¿Qué significa (b)?
Posted: Thu Jul 19, 2012 7:15 am
by arroya2
Hola amigos.
Tengo una curiosidad: Al ejecutar una aplicación y surge un error, en la ventana de información del error, aparece donde se ha producido el error.
¿Qué significa la '(b)' que aparece en algunas líneas?
Rafael Pérez
Hello friends.
I have a curiosity: When running an application and an error occurs, the error information window appears where the error occurred.
What does '(b)' which appears in some lines?
Rafael Pérez
Re: ¿Qué significa (b)?
Posted: Thu Jul 19, 2012 7:37 am
May be 'B'ranched from?
Posted: Thu Jul 19, 2012 8:22 am
"branched from a code block."
Clipper Reference Guide wrote: If the activation being queried is a code block evaluation, PROCNAME()
returns the name of the procedure or user-defined function that defined
the code block, preceded by "b".
Regards.
Posted: Fri Jul 20, 2012 12:12 pm
by arroya2
Supposed to be that, but now I'm sure.
Thank you very much to all.
Rafael Perez
