xHarbour.com SQLRDD and HMG
melliott42
Post by melliott42 »
Hello,
Can anyone suggest the changes required to get xHarbour.com's SQLRDD to work with HMG 3.0.4?
I guess at a high level it involves pointing to the right /INCLUDE and /LIBs but was hoping someone has gone down this path before more and can share the optimal steps they found.
Thanks,
Michael
apais
Re: xHarbour.com SQLRDD and HMG
Post by apais »
I think this a question for harbour developpers.
This is a HMG ( a GUI for he Harbour compiler ) forum.
Angel
Angel Pais
melliott42
Let me take a step back perhaps...
Assume that I have a new library that has one or more ".lib" and ."ch" files that did not come with the default HMG install. If up-to-this point all my HMG programs have been created using just the standard build.bat and just one .prg file and I want to get this new Library to work, what do I need to modify and why in HMG?
[Sidebar]
I think at this point I am finding many variants of Clipper\Harbour (which is not a bad thing) and not sure what the rules of engagement are to introduce a new library into HMG. This may be a reason more new developers are put off from using xHarbour. Old Clipper 5.x guys had to learn this but new folks may find the availability of make-link-compile-etc docs very unclear.
Thanks for helping me understand this for HMG.
Michael
apais
Post by apais »
AFAIR sqlrdd is a closed source lib only generated for xharbour.
harbour and xharbour pcodes are incompatible, so I seriouslky doubt this will ever work.
There's been some years since I used to read xh forums. But I think SQLRDD is/was used to lock users into the paid version of xHarbour
Angel
Angel Pais
melliott42
I did not know this. I figured all xHarbour was the same at the core. Thanks for pointing that out.
