About CDOSYS (Collaboration Data Objects) and attachments
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi to all :) ,
I tested the sample code posted by Daniel Maximiliano using Collaboration Data Objects
and really it worked fine to sending only email without attachments.
viewtopic.php?f=5&t=1518&p=20113#p20113
Anybody knows how to get CDO working properly with attachments ??
TIA,
[]´s Salamandra
Re: About CDOSYS (Collaboration Data Objects) and attachment
Hi / Hola Salamandra :
CdoSys tiene como enviar un archivo adjunto , eh intentado activar dicha funcion pero me da error, estoy investigando cual es la falla,apenas lo resuelva subo la modificacion.
Translate Google
CdoSys is to send an attachment, eh tried to activate this function but I get error, I am researching which is the fault, just upload the modified work it out.
      loMsg := CREATEOBJECT ( "CDO.Message" )
      WITH OBJECT loMsg
         :Configuration := loCfg
         :From          := Main.cFrom.Value
         :To            := Main.cTo.Value    // <-----       Coloca aqui  tu direcci¢n de correo
         :Subject       := "Prueba con DO"
         :TextBody      := Main.Contenido.Value
         :AddAttachment := "c:\Main.prg"         /*** Lineas a agregar ****/
         :Send()
      ENDWITH
Nota sobre archivos adjuntos : si se desea enviar varios archivos en el mismo mensaje , se debe ejecutar el método para cada archivo, por ejemplo :
CDO.AddAttachment (Adjunto 1)
CDO.AddAttachment (Adjunto 2)
CDO.AddAttachment (Adjunto 3)
... resto de código
Translate Google
ya encontre la solucion
      WITH OBJECT loMsg
         :AddAttachment("c:\Main.prg")
         :Send()
      ENDWITH
if you need more upload attachments / si se necesitan cargar mas adjuntos
  :AddAttachment("c:\Main.prg","file2","file3",more,,)
or
 :AddAttachment("File2")
salamandra
Hi Daniel :) ,
Thanks you for your reply.
I´ll try this way and post result here.
[]´s Salamandra
salamandra
Hi Daniel :) ,
Tested the following code and it worked fine :P
WITH OBJECT loMsg
	:Subject       := "e-Mail test using <<< CDOSYS (Collaboration Data Objects) >>>"
	For k:=1 to Main.archivos.ItemCount
		:AddAttachment(Main.archivos.Item(k))
	Next k
	:Send()
ENDWITH
Thanks again for your help :D
[]´s Salamandra
