Draw text and Draw Line in Window
spelman
Post by spelman »
Hi Everyone,
I wonder if someone could give me some help ...
I've been using the DRAW LINE IN WINDOW , and DRAW TEXT IN WINDOW commands.
My question is how to erase a line once drawn ? , or for that matter
text ...
I have looked in the example programs , but not really found anything
Kind regards,
Steve
Re: Draw text and Draw Line in Window
You can erase the whole window.
If you want to eliminate any one or some of the drawn object(s), you have to remove the stack of draw commands.
Actually whatever graph commands we issue are added to a system variable _HMG_SYSDATA [ 102 ] (i being the window index which can be got from getformindex( windowname ). Using a small hack you can remove whatever command you added.
So, if you want to remove the first draw command from the stack, just use,
adel( _HMG_SYSDATA [ 102 ] [i], 1 )
asize( _HMG_SYSDATA [ 102 ] [i], len( _HMG_SYSDATA [ 102 ] [i] ) - 1 )
And, when the window is re-painted, the command removed will not be used.
spelman
Post by spelman »
Hi Rathi,
Thanks for the response.
It looks a bit more complicated than I thought. It sounds easier to erase the window and redraw all the elements.
When you say 'erase the window', do you mean destroy it , or is there a command to just clear the contents of the window?
Please forgive my ignorance of these windows programming issues , my experience comes from some years ago in
in the DOS field. BTW , is there a good free primer anywhere which explains the basics of what should and shouldn't be
done when programming in Windows. I've been having quite a bit of success using HMG and just bumbling along seeing what
works, but I get the feeling I could be missing some key concepts.
Thanks
Steve
Hi Steve,
There is a command just to erase all the draw commands. You can find out from i_graph.ch file in c:\hmg\include folder.
IMHO 'Samples' folder is the best resource to know about window programming.
spelman
Post by spelman »
Hi Rathi,
Thanks , I'll look at that file.
Kind regards,
Steve
spelman wrote:...
Hi Steve
Welcome aboard :)
Sorry for the late welcome :(
Regards from Turkiye :)
BTW, are you sure that you are using DRAW TEXT command with HMG (official ) ?
If so, could you please give a small (but working) example ?
IMATECH
Post by IMATECH »
file:///C:/HMG/DOC/data/index.htm
DRAW / ERASE / PRINT GRAPH
Drawing Commands
DRAW GRAPH ...
DRAW GRAPH IN WINDOW <window> ...
DRAW LINE IN WINDOW <WindowName> AT <nRow>,<nCol> ...
DRAW RECTANGLE IN WINDOW <WindowName> AT <nRow>,<nCol> ...
ERASE [ IN ] WINDOW <WindowName>
PRINT GRAPH [ OF ] <cWindowname> [ PREVIEW ] [ DIALOG ]
'Print Graph' command, prints BARS, POINTS, LINES or PIE graph
previously drawn using DRAW GRAPH command in the specified window.
M., Ronaldo
By: IMATECH
Imation Tecnologia
spelman wrote:... how to erase a line once drawn ?
Hi Steve
#define nMaxPenWidth 10
PROCEDURE Main()
   aWinBackColor := { 0xF0, 0xF0, 0xF0 }
   lDrawn  := .F.
   aColorS := { YELLOW	,;
                PINK		,;
                RED		,;
                FUCHSIA	,;
                BROWN	,;
                ORANGE	,;
                GREEN	,;
                PURPLE	,;
                BLACK	,;
                WHITE	,;
                GRAY		,;
                BLUE		}
   nLineBRow := 0
   nLineBCol := 0
   nLineERow := 0
   nLineECol := 0
   nLinePenW := 0
   nLineColr := 0
   DEFINE WINDOW frmEraseLine ;
      AT 138 , 235 ;
      WIDTH  560 ;
      HEIGHT 380 ;   //  BACKCOLOR GRAY ;
      TITLE "Erasing drawn line" ;
      MAIN ;
      BACKCOLOR aWinBackColor ;
      ON INIT Initialize()
      ON KEY ESCAPE    ACTION frmEraseLine.Release
      @ 280, 100 BUTTON btnDraw CAPTION "&Draw"  ACTION Draw1Line( .T. )
      @ 280, 230 BUTTON btnEras CAPTION "&Erase" ACTION Draw1Line( .F. )
      @ 280, 360 BUTTON btnExit CAPTION "E&xit"  ACTION frmEraseLine.Release
   END WINDOW // frmEraseLine
   frmEraseLine.Center
   frmEraseLine.Activate
RETURN // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._
PROCEDURE Initialize()
   frmEraseLine.btnEras.Enabled := .F.
RETURN // Initialize()
PROCEDURE Draw1Line( ;
                    lDrawLine )  // .T. : DRAW, .F. : ERASE
   LOCAL nOldColor := nLineColr
   IF lDrawLine
      nLineBRow := HB_RandomInt( 0, frmEraseLine.WIDTH / 2 )
      nLineBCol := HB_RandomInt( 0, frmEraseLine.HEIGHT / 2  )
      nLineERow := HB_RandomInt( nLineBRow , frmEraseLine.WIDTH  )
      nLineECol := HB_RandomInt( nLineBCol, frmEraseLine.HEIGHT  )
      nLinePenW := HB_RandomInt( 1, nMaxPenWidth )
      WHILE nOldColor = nLineColr
         nLineColr := HB_RandomInt( 1, LEN( aColorS ) )
      ENDDO
      DRAW LINE IN WINDOW frmEraseLine  AT nLineBRow, nLineBCol ;
                                 TO nLineERow, nLineECol ;
                                 PENCOLOR aColorS[ nLineColr ] ;
                                 PENWIDTH nLinePenW
      lDrawn := .T.
                                 PENCOLOR aWinBackColor  ;
                                 PENWIDTH nLinePenW
      RESTORE WINDOW frmEraseLine
      lDrawn := .F.
   ENDIF lDrawLine
   frmEraseLine.btnDraw.Enabled := !lDrawn
   frmEraseLine.btnEras.Enabled := lDrawn
RETURN // Draw1Line()
I hope that help you :)
Well ...
No anyone responded :(
Does that means no anyone liked it :?:
May be ... A tool is valuable as much as need for it.
A little modification made: ErasLine() became a separate procedure.
Enjoy !
ErasLine.zip
Erase Line .prg & .hbp
(1.07 KiB) Downloaded 385 times
That's great! Thanks Esgici.
