Hi
Just downloaded HMG/HMGIDE and I must say I am pretty impressed with it given my extensive Delphi + Clipper background.
Using the Menu Sample,
#include "minigui.ch"
Load Window Test
Center Window Test
Activate Window Test
I can understand that Test is a window defined as test.fmg but I cannot see how and where the
a) File /Open, Edit,Save is created
b) how the message Dialog is onvoke when one click say File/open
CCH
http://cch4clipper.blogspot.com
Trying to understand the Samples via HMGIDE
Re: Trying to understand the Samples via HMGIDE
Hello CCH, welcome abord, big haapiness seeing you here
Again, welcome and happ HMG'ing.
Best Regards.
In HMG-IDE, all the project files ( .ch, .prg, .fmg etc ) are in project directory. Only project file ( .hmg ) invoke directory path when first opening and first saving. Other files are saved to project path without asking path. When you open a project file (.hmg), IDE open all project files automatically.CCH4CLIPPER wrote:
CCH
Best Regards.
Hi esgici
Great to be here
What I meant was how do I define the menus or customise the menu sample ?
CCH
Great to be here
CCH
Hello CCHCCH4CLIPPER wrote: ...
CCH
Well, we have four "menu builder" commands/buttons in the "builders" section of "Control Panel" of HMG-IDE: Main menu, Context Menu, Notify Menu and Drop-down Menu builders.
Because of the menu controls are complicated than ordinary GUI control, they are considered as "builder" in IDE.
Although HMG-IDE is a optional utility for make easy working in graphics, sometime working without IDE may be seen more easy.
In other hand for learning , direct coding is always better way than using "code writers".
In short, my suggestion is beginning by "Adding The Main Menu" subtitle of "Tutorial" page: C:\hmg\DOC\tutorial.htm
Hi Escigi
Yup, I found out how it was done via Menu Builder late last night.
What I am going to do is to explore the IDE first...
BTW, I am promoting HMG at Clipper... Clipper...Clipper
CCH
http:/cch4clipper.blogspot.com
CCH
Hi Esgici
You are right, it is much easier to code by hand
So, I am temporarily dropping the IDE and coding by hand the menu framework of my target xHarbour Application
BTW, if I have several prgs, how do I compile them ?
The samples compile.bat deals with only a single prg
CCH
CCH
It is easy to compile several prgs.
Write down all the prg filenames each in a separate line, keeping the prg file having main() function as the first line.
Save the file giving an extension of .hpj and open the same using HMG-IDE. You need not worry about any designing of forms there. Just press ctrl+F5 (Project->Build) or F5 (Project -> Run) or click the play button there to build and run.
So, HMG-IDE is a two way utility to build a HMG project and as well as an IDE.
Hi CCHCCH4CLIPPER wrote:
... if I have several prgs, how do I compile them ?
CCH
As Rathinagiri said, it is easy to compile several prgs with HMG-IDE.
As cited in HMG-IDE page of Viva Clipper], HMG-IDE is both a Project Manager and a Form Designer.
The project management tools allow you all project based works with interactive manner. This includes building and running projects without complex batch processing and environment configuration tasks.
Build or open a project and add or exclude project elements ( forms (.fmg), modules (.prg ) whatever you want. This way have a big advantage: since HMG-IDE is at the same time a highly sophisticated "make" utility, only changed files will be compiled.
Alternatively you can use SET PROCEDURE TO <cModulFileName> command and also #include <cModulFileName> statement of Clipper. But, notice that in this case "make" concept will be broken.
In other hand, "The samples compile.bat deals with only a single prg" isn't correct. If you read it you will be seen "%1 %2" expressions. They are command parameters and each for a separate file.
BTW, in only one night you solved almost all about HMG, congratulations!
