Hmg 3.0.40 Build Problem
Posted: Mon Feb 20, 2012 7:17 am
by jayadevu
I have downloaded hmg.3.0.40 and installed in d:\hmg folder. When I compile any application, I get the following error:
D:\hmg\\mingw\bin\nm.exe: 'C:/DOCUME~1/jayadev/LOCALS~1/Temp/hbmk_g9opx9.dir/.c': No such file
Even If I correct the path in build.bat to d:\hmg, thereby removing the \\ in the above path, the error continues. Do I have to install some other tool Also ?
What seems to be the mistake :-(
Warm regards,
Jayadev
Re: Hmg 3.0.40 Build Problem
Posted: Mon Feb 20, 2012 10:36 am
by mol
jayadevu wrote:hbmk_g9opx9.dir/.c': No such file
Jayadev
Problem lays in empty name generated while building, I think
Posted: Mon Feb 20, 2012 1:28 pm
Hi jayadevu:
It happens when compiling with the IDE HMG???
in this case, delete HMG.INI within the folder
c:\hmg.3.0.40\IDE
or modify HMG.INI to make it look so
d:\hmg.3.0.40\IDE
or try to compile from Windows Console?
Administrador Cwindowssystem32cmd.png (24.45 KiB) Viewed 1941 times
in my case I have slightly edited MyBuild.bat
Posted: Mon Feb 20, 2012 3:13 pm
HI:
MyBuild.bat
@echo off
cls
Title New HMG -- Build.bat --
SET HMGPATH=c:\HMG.3.0.40\
SET Backup=%PATH%
@echo
if "%1"=="" goto Input
if not EXIST %1 Goto Noexist
:Build
@Echo Compiling %*
call %HMGPATH%build.bat %*
@echo.
goto Finish
:Noexist
echo  El archivo %1  no existe,  revise el nombre
@echo
Goto Finish
:Input
SET HMGPATH=e:\hmg.3.0.40\
Color 04
@echo ********************************************************************************
@echo  This batch passes information to compile hbmk2 for easy and clean
@echo  is distributed as is and does not guarantee error-free
@echo  if you find one you can write danielmaximiliano@yahoo.com.ar
@echo  Based on a distributed Build.bat HMG Roberto Lopez Project
@echo.
@echo Enter the name of the project to compile, assumes the extension .HBP if it exists
@echo in the project folder , but will compile the file .PRG
@echo.
@echo "<Enter>" Batch leaves
@echo.
color 07
Set /p Filename=Name of Application:=
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
if {%Filename%}=={} goto :Finish
if EXIST %Filename%.hbp (Set Extension=.hbp&&Goto Enterparameters)
if EXIST %Filename%.prg (Set Extension=.prg&&Goto Enterparameters)
goto Cleanvar
:EnterParameters
@echo  Extras parameters to compile %Filename%%extension%
@echo.
@echo                           /n	Do not run after compile
@echo                           /d	enable DEBUG
@echo                           /c	Mode D.O.S CONSOLE
@echo.
@echo Note: " With  <Enter> no parameter is passed"
@echo.
Set /p Parameter=Parameters :=
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
If "%Parameter%"== "" goto Continue
If /I "%Parameter%"=="/n" Goto Withparameters
If /I "%Parameter%"=="/d" Goto Withparameters
If /I "%Parameter%"=="/c" Goto Withparameters
cls
Goto EnterParameters
:Withparameters
@echo compiling with parameters
if EXIST %Filename%.hbp Goto HBPParameters
if EXIST %Filename%.prg Goto PRGParameters
goto Cleanvar
:HBPParameters
@Echo compiling %Filename%.hbp %Parameter%
call %HMGPATH%build.bat  %filename%.hbp %Parameter%
goto Cleanvar
:PRGParameters
Echo compiling %Filename%.PRG %Parameter%
call %HMGPATH%build.bat %filename%.prg %Parameter%
goto Cleanvar
:Continue
@echo no parameters compilation
:HBP
@Echo Compile %Filename%.hbp
goto Cleanvar
:PRG
@Echo Compile %Filename%.prg
goto Cleanvar
:CleanVar
@echo Cleaning variable´s
(SET HMGPATH=)
(SET Filename=)
(SET Parameter=)
Goto Input
:Finish
SET PATH=%Backup%;;%HMGPATH%\mingw\bin
set "bar="
set "percent=0"
set "count=0"
for /l %%i in (1,1,20) do set "bar=!bar!±"
:loop
set /p "= %bar:~0,20% %percent%%%"<nul
ping -n 1 -w 1 localhost>nul
for /l %%i in (1,1,26) do set /p "="<nul
set "bar=Û%bar%"
set /a "count+=1"
set /a "percent+=5"
if %count% leq 20 goto:loop
echo.
echo.
(SET HMGPATH=)
(SET Filename=)
(SET Parameter=)
(set bar=)
(set percent=)
(set count=)
Mybuild.rar
Idioma/Languaje
Español : Mibuild.bat
English : MyBuild.bat
(2.44 KiB) Downloaded 181 times
save the folder where your application to compile.
if you want to see how it works build.bat can edit, delete "-q" on line 102
from Windows Explorer, drag and drop your application on MyBuild.bat
or doubleclick on MyBuild.bat thus compile your application interactively.
only need to enter the name of your application, if any project is compiled it, but compile myaplication.prg
Posted: Tue Feb 21, 2012 6:10 am
by jayadevu
Dear DanielMaxmiliano,
Many thanks for your guidance and .bat file.
Warm regards,
Jayadev
