Hi all,
I was wondering if anyone has used the Advantage RDD with HMG.
I noticed that there are some functions in the Harbour library ( ADSSetAOF() Create an Advantage Optimized Filter for example )
but I can't find any examples, either on teh Harbour site, or in the samples directory as delivered.
I used something similar ( but it might have been the Comix RDD... ) when I was developing professionally some years ago
and found it very useful for creating database Filters which made full use of indexes.
I really just need it for flexible reporting , but as I remember , it also allows some very fast queries.
Thanks
Steve
Advantage RDD
Re: Advantage RDD
Hi Steve,spelman wrote:Hi all,
I don't use the Advantage RDD in my applications. But you may take a look for the working sample below:
* MINIGUI - Harbour Win32 GUI library
* Copyright 2002-2010 Roberto Lopez <harbourminigui@gmail.com>
* Demo of ADS Connection handling and Data Dictionaries
* Translate From xHarbour to Harbour MiniGui by Stefano Meli <stemeli@hotmail.com>
#include "minigui.ch"
#include "Ads.ch"
FUNCTION Main()
RddRegister( "ADS", 1 )
RddSetDefault("ADT")
AdsSetServerType ( 7 )
Set Filetype To ADT
DEFINE WINDOW Win_1 ;
WIDTH 640 ;
HEIGHT 480 ;
TITLE "Advantage Database Server RDD Demo" ;
MAIN ;
NOMAXIMIZE ;
NOMINIMIZE ;
ON INIT OpenTable() ;
ON RELEASE Closetable() ;
BACKCOLOR GRAY
DEFINE BROWSE Browse_1
ROW 10
COL 100
WIDTH 1093
HEIGHT 900
HEADERS {'ID', 'Name', 'Address', 'City', 'Age'}
WIDTHS { 210, 230, 210, 210, 210}
WORKAREA custom
FIELDS { 'custom->id','custom->name','custom->address','custom->city','custom->age' }
JUSTIFY { BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT , BROWSE_JTFY_LEFT , BROWSE_JTFY_LEFT}
TOOLTIP 'Advantage Database Server RDD Demo'
VALUE 1
FONTNAME 'VERDANA'
FONTSIZE 9
VISIBLE .f.
END BROWSE
DEFINE MAIN MENU OF Win_1
POPUP "&File"
ITEM "&Browse test" ACTION (Win_1.Browse_1.Visible := .t. , Win_1.Browse_1.setfocus)
SEPARATOR
ITEM "E&xit" ACTION Win_1.Release
END POPUP
POPUP 'Help'
ITEM 'About' ACTION MsgInfo ("MiniGUI ADS RDD Demo")
END POPUP
END MENU
DEFINE WINDOW Splash ;
AT 00,0 ;
WIDTH 500 HEIGHT 200 ;
TITLE '';
TOPMOST NOCAPTION ;
ON RELEASE Win_1.Maximize()
@ 55,45 LABEL Label_1 ;
WIDTH 400 HEIGHT 80 ;
VALUE PadC('Please Wait ',60) + CRLF + ;
PadC ('Now Create a Data dictionary ', 50) ;
FONT 'Arial' SIZE 16
Win_1.Browse_1.Hide
CENTER WINDOW Splash
CENTER WINDOW Win_1
ACTIVATE WINDOW Splash, Win_1
RETURN Nil
Procedure OpenTable()
local cErr
local aStru := {{ "ID", "A", 1, 0}, {"Name", "C", 50, 0}, {"address", "C", 50, 0}, {"city", "C", 30, 0}, {"Age", "n", 3, 0}}
local lIsDict := .f.
local n
local hConnection1
fErase("harbour.add")
fErase("harbour.ai")
fErase("harbour.am")
fErase("Table1.adt")
fErase("Table1.adi")
fErase("Table2.adt")
fErase("Table2.adi")
// now Create a Data dictionary and the files if not exist
IF !File("harbour.add")
ADSDDCREATE("harbour.add",, "harbour ADS demo for data dictionary")
// This also creates an Administrative Handle that is set as the default
// MsgInfo("Default connection is now this admin handle:" + STR(adsConnection()))
AdsDisconnect() // disconnect current default. If you wanted to retain this connection for later, you could use
// hAdminCon := adsConnection(0)
// This get/set call would return the current connection, then set it to 0
// MsgInfo("Default connection is now this handle (zero):" + STR(adsConnection()))
// now create two free tables with same structure
DbCreate("Table1", aStru)
DbCreate("Table2", aStru)
//now create an index
USE table1 new
INDEX ON id TAG codigo
USE
USE table2 new
USE
// now the magic
IF adsConnect60("harbour.add", 7/* All types of connection*/, "ADSSYS", "", , @hConnection1 )
// The connection handle to harbour.add is now stored in hConnection1,
// and this is now the default connection
// Add one user
AdsDDCreateUser(, "Luiz", "papael", "This is user Luiz")
// "Add the tables"
AdsDDaddTable("Table1", "table1.adt", "table1.adi")
IF ! AdsDDaddTable("Customer data", "table2.adt", "table2.adi")
// notice the "long table name" for file Table2.adt.
// Later open it with "Customer data" as the table name
MsgExclamation ("Error adding table:" + (adsGetLastError(@cErr))+ (cErr) )
MsgExclamation ("Error connecting to harbour.add!")
AdsDisconnect(hConnection1)
hConnection1 := nil // you should always reset a variable holding a handle that is no longer valid
AdsConnect60("harbour.add", 7/* All types of connection*/, "Luiz", "papael", , @hConnection1)
FOR n := 1 TO 100
IF AdsCreateSqlStatement("Data2", 3)
AdsExecuteSqlDirect(" insert into Table1( name,address,city,age) VALUES( '" + strzero(n)+"','"+strzero(n)+"','"+strzero(n)+"'," +str(n)+ ")" )
USE
FOR n := 1 TO 100
IF AdsCreateSqlStatement("Data1", 3)
AdsExecuteSqlDirect(" insert into " +'"Customer Data"'+"( name,address,city,age) VALUES( '"+ strzero(n)+"','"+strzero(n)+"','"+strzero(n)+"'," +str(n)+")" )
USE
Splash.Release
DbUseArea(.t.,, "Customer data", "custom", .t., .f.)
PROCEDURE CloseTable()
CLOSE ALL
RETURN NilKind Regards,
Re: Advantage RDD
Excellent - Thankyou for the fast reply Grigory
