Change Size Menuitem im hmg.4
Hello,
Is possible change the size of "menuitem" ? See this image ?
Rossine.
Rossine.
Re: Change Size Menuitem im hmg.4
Hi Rossine.
With my compiled library, MainMenu, MenuPop and MenuItem have the same size.... this is the code
And these are two picture, one without "FontSize" (default system size)
If I understand your request or problem.
It's not possible (I have tried some times ago...) to have different size between MainMenu, MenuPopUp or MenuItem... In other words
Cheers
WITH OBJECT MainMenu():New( "MainMenu" )
:FontSize := 16
WITH OBJECT MenuPopup():New( 'File',, 'File' )
WITH OBJECT MenuItem():New( 'ItemOpen' ,, 'Open' , { || MsgInfo( 'Open' ) } ); END WITH
WITH OBJECT MenuItem():New( 'ItemClose',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH
WITH OBJECT MenuPopup():New( 'PopUp',, 'PopUp' )
WITH OBJECT MenuItem():New( 'Item1' ,, 'Open' , { || MsgInfo( 'Open' ) } ); END WITH
WITH OBJECT MenuItem():New( 'Item2',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH
END WITH
END WITH
END WITHIt's not possible (I have tried some times ago...) to have different size between MainMenu, MenuPopUp or MenuItem... In other words
:FontSize := 16
:FontSize := 10
:FontSize := 8
END WITH
END WITH
END WITH
Luigi from Italy
www.L3W.it
www.L3W.it
Wow! Thanks Luigi.
Wow ! It´s wonderful !
Taking this chance to ask:
In HMG 3 is this possible to do ?
Luigi :
Gracias por compartir tus conocimientos.
Hi DanielMaximiliano
"De nada", but I stop here my knowledge about hispanic language
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hello Luigi,
This would be a request
Wonderful to see it all working. Thank you for sharing your knowledge with us all and also all over your precious time dedicated to this great project.
Thanks Master Luigi
Rossine.
>> If I understand your request or problem.l3whmg wrote:Hi Rossine.
With my compiled library, MainMenu, MenuPop and MenuItem have the same size.... this is the codeAnd these are two picture, one without "FontSize" (default system size) If I understand your request or problem.Code: Select all
WITH OBJECT MainMenu():New( "MainMenu" ) :FontSize := 16 WITH OBJECT MenuPopup():New( 'File',, 'File' ) WITH OBJECT MenuItem():New( 'ItemOpen' ,, 'Open' , { || MsgInfo( 'Open' ) } ); END WITH WITH OBJECT MenuItem():New( 'ItemClose',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH WITH OBJECT MenuPopup():New( 'PopUp',, 'PopUp' ) WITH OBJECT MenuItem():New( 'Item1' ,, 'Open' , { || MsgInfo( 'Open' ) } ); END WITH WITH OBJECT MenuItem():New( 'Item2',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH END WITH END WITH END WITH
It's not possible (I have tried some times ago...) to have different size between MainMenu, MenuPopUp or MenuItem... In other wordsCheersCode: Select all
WITH OBJECT MainMenu():New( "MainMenu" ) :FontSize := 16 WITH OBJECT MenuPopup():New( 'File',, 'File' ) :FontSize := 10 WITH OBJECT MenuItem():New( 'ItemOpen' ,, 'Open' , { || MsgInfo( 'Open' ) } ) :FontSize := 8 END WITH END WITH END WITH
Thanks Master Luigi
Rossine.
Hi friends.
Many thanks for your words
A little brief about Menu and related font problem/request.
In the previous code, the MainMenu object inherit font (size, name, etc.) from QT default.
In the previous code, we have changed the fontsize property for the MainMenu object.
MenuItem inherit font (size, name, etc.) from its parent. Who is its parent? MainMenu
So, with first example MenuItem inherit Qt default font, in the second one inherit a "changed" font.
There are 3 lines within MenuPopUp.prg (97-100): if I remove these lines, menuitem doesn't inherit font property from its parent, but what happens? If I set a font for the MainMenu, this font it is not propagate to the MenuItem (in other words, it has default font) and we must use :FontSize to align its fontsize.
Remember that all font* methods are used by many objects.
From one side we can use only one time :FontSize and all menu objects have the same size; on the other side, we can have different size, but we must use everywhere :FontSize to have the same size.
I think this can be an evolution and everyone can think a solution.
Cheers
END WITH
END WITHCode: Select all
:FontSize := 16
END WITH
END WITHMenuItem inherit font (size, name, etc.) from its parent. Who is its parent? MainMenu
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hello Luigi,
Many thank´s for this explanation
Below an example to let the possibility of using each submenu with a different size.
Thanks for your help,
Rossine.
#include "hbqtgui.ch"
static Form_1
HbQt_ErrorSys()
WITH OBJECT Form_1 := MAINWINDOW():New( "Form_1" )
:Row := 10
:Col := 10
:Width := 1024
:Height := 630
:Title := "HMG4 demo change font menu"
:Icon := ":HMG_ICO"
DEFINE TOOLBAR oToolBar1 BUTTONSIZE 120, 80 FONT "ms sans serif" SIZE 12 MOVEABLE .F.
TOOLBUTTON oButton1 ;
Caption 'Font Menu Main' ;
picture 'open.png' ;
ACTION { || Form_1:MainMenu:FontSize ++ }
tooltip 'Change font of <Menu Main>'
TOOLBUTTON oButton2 ;
Caption 'Font Menu File' ;
ACTION { || Form_1:MainMenu:ItemFile:FontSize ++ }
tooltip 'Change font of Option <File>'
TOOLBUTTON oButton3 ;
Caption 'Font Menu Help' ;
ACTION { || Form_1:MainMenu:ItemHelp:FontSize ++ }
tooltip 'Change font of Option <Help>'
END TOOLBAR
:FontSize := 16
WITH OBJECT MenuPopup():New( 'ItemFile',, 'File' )
WITH OBJECT MenuItem():New( ,, 'Open' , { || MsgInfo( 'Open' ) } )
END WITH
WITH OBJECT MenuItem():New( ,, 'Save' , { || MsgInfo( 'Save' ) } )
END WITH
END WITH
WITH OBJECT MenuPopup():New( 'ItemHelp',, 'Help' )
WITH OBJECT MenuItem():New( ,, 'About' , { || MsgInfo( 'About' ) } )
END WITH
END WITH
END WITH
END WITH
ACTIVATE WINDOW Form_1
return NIL
Rossine.
Hi Rossine.
WoW
very
Many thanks
Cheers
WoW
Many thanks
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
