Please show your most complex PICTURE
Hi everybody.
3 of us (me, Luigi and Ricci) are discussing and working on prototypes for PICTUREs in Textbox. We are discussing on different approaches and results...
Before going further I'd like to ask EVERYBODY:
- can you please show us the complex PICTUREs do you have in software written with HMG3 library?
- can you please show us the PICTUREs you have in harbour text-only code ?
- is it a big problem if you need to change them ?
Re: Please show your most complex PICTURE
Hi Francesco,
In my programs I don't use complex pictures a lot.
However, I use/prefer date textbox in the place of calendar which reduces the key strokes.
My numeric textbox would have a picture like this '9999999.999'. That's all.
Recently I have used this picture for a specific purpose:
inputmask 'AAAAA9999A'
PICTUREs in Textbox... ? I never used it. Well I am just starting in GUI world, I begin in begining of 2011, so I do very simple codes but It will be very good to have it. This would be something like this ?
I have took that picture from internet.
Another thing that could it be interesting is inserting text boxes in pictures.
I also read some comments that could it be interesting to be considered:
Where the picture is?
1. Will there be a border around the outside edge of the text (i.e., between the text and the edge of the physical page)? If so, you can do this using a page border. If not... ignore this step.
2. Do you want a border that separates the text from the picture? If you want white space between that border and the picture, as well as between that border and the text, you can do this by inserting a rectangular shape, and setting its wrapping style to square or tight.
3. You then insert the picture, and set its wrapping style to In front of text, and drage the picture so that it's overlayed on top of the rectangular shape that provides the border.
I was asking PICTURE of the
@ GET PICTURE <sample>
not including images in textboxes....
Ohhh so sorry ! I have missunderstood ! Very sorry.
Well here in Brasil we use for exemple:
- Nums: 1.000,50 (one thousand and fifty) this also valid for money. In Clipper I've used "@E 999,999.99". It would it be wounderful to use like elctronical cash of banks, type each numbers and be aligned from right to left considering comma as decimals.
- Date: "@D" in this format dd/mm/yyyy - Set British way. But the claendar is great !
- For social ID: "999.999.999-99"
- For upper cases: "@!"
- Now for emails picture, we know shoulkd it be in lower case with noespecial caracters and exemptions.
- Some modifications in GETSYS.PRG in Clipper was used to do it for lower cases pictures, using Picture "@M".
- Also in Clipper for string I have used much "@!S30" combined case, upper + subs tring showing just 30 characters. Other char picture is "!AAA" combined upper and only alpha characters.
- For passwords, must be showing a pre-defined character "*" (for example)
- For telephone numbers (but string one): "#999-9999" first character could it be in blank (one space).
- And for numbers that no appears on screen when value is zero, usedin CLipper: "@Z 999" shows in blank.
Well, I hope be helpfully for your concepts. Thank you for your attention and dedication too.
hi all,
I also don't use complex picture.
For me the maximum is like '99!!!999" or "99-AAA-999" to input codes for inventory items.
Thanks for your fantastic work I'm only at my third month with hmg so I read all but I can't post cause my ignorance.
Hi to everyone.
I'm working on TEXTBOX. In this moment I have a working experiment based upon "some" HMG3 codes: "!", "A", "N", "X", "9" (obviously with ".", ",", "+","-"). As soon as possible I will share exe to show.
To manage entered data there are many possibilities, as you can see can be implemented with validator (see MrDuck commit), but I have a question related with this topic: do you think it's better to respect HMG3 (it has a reduced set of code), CLIPPER (it has some "strange" or "unused" or "unusefull" code), strictly QT inputmask (see this http://doc.qt.nokia.com/latest/qlineedi ... tMask-prop ) or create a mixed? If we use the last two (Qt inputmask or a mix) we can't use some CLIPPER function (f.e. TRANSFORM) and we must create a new set of functions (f.e. Hmg_Transform).
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi friends.
post revised on 2011.12.15
I'm very pleased to show you my last improvement of TEXTBOX object.
I have solved some problem and the first one is about DATATYPE (thanks to MrDuck, he said me: try to find a solution); now, there isn't need to set this value as parameter within the New() method.
On the other hand, this setting cannot be changed after object creation.
OOP syntax accpeted (I will show only specific for textbox )
InputMask:
A) Can be always omitted. About TXT_DATE will be used "SET( _SET_DATEFORMAT )" returned value
B) TXT_DATE acceppeted character code:
n.b. if a wrong date is entered only when TEXTBOX object lost focus an error occurs.
C) acceppeted character code:
Format:
n.b. only for numeric datatype are used
Can be omitted: in this case, will be set with related value VALTYPE.
Behaviour:
I'll wait your opinion and then if liked it As Soon As Possible and in according with MrDuck's job (he is working on the same object), I will change current HMG4 TEXTBOX object.
Cheers
WITH OBJECT [oVarName := ] TEXTBOX():New( [cObjectName][,oParent] )
[:InputMask := "......."]
[:Format := [E | C | X | ( | S] ]
[:DataType := [TXT_CHARACTER | TXT_NUMERIC | TXT_DATE] ]
[:CaseConvert := [TXT_NONE | TXT_UPPER | TXT_LOWER] ]
[:MaxLength := <number> ]
:Value := [<string>, <number>, <date>]
END WITHInputMask:
- ["YYYY" | "YY"]: year position
"MM" : month position
"DD" : day position
- "!" : convert uppercase alphabetic character
"A" : alphabetic (a-z, A-Z)
"9" : digit (0-9). About TXT_NUMERIC "+" and "-" are accepted
"N" : digit (0-9) and alphabetic (a-z, A-Z)
"X" : any character
"," : with TXT_NUMERIC to format displayed value
"." : with TXT_NUMERIC to format displayed value and to know if decimals are present while editing
Format:
- "E" : swap "." and "," to show numbers in European format (eg. "1.234.567,89"). By default is English-speaking format (eg. "1,234,567.89")
"C" : displays "CR" after positive numbers
"X" : displays DB after negative numbers
"(" : encloses negative numbers in parentheses
"S" : new always displays sign for positive or negative numbers
Behaviour:
- A) when TEXTBOX object will be created cannot be changed
B) if already set and value VALTYPE is not compatible an error occurs
C) if set after value assignment and is not compatible with value VALTYPE an error occurs
- * While editing TXT_NUMERIC field you can use both. Also character selection (one or more) can be used.
* While editing TXT_CHARACTER field:- - without InputMask: you can use both. Also character selection (one or more) can be used.
- with InputMask: BACKSPACE not allowed, DEL only if all the characters are selected
Cheers
- demo01_t.zip
- demo 2011.12.15 update
- (1.05 MiB) Downloaded 318 times
Luigi from Italy
www.L3W.it
www.L3W.it
Hi friends.
I have upload a new version of my experiment.
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Luigi,
I have tested the sample Luigi. It is working as expected.
Thanks man.
So, we have to write the validation of date. (Now it accepts any invalid date too.)
