, as part of data, like in a addres, etc..
I hope this will hope to somebody
Saludos desde Mexico
Arturo.
Arturo.
Thanks a lot for the info.
Hola Arturo, saludos desde Turkiye
such as
Anyway it isn't logical
will work, though
doesn't work.
If so, IMHO this will be considered a bug in Harbour
Any opinion
Does "PIPE" is a built-in (by Harbour) constant or we have declare and initialize it ?arturo_lopesoria wrote: APPEND FROM xcFile DELIMITED WITH '|' do not function.
such as
#define PIPE "|" // .or. CHR( 124 )
.or.
PUBLIC PIPE "|" // .or. CHR( 124 )
APPEND FROM xcFile DELIMITED WITH PIPE
Any opinion
This is from Harbour changelog:
APPEND FROM ... DELIMITED WITH TAB
APPEND FROM ... DELIMITED WITH PIPE
APPEND FROM ... DELIMITED WITH ( { cStrDelim, cFldSeparator } )
It seems that, 'PIPE' is hard coded in src/rdd/dbcmd.c
Thanks Rathi
Best regards
Best regards
- arturo_lopesoria
Esgici, Rathi.
Thanks to both as allways
Arturo
Arturo
- Czarny_Pijar
The command
COPY FIELDS ID,NAME TO temp.txt DELIMITED
works fine, but the
APPEND FROM temp.txt TYPE DELIMITED
can't even pass the compile process...
EDIT: never mind and forget it, JPARADA show me the right way*, thank you.
* http://hmgforum.com/viewtopic.php?f=24& ... TED#p10950
works fine, but the
- append_from.PNG (18.22 KiB) Viewed 12822 times
- Jairo Maia
Can't have the TYPE. Try in this way:Czarny_Pijar wrote:APPEND FROM temp.txt TYPE DELIMITED
APPEND FROM temp.txt DELIMITED
