HMG.4 New Windows Binaries+Source Release (2011.11.23)
Updated Windows binaries along with HMG4 compatible HMG-IDE contributed by Roberto Lopez and the latest svn update.
https://sourceforge.net/projects/hmg/fi ... urce=files
I request you to test the build and report the problems you encounter.
Thank you.
Thank you.
Re: HMG.4 New Windows Binaries+Source Release (2011.11.23)
Thanks a lot Rathi
I've tried to use new IDE and new hmg.4 to compile two of my huge projects.
the problem is a lot of errors, but I can''t see anything, because results of compilation dissappear from screen, you can not scroll result window.
It's unusable in this form
137 errors? from where?
How to find first of them?
Can you please send akord.prg to me, please ?mol wrote:I've tried to use new IDE and new hmg.4 to compile two of my huge projects.
Francesco
- HMG Founder
I've published it for basic compatibility testing only.mol wrote:I've tried to use new IDE and new hmg.4 to compile two of my huge projects.
It's unusable in this form![]()
It is (obviously) not ready for production. A lot of work must be done.
Despite that, you can easily solve your problem, simply redirecting the hbmk2 output to a file.
You can learn how to do that in HMG 3.x build.bat file.
If you achieve it, please post your modified buildapp.bat since it will be very useful for other users.
TIA!
Akord.prg is only one piece of code. You can downoload it from http://www.molsystemy.pl/kern/akord.prgmrduck wrote:Can you please send akord.prg to me, please ?mol wrote:I've tried to use new IDE and new hmg.4 to compile two of my huge projects.
Francesco
TIA!
if "%1"=="/3" goto compatible
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -w3 -es2 > compile.log 2>&1
Sorry, I don't know how to do it, now...
- HMG Founder
Please, look at build.bat (hbmk2 line) in (ie) 3.0.35 binaries.mol wrote:I've tried to modify buildapp.bat:Roberto Lopez wrote:
TIA!but, it doesn't produce any log file.Code: Select all
if "%1"=="/3" goto compatible HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -w3 -es2 > compile.log 2>&1 ...
It requires a little utility called redir (included in the distribution, UTIL folder).
- HMG Founder
Something like that:mol wrote: but, it doesn't produce any log file.
redir -eo hbmk2 ...desired hbmk2 parameters... >build.logCode: Select all
notepad build.logRegards/Saludos,
The errors you see are from lines like these:mol wrote:I've tried to use new IDE and new hmg.4 to compile two of my huge projects.
OkGl_Akord.L201Zad.VALUE := str(aAktyw[1]/465,5,2)
To see what happens, please add to hbmk2 line in buildapp
-prgflag=-p -prgflag=-p+
