Export data to OpenOffice Calc and MS Office Excel
Hi guys!
I need export data to Calc and Excel - selected by user.
Some time ago, Alex Gustove presented quick method of exporting data to excel. It was based on paste method
cMemo := "some data to paste into worksheet" + chr(9)+"second cell value"+chr(9)+"third cell value"
system.clipboard := cMemo
oSheet:Range("A2"):select()
oSheet:paste()
This method really accelerates export to MS Excel.
I want to implement this for exporting to OO Calc, but, I can't find something like paste() method.
Maybe someone knows it?
regards, Marek
Re: Export data to OpenOffice Calc and MS Office Excel
Hi Marek,
This sample is from Harbour OLE test code. Hope it helps you.
   LOCAL oServiceManager, oDesktop, oDoc, oSheet
   IF ( oServiceManager := win_oleCreateObject( "com.sun.star.ServiceManager" ) ) != NIL
      oDesktop := oServiceManager:createInstance( "com.sun.star.frame.Desktop" )
      oDoc := oDesktop:loadComponentFromURL( "private:factory/scalc", "_blank", 0, {} )
      oSheet := oDoc:getSheets:getByIndex(0)
      oSheet:getCellRangeByName( "A1" ):setString( "OLE from Harbour" )
      oSheet:getCellRangeByName( "A3" ):setString( "String:" )
      oSheet:getCellRangeByName( "B3" ):setString( "Hello, World!" )
      oSheet:getCellRangeByName( "A4" ):setString( "Numeric:" )
      oSheet:getCellRangeByName( "B4" ):setValue( 1234.56 )
      oSheet:getCellRangeByName( "A5" ):setString( "Logical:" )
      oSheet:getCellRangeByName( "B5" ):setValue( .T. )
      oSheet:getCellRangeByName( "B5" ):setPropertyValue( "NumberFormat", 99 ) // BOOLEAN
      oSheet:getCellRangeByName( "A6" ):setString( "Date:" )
      oSheet:getCellRangeByName( "B6" ):setValue( DATE() )
      oSheet:getCellRangeByName( "B6" ):setPropertyValue( "NumberFormat", 36 ) // YYYY-MM-DD
      oSheet:getCellRangeByName( "A7" ):setString( "Timestamp:" )
      oSheet:getCellRangeByName( "B7" ):setValue( HB_DATETIME() )
      oSheet:getCellRangeByName( "B7" ):setPropertyValue( "NumberFormat", 51 ) // YYYY-MM-DD HH:MM:SS
      oSheet:getCellRangeByName( "A3" ):setPropertyValue( "IsCellBackgroundTransparent", .F. )
      oSheet:getCellRangeByName( "A3" ):setPropertyValue( "CellBackColor", 255 ) // blue
      oSheet:getCellRangeByName( "B3" ):setPropertyValue( "CharColor", 255 * 256 * 256 ) // red
      ? "Error. OpenOffice not available.", win_oleErrorText()
JosK
Post by JosK »
* $Id: testole.prg 8142 2007-12-05 08:17:30Z vszakats $
* Harbour Project source code:
* demonstration code for FOR EACH used for OLE objects
* this code needs HBWIN32 library
* Copyright 2007 Enrico Maria Giordano e.m.giordano at emagsoftware.it
* www - http://www.harbour-project.org
/* Explicit usage of OLE DEFAULT Method when syntax implies it. */
//#include "hmg.ch"
//#include "hbqtgui.ch"
#include "minigui.ch"
#xtranslate :<!Method!>( <args,...> ) := => :<Method>( <args> ):Value :=
PROCEDURE Main()
LOCAL nOption
CLS
SetColor("W+/R")
@ 6, 25 TO 19, 55 DOUBLE
@ 8, 28 SAY "Test Harbour OLE with..."
While .t.
@ 10, 32 PROMPT "MS Excel"
@ 11, 32 PROMPT "MS Word"
@ 12, 32 PROMPT "MS Outlook (1)"
@ 13, 32 PROMPT "MS Outlook (2)"
@ 14, 32 PROMPT "Internet Explorer"
@ 15, 32 PROMPT "XP CDO"
@ 16, 32 PROMPT "OpenOffice"
@ 17, 32 PROMPT "Quit"
MENU TO nOption
IF nOption == 0
nOption := 8
ELSEIF nOption == 1
Exm_MSExcel()
ELSEIF nOption == 2
Exm_MSWord()
ELSEIF nOption == 3
Exm_MSOutlook()
ELSEIF nOption == 4
Exm_MSOutlook2()
ELSEIF nOption == 5
Exm_IExplorer()
ELSEIF nOption == 6
Exm_CDO()
ELSEIF nOption == 7
Exm_OpenOffice()
ELSEIF nOption == 8
EXIT
End
SetColor("W/N")
CLS
// ; Requires Windows XP
STATIC PROCEDURE Exm_CDO()
LOCAL oCDOMsg
LOCAL oCDOConf
BEGIN SEQUENCE WITH {|oErr| Break( oErr )}
oCDOMsg := CreateObject( "CDO.Message" )
oCDOConf := CreateObject( "CDO.Configuration" )
oCDOConf:Fields("http://schemas.microsoft.com/cdo/config ... /sendusing") := 2 // ; cdoSendUsingPort
oCDOConf:Fields("http://schemas.microsoft.com/cdo/config ... smtpserver") := "localhost"
oCDOConf:Fields("http://schemas.microsoft.com/cdo/config ... serverport") := 25
oCDOConf:Fields("http://schemas.microsoft.com/cdo/config ... iontimeout") := 120
oCDOConf:Fields:Update()
oCDOMsg:Configuration := oCDOConf
oCDOMsg:BodyPart:Charset := "iso-8859-2" // "iso-8859-1" "utf-8"
oCDOMsg:To := "test@localhost"
oCDOMsg:From := "sender@localhost"
oCDOMsg:Subject := "Test message"
oCDOMsg:TextBody := "Test message body"
oCDOMsg:Send()
RECOVER
Alert( "Error: CDO send error. [" + Ole2TxtError()+ "]" )
END SEQUENCE
oCDOConf := NIL
END SEQUENCE
oCDOMsg := NIL
RECOVER
Alert( "Error: CDO subsystem not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC PROCEDURE Exm_IExplorer()
LOCAL oIE
oIE := CreateObject( "InternetExplorer.Application" )
oIE:Visible := .T.
oIE:Navigate( "http://www.harbour-project.org" )
END SEQUENCE
RECOVER
Alert( "Error: IExplorer not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC PROCEDURE Exm_MSExcel()
LOCAL oExcel
LOCAL oWorkBook
LOCAL oWorkSheet
LOCAL oAS
oExcel := CreateObject( "Excel.Application" )
oWorkBook := oExcel:WorkBooks:Add()
FOR EACH oWorkSheet IN oWorkBook:WorkSheets
? oWorkSheet:Name
oAS := oExcel:ActiveSheet()
oAS:Cells:Font:Name := "Arial"
oAS:Cells:Font:Size := 12
// Explicit use of DEFAULT method by means of #xtranslate above!!!
oAS:Cells( 3, 1 ) := "Explict DEFAULT Method Text:"
// Array notation seem to have REVERSED indexs for the Cells Collections!!!
// Implicitly using DEFAULT Method
oAS:Cells[ 2, 3 ] := "Implicit DEFAULT Method using *reversed* array index notation"
// Operator overloading will attempt explict resolutin using :OleValue
oAS:Cells[ 2, 3 ] += "!"
oAS:Cells( 4, 1 ):Value := "Numeric:"
oAS:Cells( 4, 2 ):NumberFormat := "#.##0,00"
oAS:Cells[ 2, 4 ] := 1234.50
oAS:Cells[ 2, 4 ] *= 4
? oAS:Cells[ 2, 4 ], oAS:Cells[ 2, 4 ]:Value
oAS:Cells[ 2, 4 ] /= 2
oAS:Cells[ 2, 4 ]++
oAS:Cells[ 2, 4 ]--
oAS:Cells( 5, 1 ):Value := "Logical:"
oAS:Cells( 5, 2 ):Value := .T.
oAS:Cells( 6, 1 ):Value := "Date:"
oAS:Cells( 6, 2 ):Value := DATE()
oAS:Columns( 1 ):Font:Bold := .T.
oAS:Columns( 2 ):HorizontalAlignment := -4152 // xlRight
oAS:Columns( 1 ):AutoFit()
oAS:Columns( 2 ):AutoFit()
oAS:Cells( 1, 1 ):Value := "OLE from Harbour"
oAS:Cells( 1, 1 ):Font:Size := 16
oAS:Range( "A1:B1" ):HorizontalAlignment := 7
oAS:Cells( 1, 1 ):Select()
oExcel:Visible := .T.
oExcel:Quit()
END SEQUENCE
RECOVER
Alert( "Error: MS Excel not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC PROCEDURE Exm_MSWord()
LOCAL oWord
LOCAL oText
oWord := CreateObject( "Word.Application" )
oWord:Documents:Add()
oText := oWord:Selection()
oText:Text := "OLE from Harbour" + hb_OSNewLine()
oText:Font:Name := "Arial"
oText:Font:Size := 48
oText:Font:Bold := .T.
oWord:Visible := .T.
oWord:WindowState := 1 // ; Maximize
END SEQUENCE
RECOVER
Alert( "Error: MS Word not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC PROCEDURE Exm_MSOutlook()
LOCAL oOL
LOCAL oList
oOL := CreateObject( "Outlook.Application" )
oList := oOL:CreateItem( 7 ) // ; olDistributionListItem
oList:DLName := "Distribution List"
oList:Display( .F. )
END SEQUENCE
RECOVER
Alert( "Error: MS Outlook not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC PROCEDURE Exm_MSOutlook2()
LOCAL oOL
LOCAL oLista
LOCAL oMail
LOCAL i
oOL := TOleAuto():New( "Outlook.Application.9" )
IF Ole2TxtError() != "S_OK"
Alert("Outlook is not available", "Error")
oMail := oOL:CreateItem( 0 ) // olMailItem
FOR i := 1 TO 10
oMail:Recipients:Add( "Contact" + LTRIM( STR( i, 2 ) ) + ;
"<contact" + LTRIM( STR( i, 2 ) ) + "@server.com>" )
oLista := oOL:CreateItem( 7 ) // olDistributionListItem
oLista:DLName := "Test with distribution list"
oLista:Display( .F. )
oLista:AddMembers( oMail:Recipients )
oLista:Save()
oLista:Close( 0 )
oMail:End()
oLista:End()
oOL:End()
STATIC PROCEDURE Exm_OpenOffice()
LOCAL oOO_ServiceManager
LOCAL oOO_Desktop
LOCAL oOO_PropVal01
LOCAL oOO_Doc
LOCAL cDir
oOO_ServiceManager := CreateObject( "com.sun.star.ServiceManager" )
hb_FNameSplit( hb_ArgV( 0 ), @cDir )
oOO_Desktop := oOO_ServiceManager:createInstance( "com.sun.star.frame.Desktop" )
oOO_PropVal01 := oOO_ServiceManager:Bridge_GetStruct( "com.sun.star.beans.PropertyValue" )
oOO_Doc := oOO_Desktop:loadComponentFromURL( OO_ConvertToURL( hb_FNameMerge( cDir, "sample.odt" ) ), "_blank", 0, { oOO_PropVal01 } )
oOO_Doc:Close( .T. )
oOO_Doc := NIL
oOO_Desktop:Terminate()
oOO_Desktop := NIL
oOO_PropVal01 := NIL
END SEQUENCE
oOO_ServiceManager := NIL
RECOVER
Alert( "Error: OpenOffice not available. [" + Ole2TxtError()+ "]" )
END SEQUENCE
STATIC FUNCTION OO_ConvertToURL( cString )
// ; Handle UNC paths
IF !( Left( cString, 2 ) == "\\" )
cString := StrTran( cString, ":", "|" )
cString := "///" + cString
cString := StrTran( cString, "\", "/" )
cString := StrTran( cString, " ", "%20" )
RETURN "file:" + cString
Thanks for your help, but... I know how to write data to calc'worksheet.
I'm exactly interested of paste data from clipboard.
Marek
Interesting ! I have seem this years ago and just now I will used. Could you tell me how to break lines is used for spread sheet ? For text is chr(13)+chr(10) but in Excel ? I means when you have many line ready to copu to clipboard and the you want to pass to Excell sheet. How is the line return and feed line ?
Simply - separate lines with chr(10)
I've tested with 1,500 records and it works very fast with Excel.
Export data cell by cell works very slowly.
Just for reminder: It is really chr(13)+chr(10) not only chr(10).
I want to refresh this topic
Maybe someone knows equivalent phrase:
osheet:paste()
which will be correct and work good in openoffice ?
Hi Marek,
Had you solved this?
