how to post messages using programming in "C"
jairpinho
Post by jairpinho »
how to send messages using programming in "C" in my program done in HMG following example:
#PRAGMA BEGINDUMP
#include "hbapi.h"
#include <stdio.h>
HB_FUNC( teste )
int x = 10;
int y = 10;
printf("result x %d", x )
#PRAGMA ENDDUMP
[u]Moderator Notes[/u] (Pablo César) wrote:Topic moved from Forum en Español.
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: how to send messages using programming in "C"
What kind of message do you want to send?
Via e-mail, network to another station?
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Jair :) ,
Please take a look at the following folders:
1) To send data between 02 apps.
C:\hmg.3.0.xx\SAMPLES\COMM.01
C:\hmg.3.0.xx\SAMPLES\COMM.02
2) A Messenger like app:
C:\hmg.3.0.xx\SAMPLES\HMGTALK.
[]´s Salamandra
jairpinho
Post by jairpinho »
expressed myself wrong, I want to see done in post code in "C" equals msginfo () HMG
HB_FUNC( teste )
int x = 10;
int y = 10;
printf("result x %d", x ) && - >>>>> does not work
Jair Pinho
Re: how to post messages using programming in "C"
Jair, lembre que você está colocando uma função em C que exibe em modo console.
Experimente assim:
Jair, remember that you are putting a C function that displays in console mode.
Try this:
REQUEST HB_GT_WIN_DEFAULT
Function Main()
SetMode(25,80)
cls
@ 00,00 to 24,79 double
teste()
inkey(0)
#PRAGMA BEGINDUMP
#include "hbapi.h"
#include <stdio.h>
HB_FUNC( TESTE )
int x = 10;
int y = 10;
printf("resultado: x + y = %d", x+y ) ;
#PRAGMA ENDDUMP
jairpinho
Post by jairpinho »
EN
Yes I understand but do not have as vilsualizar in a command prompt window in console mode need to debug the code in C and the only way to know what it's doing my code would be send via printf () or accept another command that in HMG
PT-BR
sim eu entendo mas não tem como vilsualizar em uma janela de prompt em modo console preciso depurar o codigo em C e a unica maneira de saber o que esta fazendo o meu codigo seria enviar via printf() ou outro comando que aceite em HMG
Jair Pinho
Veja agora, compile o código fonte que tinha postado.
See now, please compile my source code posted before.
jairpinho
Post by jairpinho »
não funcionou
not work
Pablo César wrote:Veja agora, compile o código fonte que tinha postado.
Jair Pinho
For me it is working ! See attached files, you can execute .exe
CCode.rar
(374.52 KiB) Downloaded 661 times
jairpinho
Post by jairpinho »
HMG in 3.0.xx IDE does not perform the function
Pablo César wrote:For me it is working ! See attached files, you can execute .exe
Jair Pinho
