inputbox
t57042
Inputbox
Post by t57042 »
Why does inputbox not work without MAIN WINDOW??
(Messageinfo and msgyesno do)
Richard
Carlos Britos
Re: inputbox
Post by Carlos Britos »
t57042 wrote:Why does inputbox not work without MAIN WINDOW??
Richard
Hi
AFAIK is because inputbox is a HMG window, any Hmg window need the Main window, the msg*() are api functions.
Carlos
Re: inputbox
Richard
Richard :
what is your need for Inputbox before creating the main window?
Use Inputbox from WinAPI : http://www.codeproject.com/Articles/242 ... ing-WinAPI
Inputbox
danielmaximiliano wrote:Use Inputbox from WinAPI: http://www.codeproject.com/Articles/242 ... ing-WinAPI
Nice one, Daniel ! :D
Re: inputbox
Richard
Richard :
Re: inputbox
Hi Richard,
You can also simulate InputBox start with, if you do a trick, you do give very small MAIN window after your MsgInfo, big do!
Espro serve you!
Function main()
	DEFINE WINDOW Form_1 ;
		WIDTH 1 ;         //640,480
		HEIGHT 1 ;
		TITLE 'InputBox Demo' ;
		MAIN ;
		ON INIT (MsgInfo("Hola"),Form_1.WIDTH := 640, Form_1.HEIGHT:=480)
		@ 50 ,100 BUTTON Button_1 ;
			CAPTION "InputBox Test" ;
			ACTION CLick() ;
	                WIDTH 200 ;
			HEIGHT 30
		@ 100 ,100 BUTTON Button_2 ;
			CAPTION "InputBox (Timeout) Test" ;
			ACTION TCLick() ;
	                WIDTH 200 ;
			HEIGHT 30
		@ 150 ,100 BUTTON Button_3 ;
			CAPTION "InputBox (Timeout) Test 2" ;
			ACTION TCLick2() ;
	                WIDTH 200 ;
			HEIGHT 30
	ACTIVATE WINDOW Form_1
Procedure Click
	MsgInfo ( InputBox ( 'Enter text' , 'InputBox Demo' , 'Default Value' )	)
Procedure TClick
	MsgInfo ( InputBox ( 'Enter text' , 'InputBox Demo' , 'Default Value' , 5000 ) )
Procedure TClick2
	MsgInfo ( InputBox ( 'Enter text' , 'InputBox Demo' , 'Default Value' , 5000 , 'Timeout Value' ) )
Re: inputbox
See this code:
Function Main()
   SET WINDOW MAIN OFF
      InputBox()
      _HMG_SYSDATA [ 271 ] := .F.   // _HMG_IsModalActive, InputBox() is a modal Window
   SET WINDOW MAIN ON
Inputbox
Yeah !
I forgot this great detail ! :oops:
Function Main()
Local cTest:=""
SET WINDOW MAIN OFF
    cTest := InputBox ( "Type your name: ", "HMG InputBox Demo without Main Form", cTest )
SET WINDOW MAIN ON
MsgInfo(cTest)
Very simple and functional !
Thank you Dr. Claudio fo reminding us ! :D
Inputbox
Javier Tovar wrote:You can also simulate InputBox start with, if you do a trick, you do give very small MAIN window
Thank you Javier for your example.
But instead of doing this:
I would HIDE the main form. ;)
But for sure, SET WINDOW MAIN OFF/ON it's the best option. :D
It's good to have it on mind.
B.Rgds
Re: inputbox
srvet_claudio wrote:See this code:
Function Main()
   SET WINDOW MAIN OFF
      InputBox()
   SET WINDOW MAIN ON
Nice
