WHOLEDROPDOWN
arroya2
WHOLEDROPDOWN
Post by arroya2 »
Hola amigos:
En un WHOLEDROPDOWN, cómo se puede controlar, mediante código, que el submenú aparezca más a la derecha o más a la izquierda.
Rafael Pérez
Hello friends:
In a WHOLEDROPDOWN, how you can control, through code, the submenu appears to the right or left.
Rafael Pérez
IMATECH
Re: WHOLEDROPDOWN
Post by IMATECH »
Can be solved removing all Separator's used on Button DropDown
M., Ronaldo
By: IMATECH
Imation Tecnologia
salamandra
DBs Used: DBF, MySQL, SQL
Re: WHOLEDROPDOWN
Post by salamandra »
HI arroya2,
This is a quite old issue, also posted Here by me sometime ago.
viewtopic.php?f=5&t=2266
and.. as Ronaldo said, seems to be a unique "solution" : remove the separators
if you really don´t need them. (and yes, I know: sometimes you would need grouping some buttons...)
[]´s Salamandra
arroya2
Re: WHOLEDROPDOWN
Post by arroya2 »
Es cierto. En cuanto he quitado los SEPARATORs, el submenú se ha colocado en su sitio. O mejor dicho los BUTTONs se han colocado en su sitio, porque el submenú no se ha movido nada.
Gracias a todos
Rafael Pérez
It's true. As I removed SEPARATORs, the submenu is placed on your site. Or rather the BUTTONs have been put in place, because the submenu has not moved anything.
Thanks to all
Rafael Pérez
