About ComboBox Compatibility...
Francesco, Luigi,
I'm testing Combo height property compatibility and I've found that it appears to be not working, even when the height method is overloaded to allow HMG3 compatibility.
I'm sure that I'm missing something, but I'm not able to found what the problem is.
This is the code:
	hbqt_errorsys()
	HMG3(.T.)
        Load Window Main
        Main.Center
        Main.Activate
* HMG-IDE Form Designer Generated Code
DEFINE WINDOW TEMPLATE AT 216 , 350 WIDTH 696 HEIGHT 215 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "Hello World!" ICON NIL MAIN CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
    DEFINE COMBOBOX Combo_1
        ROW    30
        COL    260
        WIDTH  100
        HEIGHT 100
        ITEMS {""}
        VALUE 0
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        SORT .F.
        ONENTER Nil
        ONDISPLAYCHANGE Nil
        DISPLAYEDIT .F.
        IMAGE Nil
        DROPPEDWIDTH Nil
        ONDROPDOWN Nil
        ONCLOSEUP Nil
    END COMBOBOX
TIA.
Re: About ComboBox Compatibility...
and...
This is the resulting app.
As you can see, the height property is not ignored...
Francesco,
I've made a little test about combo height in HMG3 compatibility mode:
   Height: overloaded since has different meanings from hmg3()
METHOD Height( nArg1 ) CLASS COMBOBOX
   IF HMG3()  // hmg3 compatibility mode
      // do nothing with Height
	IF PCOUNT() == 1 .AND. hb_IsNumeric( nArg1 )
	      	Super:Height( nArg1 )
		MsgInfo('Combo Height Set!')
RETURN Self
Then, compiled again the sample in the first message in this thread, and strangely, this was the result:
So, HMG3() is returning .F. in combo's height method even when HMG3(.T.) is invoked.
mrduck
Post by mrduck »
Yes, this is a known bug !
hmg3() lowercase...
HMG3 uppercase is rewritten with the #define HMG3...
it has to be changed !
hmg3_compatibility( .T. )
I will do this evening
sorry but yesterday night was too late...
mrduck wrote:Yes, this is a known bug !
hmg3() lowercase...
Ok.
No problem, it was too late for me too, but today is a non-working day here, so I'm dedicating it to compatibility tests :)
Thanks!
I've already done and committed.
Apparently it has not side effects and is working fine for combo.
Thanks again.
