create menu at runtime with HMG
jairpinho
Post by jairpinho »
need to create menu at runtime with HMG using dbf mysql or if someone has an example of how to do this with HMG please post an example
[u]Moderator Notes[/u] (Pablo César) wrote:Topic moved from Forum en Español.
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: create menu at runtime with HMG
you can create it using code like this one:
		DEFINE MAIN MENU OF OknoGlowne
			DEFINE POPUP "Projektant przycisków"
				MENUITEM "Zapisz definicję przycisków" ACTION ZapiszDefinicjePrzyciskow()
				MENUITEM "Porzuć projektowanie" ACTION PorzucDefiniowaniePrzyciskow()
				MENUITEM "Przywróć domyślne definicje przycisków" ACTION DomyslnaDefinicjaPrzyciskowOknaGlownego()
			END POPUP
		END MENU
Once upon a time, I've created control ACHOICE, which was working link old achoice, you can search it on the forum...
Here it is:
viewtopic.php?f=5&t=1180&p=18241&hilit=achoice#p18241
jairpinho
Post by jairpinho »
these examples already noticed, which would really need a manager menu at runtime, which can create delete modify menus at runtime.
thanks for the help of all
Jair Pinho
tave2009
Post by tave2009 »
This is the file ... (Edmenu.prg)
try with this
Edmenu.zip
(11.92 KiB) Downloaded 744 times
jairpinho
Post by jairpinho »
not compiling from HMG IDE
hbmk2: Harbour: Compilando m¢dulos...
Harbour 3.0.0 (Rev. 16951)
Copyright (c) 1999-2011, http://harbour-project.org/
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(63) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(66) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(69) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(72) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(75) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(79) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(82) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(85) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(88) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(118) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(119) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(122) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(125) Error E0030 Syntax error "syntax error at '@'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(897) Error E0030 Syntax error "syntax error at ''"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(926) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(928) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(932) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(934) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(941) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(943) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(947) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg(949) Error E0030 Syntax error "syntax error at 'CM_CAPTION'"
22 errors
No code generated.
hbmk2: Erro: Executando o compilador Harbour (interno): 1
(C:\HMG3.0.38\harbour\bin\harbour.exe) -n2 K:\@Prog-Xbase\HMG-3038\Projetos\Edmenu\edmenu.prg -q -o.hbmk\win\mingw\ -iC:\HMG3.0.38\harbour\include -i. -iC:\HMG3.0.38\include
tave2009 wrote:This is the file ... (Edmenu.prg)
try with this
Jair Pinho
tave2009
Post by tave2009 »
Este software es para la HMG extendida tenes que adaptarlo
Pero ahora te adjunto el ejecutable para que pruebes.
Slds.
Walter
edmenu.zip
(591.49 KiB) Downloaded 738 times
tave2009 wrote:... tenes que adaptarlo...
Walter
Adapted.
Regards / saludos.
EdMenu&Demo.zip
EdMenu.prg & Demo.prg
(8.86 KiB) Downloaded 796 times
tave2009
Post by tave2009 »
Español:
Gracias Esgici,
Me asombra tu rapidez.
Walter
Inglés (Google)
Thanks Esgici,
It amazes me your speed.
Walter
jairpinho
Post by jairpinho »
this was what I wanted in HMG, THANK ESGICI and tave2009
Walter
Adapted.
Regards / saludos.
EdMenu&Demo.zip
Jair Pinho
