BROWSE AND QUICK SEARCH
I'm looking for the way to realize quick search function in browse or grid.
It should be easy to do this, by adding to browse or grid OnKeyPressed event with code of pressed key passed as parameter.
If operator press navigation keys, browse interprets it the same, but, if it's pressed antoher key (A, B or 1,2,3... etc.) pressed key should be passed as parameter to OnKeyPressed event..
How do you think?
Is it possible to achieve?
Best regards, Marek
Re: BROWSE AND QUICK SEARCH
Hi Mol
Please look at here ( QuickSearch.zip )
I hope that it will help you
Very nice examples Mr. Esgici. I have seem SFilBox also very good.
I do not know if your will find any example of keyboards events inside of browse control. I think all functionality in Gird/Browse in HMG is completly different than we have used like us in console mode or in Clipper. In MiniGui there are two favorites of mine in:
C:\MiniGUI\SAMPLES\BASIC\FastFind
C:\MiniGUI\SAMPLES\Advanced\MiniAgenda
Hi Pablo
Didn't noticed original author of MiniAgenda ?
If so, please look at here or here ;)
hahaha I really like very much this MiniAgenda. Congratullations worderfull job !
esgici wrote:Hi Mol
Hi Esgici!
Many thanks for this sample! I know it from the years and I'm using this way of incremental searching, but, a little modified.
But, In my intensions was to still get focus on grid or browse without moving to "Search Box"
claudiotedesco
Post by claudiotedesco »
Hi Esgici
Compile el ejemplo MAgendaB918 con HMG 3.0.35 y me da el siguiente error:
Cual es el problema?
Gracias
Claudio
hbmk2: Processing configuration: C:\hmg\harbour\bin\hbmk.cfg
hbmk2: Processing: MAgenda.hbc
hbmk2: Compiling Harbour sources...
Harbour 2.0.0 (Rev. 13372)
Copyright (c) 1999-2010, http://www.harbour-project.org/
hbmk2: Compiling...
hbmk2: Linking... MAgenda.exe
.hbmk\win\mingw\magenda.o:magenda.c:(.data+0x598): undefined reference to `HB_FUN(int13_t &, int0_t &)'
gcc.exe .hbmk\win\mingw\magenda.o .hbmk\win\mingw\_hbmkaut.o _temp.o -mwindows -Wl,--start-group -lhmg -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lpq -lhbtip -lhbct -lhbmisc -lhbnetio -lxhb -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oMAgenda.exe -LC:/hmg/harbour/lib -LC:/hmg//lib -LC:/hmg/SAMPLES/MAgendaB918/
Hola Claudio
Interesting :?
Here ( HMG 3.0.40 ) there isn't any problem
Please check size of .zip file, must be 7.152 bytes; may be corrupted while downloading.
If size is correct, probably you have upgrade to HMG 3.0.40 (2011-11-13) ;)
Hola Claudio:
el la carpeta HFCL dentro de HMG.3.040 estan los Include que necesitas para compilar MAgenda.hbp
yo copie la carpeta completa HFCL a la carpeta de Magenda
y ningun problema
danielmaximiliano wrote:
Google Translate wrote:l folder within HMG.3.040 HFCL are the need to compile Include MAgenda.hbp
I copy the entire folder to the folder HFCL Magendo
and no problem
No need copying entire folder :!:
Everything explained in C:/hmg/hfcl/Doc/index.htm.
ReadMe file of MiniAgenda wrote:
Notes :
- Mini Agenda use HFCL library
And MiniAgenda.hbc file have the line :
incpaths=C:\hmg\hfcl\Include\
After changing C:\hmg to your hmg path, you will compile either via HMG-IDE or build.bat with no problem.
Build.bat will be like :
call c:\hmg\build.bat MAgenda
That's all 8-)
PS: There is another simple way:
If you no need PRINT your grid, change ( line 487, 488 ) MAgenda.prg
   CASE cFOper == 'P'        // File\Print
         PRINT GRID grdMAgenda OF frmMiniAgenda SHOWWINDOW
to
         * PRINT GRID grdMAgenda OF frmMiniAgenda SHOWWINDOW
