[u]Moderator Notes[/u] (Pablo César) wrote:Topic moved from Forum en Español.
write a file type jpeg image in a field of a mysql table
Hello Guys need to write a file type jpeg image in a field of a mysql table and then have to view this image, what query should I use to do what I need.
Re: write a file type jpeg image in a field of a mysql table
There are two ways to achieve this.
1. Blob method:
Have a field as type blob.
buff := sqlite3_file_to_buff( "pngtest.png" )
This is to convert file into buffer.
For reverting back,
sqlite3_buff_to_file( "pngtest1.png", @buff )
This way you can store the image, directly into MySQL (like sqlite).
2. File method:
If your image database is very big, then it is advisable to have a separate directory for images and keep only the names of the image files in the database.
1. Blob method:
For reverting back,
2. File method:
Hi Rathi
Useful info, thanks
If I'm not wrong, M type of DBFNTX system too can hold binary large objects; like images etc
Does anyone know; is there a similar or equivalent of these file_to_buff() and buff_to_file() functions in Harbour ?
Useful info, thanks
There is a way to make some functions instead of mysql sqlite_3
I need to put the picture of an object image in buff
main.image_1.picture: = buff
rathinagiri wrote:There are two ways to achieve this.
1. Blob method:
For reverting back,
2. File method:
what type of field can use with this buff, blob / text / char / binary, I tried to write to a BLOB field and giving this error.
1. Blob method:
For reverting back,
2. File method:
Function tested with mysql and MariaDB works perfectly with images.
if anyone knows how to convert to harbor language and add Harbou as a function of the code is below.
Function File_To_Buff(cFile)
local cBuff:="", fh, nLen
local lRetVal:=.f.
local cFile_in := cFile
Write file 'Test.gif' to MySQL and MariaDB table 'test.blobtest.blobfield'
fh:=fopen(cFile_in,0)
if fh > -1
// determine length of file
nLen := fseek(fh, 0, 2)
if nLen > 0
//move file pointer back to begin of file
fseek(fh, 0, 0)
cBuff:=space(nLen)
fread(fh, @cBuff, nLen)
// escapes
cBuff:=strtran(cBuff, chr(92), "\\")
cBuff:=strtran(cBuff, chr(0), "\0")
cBuff:=strtran(cBuff, chr(39), "\'")
cBuff:=strtran(cBuff, chr(34), '\"')
Else
cBuff := "OFF"
fclose(fh)
Return(cBuff)
Function Buff_To_File(cBuff)
local fh, nLen
local lRetVal:=.f.
Local cFile_out := ""
Read Blobfield from MySQL and MariaDB table 'test.blobtest' and save it to file 'Test2.gif'
nNFile := INT(RANDOM()%999 +1)
cFile_out := "Foto" + Alltrim(STR(nNFile)) + ".tmp"
cDir_Temp := BaseDeDados("DIR23")
IF !File(cDir_Temp + cFile_out)
fh := fcreate(cDir_Temp + cFile_out,0)
IF fh>-1
nLen:=fwrite(fh, cBuff)
FCLOSE(fh)
IF nLen==len(cBuff)
// MsgInfo("File written back to "+ cFile_out)
RETURN(cDir_Temp+cFile_out)
I wanted to have a common function to convert a file into a SQL safe string and string into a file back.
Instead of re-inventing the wheel again, I decided to use the base64 encoding and decoding which is used in attaching the files in a mail.
So, here comes the functions:
I have checked in SQLite blob field for an image file and converted back the blob field content into a temporary image file. Everything works fine.
function file2str( cFileName )
local oEncoder := TIPEncoderBase64():New()
local hInput
local cData := ''
local cBuffer := Space( 1024 )
IF hb_FileExists( cFileName )
hInput := FOpen( cFileName )
nLen := FRead( hInput, @cBuffer, 1024 )
DO WHILE nLen > 0
IF nLen < 1024
cData += hb_BLeft( cBuffer, nLen )
cData += cBuffer
ENDDO
FClose( hInput )
cData := oEncoder:Encode( cData )
return cData
return cData
function str2file( cStr, cFileName )
local hOutput
cStr := oEncoder:Decode( cStr )
hOutput := FCreate( cFileName )
FWrite( hOutput, cStr )
FClose( hOutput )
return nil
