Sample of usage of Browse()
CCH4CLIPPER
Post by CCH4CLIPPER »
Hi
I have tried to figure out how to use the Browse control in a form.
What I ahve done is to start a new project, add Boriwse control to the default window.
Problem is I can't figure out on how to add properties and events to get it to work :-(
What I need is a sample to get me started :-)
CCH
http://cch4clipper.blogspot.com
Re: Sample of usage of Browse()
CCH4CLIPPER wrote:Hi
Hello CCH,
Take a look for Building a BROWSE based HMG application generated by IDE at
http://vivaclipper.googlepages.com/ide_sample1_eng
I hope that helps. :idea:
CCH4CLIPPER
Hi
Yes, this helps tremendously !
BTW, how would like to do the same via hand-coding.
Following Esgici advice, I have discovered that one can be more productive via hand-coding :-)
Hello "Speedy" :D
Your speed prevent you to look around !
We have C:\hmg\SAMPLES\BROWSE_x ( x= 1..5 ) five directories and some of them include more than one browse*.prg (all hand coded).
In fact, HMG-IDE sample of browse is based upon one of them.
CCH4CLIPPER
Hi Escigi
Tx for poing me in the right direction
OK, I slow down, a little bit only :-)
BTW, you must remember that I have been using Delphi (probably the best RAD tool for Win32) for the last 12 years to build huge ERP/CRM Windows apps. So I need get to speed fast :-)
CCH
CCH4CLIPPER wrote:Hi Escigi
CCH
I don't have any intention for changing direction of anyone. Also I don't want withstanding to speed. I want only point dangers and probable damages of speed.
Sorry, I don't understand relation with using Delphi and getting to speed fast.
BTW, you don't think that everybody in here, are from out of programing world and begun to everything by zero; right?
CCH4CLIPPER
Hi Escigi
Great Browse() samples, still at Browse_1 and already I am having an insight (ie answers to unasked questions) into
a) Browses(), I am definitely going to change my dbedits() to Browses()
My Dbedit() usually support
F4- Append
F5- Horizontal Edit
F6 - Vertical Edit
F7 - Seek
F8 - Pack
Alt+B, dill down to another Master-Detail dbedit()
b) enhancements to Status Bar
c) Split Pages, etc
So, I am going to look forward to a major conversion exercise over the weekend :-)
CCH
I see that our forum was dominated by CCH...
I think you need to look at the samples first, then write to the forum.
mol wrote:I see that our forum was dominated by CCH...
Hi Mol
Reading documentations and "Looking at the samples first" is ok, I agreed.
But IMHO being dominated by someone is better than remaining motionless.
Also CCH is a very excited person and desire arriving his targets as fast as possible.
Do you have read all documents and analyzed / tested all samples ? Me, no.
Participating instead of criticize may be more friendly, I think.
Sorry, I didn't want to be so sharp, as it sounded...
It's good that are people, who respond patiently on every question.
Best regards, Marek
