update the image object with a null value or empty
jairpinho
Post by jairpinho »
update the image object with a null value after a set image in an image object can not just clean the obejto
example:
main.image_1.picture := "c:\teste.jpg"
main.image_1.picture := "" && -> does not work
[u]Moderator Notes[/u] (Pablo César) wrote:Topic moved from Forum en Español.
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: update the image object with a null value or empty
If you don't want to show it you can either use hide() method or visible := .f.
If you don't want to keep the image or change the image, you can release() and then define again when required.
jairpinho
Post by jairpinho »
Thank Rathi worked
Jair Pinho
