I know about current QT license limitations regarding static linking.
Despite that, I'm interested in do some tests...
Does someone know how to do that?
It is possible to do from HMG.4 binaries, or something more is required?
TIA.
Static linking...
- HMG Founder
Static linking...
Re: Static linking...
I read that you need to compile Qt from sources... there are some guides on the net. I did cross-compile Qt on linux and it was not difficult..Roberto Lopez wrote:
If you succeed please report.
- HMG Founder
Ok.mrduck wrote:I read that you need to compile Qt from sources... there are some guides on the net. I did cross-compile Qt on linux and it was not difficult..Roberto Lopez wrote:
Thanks.
It would be great to put all used dll into the exe including the grafic dlls and translation files.
