Lock Columns in grid
Hi Rathi/Everyone:
You can disable a column in a grid in particular, thereby unable to edit it? ?
Hola Rathi / Todos:
es posible bloquear una columna de un grid en especial, de ese modo no puedan editar la misma ? ?
DEFINE GRID Articulos
        ROW    50
        COL    5
        WIDTH  735
        HEIGHT 460
        VALUE 1
        WIDTHS  { 50   , 140    ,260            ,130           ,150      }
        HEADERS {'Cant',' Codigo',' Descripción ',' P.Unitario ','Total'}
        FONTNAME "Arial"
        FONTSIZE 12
        TOOLTIP "Grid de Facturación"
        JUSTIFY { GRID_JTFY_RIGHT,GRID_JTFY_RIGHT, GRID_JTFY_LEFT  ,GRID_JTFY_RIGHT,GRID_JTFY_RIGHT}
        COLUMNCONTROLS { {'COMBOBOX' , {'1' , '2' , '3' , '4' , '5' , '6' , '7' , '8' , '9' , '10' , '11' , '12'  }} , ;
                         {'TEXTBOX'  ,'CHARACTER'              } , ;
                         {'TEXTBOX'  ,'NUMERIC','$ 999999.99'  } , ;
                         {'TEXTBOX'  ,'NUMERIC','$ 999999.99'  } }
        FONTBOLD .T.
        SHOWHEADERS .T.
        ON DBLCLICK SelectRow()
        ALLOWEDIT .T.
        CELLNAVIGATION .T.
        ITEMCOUNT 100
        BACKCOLOR NIL
        FONTCOLOR NIL
        HEADERIMAGES Nil
        ROWSOURCE Nil
        COLUMNFIELDS Nil
        ALLOWAPPEND .F.
        ALLOWDELETE .F.
        BUFFERED .F.
        ONSAVE Nil
        LOCKCOLUMNS 0
        DYNAMICBACKCOLOR {  bColor      , bColor      , bColor   , bColor   , bColor  }
		DYNAMICFORECOLOR {  fColor      , fColor      , fColor   , fColor   , fColor  }
    END GRID
Re: Lock Columns in grid
You can disable editing a column using the columnwhen option.
For example, if you have three columns in a grid, and you don't want to allow editing the second column, use this,
coumnwhen { {||.t.}, {||.f.}, {||.t.} }
That's all!
rathinagiri wrote:You can disable editing a column using the columnwhen option.
That's all!
Thanks Rathi, was looking for info on LOCKCOLUMNS <nValue>
and only one example in
C:\hmg.3.0.42\SAMPLES\GRID.38\demo.prg
Hola Daniel
danielmaximiliano wrote:... was looking for info on LOCKCOLUMNS <nValue>
Perhaps meaning of LOCKCOLUMNS is a bit different.
Please enter LOCK + COLUMN in "advanced search" of forum.
Rathi : funciona perfectamente
works perfectly, I noticed something in the grid. when I change "Number" does not update the Total of the product
Ventas por Registradora.jpg (48.01 KiB) Viewed 5122 times
Procedure ActualizaVenta()
 nRow := Ventas.Articulos.Value                                       //
 Ventas.Articulos.Cell(nRow,5) := Ventas.Articulos.Cell(nRow,4) * Ventas.Articulos.Cell(nRow,1)
 Ventas.Text_1.Value    := ''                                             //
 Ventas.nTotalArt.Value := 0                                              //
 Ventas.nTotal.Value    := 0.0
   For nFor := 1 to Ventas.Articulos.ItemCount                              //
       aRow := Ventas.Articulos.Item(nFor)                                  //
       Ventas.nTotalArt.Value := Ventas.nTotalArt.Value  + Ventas.Articulos.Cell(nFor,1)       //
       Ventas.nTotal.Value    := Ventas.nTotal.Value     + (Ventas.Articulos.Cell(nFor,4) * Ventas.Articulos.Cell(nFor,1))      //
   Next
Ventas.Articulos.Refresh
I see the error. If you add up the items and the total.
but that article I modified the amount.
Listo, Solucione el problema que no actualiza el Subtotal del producto.
Ventas por Registradora.jpg (46.47 KiB) Viewed 5115 times
con el siguiente codigo
To have accurate and immediate cell update, use ColumnValid option.
