Global Setting for On Key
jayadevu
Post by jayadevu »
A Very Happy New Year to all.
In clipper programs, we could make a set key (say Alt+R) to some function in the main program and we could call this function from anywhere in the program by pressing the appropriate keys.
In HMG as I understand, we have to set the keys for each window seperately with the On Key command. Is it possible in HMG to give a Global On Key setting for all the windows instead of seperate definitions for each window ? Pls advice.
Warm regards,
Jayadev
Re: Global Setting for On Key
jayadevu wrote:Hi,
Hi Jayadev,
It is possible in the HMG Extended Edition with command
SET GLOBAL HOTKEYS ON
but there is a foreign effect from applying of this command that your hotkeys is available in another's applications also :o
Happy New Year :!:
jayadevu
Post by jayadevu »
Dear Mr. Filatov,
Many thanks for your immediate reply.
You mean other MiniGui Extended applications or all other window applications which are running.
Warm regards,
Jayadev
jayadevu wrote:...
Jayadev,
I means all other running window applications :shock:
It is a global action via your application's global hotkey (may be useful for tray-based utility).
