Error in modifying the color of the main menu
jairpinho
Post by jairpinho »
I'm not getting in hmg change the color of the menu following example
        Load Window Main
        Main.Center
        Main.Activate
Func CMenu()
 Local hMenu    := _GetMenuId(GetFormHandle("MAIN"))
 Local aColor   := {255,255,255}
 Local lSubMenu := .F.
 _ColorMenu(GetFormHandle("MAIN"),aColor, lSubMenu)
#pragma BEGINDUMP
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#include "hbvm.h"
#include "hbstack.h"
#include "hbapiitm.h"
#include "winreg.h"
#include "tchar.h"
HB_FUNC( _GETMENUID)
 hb_retnl((LONG)GetMenu((HWND)hb_parnl(1)));
HB_FUNC ( _COLORMENU )
HMENU iMenu;
MENUINFO iMenuInfo ;
COLORREF lColor = {255,255,255};
BOOL lSubMenu = hb_parl(3);
iMenu = GetMenu((HWND) hb_parnl(1));
GetMenuInfo(iMenu, &iMenuInfo);
iMenuInfo.cbSize = sizeof(MENUINFO);
iMenuInfo.hbrBack = CreateSolidBrush(lColor);
SetMenuInfo(iMenu, &iMenuInfo);
if (lSubMenu)
   iMenuInfo.fMask    = MIM_BACKGROUND | MIM_APPLYTOSUBMENUS ;
   iMenuInfo.fMask    = MIM_BACKGROUND;
HB_FUNC ( _COLORSUBMENU )
HMENU      iMenu;
iMenuInfo.fMask    = MIM_BACKGROUND | MIM_APPLYTOSUBMENUS;
iMenuInfo.hbrBack  = CreateSolidBrush(RGB(hb_parni(2,1),hb_parni(2,2),hb_parni(2,3)));
DrawMenuBar((HWND) hb_parnl(1));
#pragma ENDDUMP
error build.log
hbmk2: Harbour: Compilando m¢dulos...
Harbour 3.0.0 (Rev. 16951)
Copyright (c) 1999-2011, http://harbour-project.org/
hbmk2: Compilando...
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg: In function 'HB_FUN__COLORMENU':
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:42:1: warning: excess elements in scalar initializer
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:42:1: warning: (near initialization for 'lColor')
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:59:25: error: 'MIM_BACKGROUND' undeclared (first use in this function)
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:59:25: note: each undeclared identifier is reported only once for each function it appears in
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:59:42: error: 'MIM_APPLYTOSUBMENUS' undeclared (first use in this function)
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg: In function 'HB_FUN__COLORSUBMENU':
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:82:22: error: 'MIM_BACKGROUND' undeclared (first use in this function)
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:82:39: error: 'MIM_APPLYTOSUBMENUS' undeclared (first use in this function)
K:\@Prog-Xbase\HMG-3038\Projetos\HMGFORUM\Menucolor\main.prg:83:1: error: too many arguments to function 'hb_parni'
C:/HMG3.0.38/harbour/include/hbapi.h:637:31: note: declared here
hbmk2: Erro: Executando compilador C/C++. 1
gcc.exe -c -O3 -march=i586 -mtune=pentiumpro -fomit-frame-pointer -W -Wall -pipe -IC:/HMG3.0.38/harbour/include -I../../.. -IC:/HMG3.0.38/include ../../../.hbmk/win/mingw/main.c
[u]Moderator Notes[/u] (Pablo César) wrote:Topic moved from Forum en Español.
COLOR_MENU-OK.zip
(429.52 KiB) Downloaded 763 times
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: Error in modifying the color of the main menu
Ola Jair :
MenuColor só existe em MiniGUI, olhar para o novo exemplo
Espero que ajude.
C:\MiniGUI\SAMPLES\Advanced\MenuEx\demo.exe
Function GetMenuColors() está em
C:\MiniGUI\SOURCE\c_menu.c
IsExtendedMenuStyleActive() no i_menu.ch
#translate IsExtendedMenuStyleActive () => _NewMenuStyle ()
_NewMenuStyle () No C:\MiniGUI\SOURCE\c_menu.c
HB_FUNC( _NEWMENUSTYLE )
   if( HB_ISLOG(1) )
      newStyle = hb_parl(1);
   hb_retl( newStyle );
Carlos Britos
Post by Carlos Britos »
jairpinho wrote:I'm not getting in hmg change the color of the menu following example
Hi, try this, it's working for me.
#define MIM_BACKGROUND              0x00000002
#define MIM_APPLYTOSUBMENUS         0x80000000
HB_FUNC ( MENU_BACKCOLOR )
   PHB_ITEM pSelf = hb_param( 0, HB_IT_OBJECT );
   HMENU hMenu = (HMENU) ObjGetNL( pSelf, "NHANDLEMENU" );
   HWND hPadre = (HWND)ObjGetNL( ObjGetObject( pSelf, "OPADRE" ), "HANDLE" );
   LONG       nColor ;
   // si es un solo param es el color
   if( HB_ISNIL(2) )
      nColor = (LONG) hb_parnl(1) ;
   // si son 2 params el priemro es el numero del submenu, el segundo es el color
      hMenu = GetSubMenu( hMenu, hb_parni(1) -1 );
      nColor = (LONG) hb_parnl(2) ;
   GetMenuInfo( hMenu, &iMenuInfo );
   iMenuInfo.hbrBack  = CreateSolidBrush( nColor );
   SetMenuInfo( hMenu, &iMenuInfo );
   DrawMenuBar( (HWND) hPadre );
Carlos Britos, when I compile in HMG your code C is presenting errors:
undefined reference to ObjGetNL and ObjGetObject
Probably functions are missing...
Pablo César wrote:Carlos Britos, when I compile in HMG your code C is presenting errors:
Ola Carlos:
você pode postar um exemplo, muitos ajudá-los.
Hola Carlos :
puede Ud publicar un ejemplo , a muchos les serviria.
Hi Carlos:
can you post an example, many would help them.
Carlos Britos
Hi.
Sorry, my fault, the above code is part of a class.
The below code compile ok with hmgee and I think is the same for hmg.
#include "minigui.ch"
Function main()
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 200 ;
		TITLE 'Menu Test' ;
		MAIN
		DEFINE MAIN MENU
			POPUP 'File'
				ITEM 'Open' 		ACTION MsgInfo ('File:Open') IMAGE 'Check.Bmp'
				ITEM 'Save' 		ACTION MsgInfo ('File:Save') IMAGE 'Free.Bmp' DISABLED
				ITEM 'Print' 		ACTION MsgInfo ('File:Print') IMAGE 'Info.Bmp'
				ITEM 'Save As...' 	ACTION MsgInfo ('File:Save As') DISABLED
				ITEM 'HMG Version' 	ACTION MsgInfo (MiniGuiVersion())
				SEPARATOR
				ITEM 'Exit' 		ACTION Form_1.Release IMAGE 'Exit.Bmp'
			END POPUP
			POPUP 'Test'
				ITEM 'Item 1' 		ACTION MsgInfo ('Item 1')  name xxx
				ITEM 'Item 2' 		ACTION MsgInfo ('Item 2')
				POPUP 'Item 3' name test
					ITEM 'Item 3.1' 		ACTION MsgInfo ('Item 3.1') DISABLED
					ITEM 'Item 3.2' 		ACTION MsgInfo ('Item 3.2')
					POPUP 'Item 3.3'
						ITEM 'Item 3.3.1' 		ACTION MsgInfo ('Item 3.3.1')
						ITEM 'Item 3.3.2' 		ACTION MsgInfo ('Item 3.3.2')
						POPUP 'Item 3.3.3'
							ITEM 'Item 3.3.3.1' 		ACTION MsgInfo ('Item 3.3.3.1')
							ITEM 'Item 3.3.3.2' 		ACTION MsgInfo ('Item 3.3.3.2')
							ITEM 'Item 3.3.3.3' 		ACTION MsgInfo ('Item 3.3.3.3') DISABLED
							ITEM 'Item 3.3.3.4' 		ACTION MsgInfo ('Item 3.3.3.4') DISABLED
							ITEM 'Item 3.3.3.5' 		ACTION MsgInfo ('Item 3.3.3.5')
							ITEM 'Item 3.3.3.6' 		ACTION MsgInfo ('Item 3.3.3.6')
						END POPUP
						ITEM 'Item 3.3.4' 		ACTION MsgInfo ('Item 3.3.4') DISABLED
					END POPUP
				END POPUP
				ITEM 'Item 4' 		ACTION MsgInfo ('Item 4') DISABLED
			END POPUP
			POPUP 'Help'
				ITEM 'About' 		ACTION MsgInfo ('Help:ABout')
			END POPUP
		END MENU
		DEFINE CONTEXT MENU
			ITEM 'Item 2' 		ACTION MsgInfo ('Item 2') DISABLED
			SEPARATOR
			ITEM 'Item 3' 		ACTION MsgInfo ('Item 3')
		END MENU
  MENU_BACKCOLOR( GetFormHandle("Form_1"),{255,0,0}  )
  MENU_BACKCOLOR( GetFormHandle("Form_1"), 1 ,{0,255,255}  )
  MENU_BACKCOLOR( GetFormHandle("Form_1"), 2 ,{255,255,0}  )
  MENU_BACKCOLOR( GetFormHandle("Form_1"), 3 ,{255,0,255}  )
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
#pragma BEGINDUMP
#include "hbapi.h"
   LONG       nColor ;
   HMENU      hMenu = GetMenu((HWND) hb_parnl(1)); ;
   // si son 2 params el segundo es el color
   // two params. 1 = handle form, 2 = array color
   if( HB_ISNIL(3) )
      nColor = (LONG) RGB(hb_parvni(2,1),hb_parvni(2,2),hb_parvni(2,3)) ;
   // si son 3 params el segundo es el numero del submenu, el tercero es el color
   // three params. 1 = handle form, 2 = index position of subMenu, 3 = array color
      hMenu = GetSubMenu( hMenu, hb_parni(2) -1 );
      nColor = (LONG) RGB(hb_parvni(3,1),hb_parvni(3,2),hb_parvni(3,3)) ;
   GetMenuInfo( (HMENU) hMenu, &iMenuInfo );
#pragma ENDDUMP
Excelente Carlos:
Carlos Britos
danielmaximiliano wrote:Excelente Carlos:
falta la definicion dentro del BEGIN SEQUENCE
de :
y para compilar con hmg habria que sacar DISABLED del menu.
No puedo en este momento compilarlo con hmg como para probarlo.
Is missing the pragam BEGIN SEQUENCE:
the definition of:
To compile with HMG maybe you have to remove the comand DISABLED from menus
I can't compile with hgm in this moment, I don´t have the zip libs. :(
jairpinho
Post by jairpinho »
Muito obrigado Carlos Britos e Daniel me ajudaram muito consegui resolver atraves do exemplo do Carlos Britos
segue resultado
Thank you Carlos and Daniel Britos helped me manage to solve through the example of Carlos Britos
result follows
menu color 1
//#include "minigui.ch"
        Load Window Form_1
        Form_1.Center
        Form_1.Activate
Function teste()
cTeste := REPLICATE("0",100)
cTeste := STUFF(cTeste,3,1,"1")
msginfo(cTeste)
Func CMenu()
 Local hMenu    := _GetMenuId(GetFormHandle("Form_1"))
 Local aColor   := {255,255,0}
 Local lSubMenu := .t.
 _ColorMenu(GetFormHandle("Form_1"),aColor, lSubMenu,, "BLUSTONE.BMP")
Func ColorMenu()
 Local aColor   :=GetColor()
 Local aBr := GetControlHandle("ImgTest","Form_1")
 If aColor[1] = Nil
   MsgInfo(" No Selecciono Color ")
 Else
   _ColorMenu(GetFormHandle("Form_1"),aColor, lSubMenu, )
 EndIf
Func ImageMenu()
 Local aImage   := GetFile(	{ {'BITMAP','*.Bmp'} } , 'Abrir Archivos Bitmap' ,  , .f. , .t. )
 If Empty(aImage)
   MsgInfo(" No Selecciono Imagen ")
 Else
   _ColorMenu(GetFormHandle("Form_1"),, lSubMenu, aImage)
  SetProperty("Form_1","ImgTest","picture",aImage)
 EndIf
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbvm.h"
#include "winreg.h"
#include "tchar.h"
HMENU      iMenu;
//nRed   = hb_parvni(2,1);
//nGreen = hb_parvni(2,2);
//nBlue  = hb_parvni(2,3);
HWND  himage ;
himage = (HWND)LoadImage(0,hb_parc(4),IMAGE_BITMAP ,0,0,LR_LOADFROMFILE | LR_LOADMAP3DCOLORS | LR_LOADTRANSPARENT );
if (himage==NULL)
	himage = (HWND)LoadImage(GetModuleHandle(NULL),hb_parc(4),IMAGE_BITMAP ,0,0, LR_LOADMAP3DCOLORS	| LR_LOADTRANSPARENT );
if (lSubMenu)
if (himage==NULL)
    //iMenuInfo.hbrBack = CreateSolidBrush(RGB(nRed, nGreen, nBlue));
	iMenuInfo.hbrBack = CreateSolidBrush(RGB(hb_parvni(2,1),hb_parvni(2,2),hb_parvni(2,3)));
    iMenuInfo.hbrBack = CreatePatternBrush(himage);
HMENU      iMenu;
#pragma ENDDUMP
Menu color 2
        Load Window Form_1
			//MENU_BACKCOLOR( GetFormHandle("Form_1"), 2 ,{255,255,0}  )
			//MENU_BACKCOLOR( GetFormHandle("Form_1"), 3 ,{255,0,255}  )
        Form_1.Center
        Form_1.Activate
#pragma BEGINDUMP
#include "hbapi.h"
   LONG       nColor ;
   if( HB_ISNIL(3) )
#pragma ENDDUMP
Jair Pinho
Wow! Very nice implementation.
Can we change the color of an individual menu item alone? (Like 'red' color for File->Delete)
