using code "C" in HMG
friends need help I have a code in "C" and must use in hmg can not call the function in "c" can someone help me how to call this function within my program
Static Procedure fEnvia()
local cWrite := CHR(1)+CHR(2)+CHR(0)+CHR(0) + CHR(0) + CHR(100)+ CHR(121) + CHR(225)
msginfo(CRC16(CHR(1)+CHR(2)+CHR(0)+CHR(0) + CHR(0) + CHR(100), LEN(CHR(1)+CHR(2)+CHR(0)+CHR(0) + CHR(0) + CHR(100)))) ->>>does not work the error does not exist
#PRAGMA BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include "mbcrc.h"
static const UCHAR aucCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
static const UCHAR aucCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
0x41, 0x81, 0x80, 0x40
USHORT
CRC16( UCHAR * pucFrame, USHORT usLen )
UCHAR ucCRCHi = 0xFF;
UCHAR ucCRCLo = 0xFF;
int iIndex;
while( usLen-- )
iIndex = ucCRCLo ^ *( pucFrame++ );
ucCRCLo = ( UCHAR )( ucCRCHi ^ aucCRCHi[iIndex] );
ucCRCHi = aucCRCLo[iIndex];
return ( USHORT )( ucCRCHi << 8 | ucCRCLo );
#PRAGMA ENDDUMP
#PRAGMA BEGINDUMP
#include "hbapi.h"
#include "mbcrc.h"
USHORT
int iIndex;
while( usLen-- )
#PRAGMA ENDDUMP
Re: using code "C" in HMG
To call a 'C' function from Harbour, it should be coded like the below in c:
HB_FUNC( CRC16 )
Please see some source c files from source directory.
HB_FUNC( CRC16 )
rathinagiri wrote:To call a 'C' function from Harbour, it should be coded like the below in c:
HB_FUNC( CRC16 )
can not understand with an example code that I posted never used programs in "c"
It should be like this:
#PRAGMA BEGINDUMP
#include "hbapi.h"
#include "mbcrc.h"
HB_FUNC( CRC16 )
UCHAR * pucFrame;
USHORT usLen;
int iIndex;
pucFrame = hb_parc(1);
usLen = hb_parn(2);
while( usLen-- )
hb_retni ( USHORT )( ucCRCHi << 8 | ucCRCLo );
#PRAGMA ENDDUMP
erro in build.log not execute compiling
Harbour 3.0.0 (Rev. 16951)
Copyright (c) 1999-2011, http://harbour-project.org/
F:\@Prog-Xbase\HMG-3\Projetos\MODBUS\HBCOMM-OK\HBCOMM-IDE\demo.prg: In function 'HB_FUN_CRC16':
F:\@Prog-Xbase\HMG-3\Projetos\MODBUS\HBCOMM-OK\HBCOMM-IDE\demo.prg:520:10: warning: assignment discards qualifiers from pointer target type
F:\@Prog-Xbase\HMG-3\Projetos\MODBUS\HBCOMM-OK\HBCOMM-IDE\demo.prg:521:1: warning: implicit declaration of function 'hb_parn'
F:\@Prog-Xbase\HMG-3\Projetos\MODBUS\HBCOMM-OK\HBCOMM-IDE\demo.prg:529:12: error: expected expression before 'USHORT'
hbmk2: Erro: Executando compilador C/C++. 1
gcc.exe -c -O3 -march=i586 -mtune=pentiumpro -fomit-frame-pointer -W -Wall -pipe -IC:/HMG3.0.38/harbour/include -I"F:/@Prog-Xbase/HMG-3/Projetos/MODBUS/HBCOMM-OK/HBCOMM-IDE" -IC:/HMG3.0.38/include C:/Users/jair/AppData/Local/Temp/hbmk_f0tfbt.dir/demo.c C:/Users/jair/AppData/Local/Temp/hbmk_m9t9ms.c
where I get a manual with commands and syntax HB_FUNC, HB_PARC, HB_PARN and others who can use
You can see the documentation here. (in Extend API section)
http://www.marinas-gui.org/projects/harbour_manual/
Rathi thank you for helping compile the code and returns the correct value when I need a time and can convert to this program will hmg help me thank you for everything follows the corrected code
HB_FUNC( CRC16_1 )
UCHAR * pucFrame;
USHORT usLen;
int iIndex;
usLen = hb_parni(2);
while( usLen-- )
hb_retni ( ucCRCHi << 8 |ucCRCLo );
}- Rathinagiri
Thank you. That is so nice of you.
