Hi guys!
I need to enable/disable editing and changing controls depending on user rights.
Is it possible to realize it?
Marek
How to set all controls to ReadOnly state?
Re: How to set all controls to ReadOnly state?
Hello Marek,mol wrote:Hi guys!
It is possible if you have the list of all controls on your form(s).
Please take a look for the following simple sample:
* http://sites.google.com/site/hmgweb/
DEFINE WINDOW Form_1 ;
WIDTH 600 HEIGHT 400 ;
TITLE "HMG Slider Demo" ;
MAIN ;
FONT "Arial" SIZE 10
// Horizontal
@ 20,20 SLIDER Slider_1 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Horizontal" ;
ON CHANGE {||Slider1_Change()}
@ 70,20 TEXTBOX TextBox_1 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 20,160 SLIDER Slider_2 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Horizontal Top" ;
ON CHANGE {||Slider2_Change()} ;
TOP
@ 70,160 TEXTBOX TextBox_2 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 20,300 SLIDER Slider_3 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Horizontal Both" ;
ON CHANGE {||Slider3_Change()} ;
BOTH
@ 70,300 TEXTBOX TextBox_3 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 20,440 SLIDER Slider_4 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Horizontal NoTicks" ;
ON CHANGE {||Slider4_Change()} ;
NOTICKS
@ 70,440 TEXTBOX TextBox_4 VALUE " 5" WIDTH 60 MAXLENGTH 5
// Vertical
@ 150,20 SLIDER Slider_5 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Vertical" ;
VERTICAL ;
ON CHANGE {||Slider5_Change()}
@ 280,20 TEXTBOX TextBox_5 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 150,160 SLIDER Slider_6 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Vertical Left" ;
VERTICAL ;
ON CHANGE {||Slider6_Change()} ;
LEFT
@ 280,160 TEXTBOX TextBox_6 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 150,300 SLIDER Slider_7 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Vertical Both" ;
VERTICAL ;
ON CHANGE {||Slider7_Change()} ;
BOTH
@ 280,300 TEXTBOX TextBox_7 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 150,440 SLIDER Slider_8 ;
RANGE 1,10 ;
VALUE 5 ;
TOOLTIP "Slider Vertical NoTicks" ;
VERTICAL ;
ON CHANGE {||Slider8_Change()} ;
NOTICKS
@ 280,440 TEXTBOX TextBox_8 VALUE " 5" WIDTH 60 MAXLENGTH 5
@ 320,20 BUTTON Btn_8 CAPTION "DISABLE ALL SLIDERS" WIDTH 160 ACTION Sliders_Disable( 'Form_1' )
@ 320,200 BUTTON Btn_9 CAPTION "ENABLE ALL SLIDERS" WIDTH 160 ACTION Sliders_Enable( 'Form_1' )
Form_1.TextBox_1.Enabled := .f.
Form_1.TextBox_2.Enabled := .f.
Form_1.TextBox_3.Enabled := .f.
Form_1.TextBox_4.Enabled := .f.
Form_1.TextBox_5.Enabled := .f.
Form_1.TextBox_6.Enabled := .f.
Form_1.TextBox_7.Enabled := .f.
Form_1.TextBox_8.Enabled := .f.
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
Function Sliders_Disable( cForm )
aeval( _GetArrayOfAllControlsForForm( cForm ), {|x,i| iif("Slider_" $ x, SetProperty( cForm, x, "Enabled", .f. ), ) } )
Function Sliders_Enable( cForm )
aeval( _GetArrayOfAllControlsForForm( cForm ), {|x,i| iif("Slider_" $ x, SetProperty( cForm, x, "Enabled", .t. ), ) } )
Function Slider1_Change
Local nValue := Form_1.Slider_1.Value
Form_1.TextBox_1.Value := Str(nValue,2)
Function Slider2_Change
Local nValue := Form_1.Slider_2.Value
Form_1.TextBox_2.Value := Str(nValue,2)
Function Slider3_Change
Local nValue := Form_1.Slider_3.Value
Form_1.TextBox_3.Value := Str(nValue,2)
Function Slider4_Change
Local nValue := Form_1.Slider_4.Value
Form_1.TextBox_4.Value := Str(nValue,2)
Function Slider5_Change
Local nValue := Form_1.Slider_5.Value
Form_1.TextBox_5.Value := Str(nValue,2)
Function Slider6_Change
Local nValue := Form_1.Slider_6.Value
Form_1.TextBox_6.Value := Str(nValue,2)
Function Slider7_Change
Local nValue := Form_1.Slider_7.Value
Form_1.TextBox_7.Value := Str(nValue,2)
Function Slider8_Change
Local nValue := Form_1.Slider_8.Value
Form_1.TextBox_8.Value := Str(nValue,2)
Function _GetArrayOfAllControlsForForm ( cFormName )
Local nFormHandle , i , nControlCount , aRetVal := {} , x
nFormHandle := GetFormHandle ( cFormName )
nControlCount := Len ( _HMG_SYSDATA [3] )
For i := 1 To nControlCount
If _HMG_SYSDATA [4] [i] == nFormHandle
If ValType( _HMG_SYSDATA [3] [i] ) == 'N'
IF ! Empty( _HMG_SYSDATA [2] [i] )
If Ascan( aRetVal, _HMG_SYSDATA [2] [i] ) == 0
Aadd( aRetVal, _HMG_SYSDATA [2] [i] )
EndIf
ElseIf ValType( _HMG_SYSDATA [3] [i] ) == 'A'
For x := 1 To Len ( _HMG_SYSDATA [3] [i] )
IF !Empty( _HMG_SYSDATA [2] [i] )
EndIf
Next x
EndIf
EndIf
Next i
Return Asort( aRetVal )Kind Regards,
