HMG.4 IDE Test
HMG.4 IDE Test
Well... no exactly... :)
I've modified the HMG.3 IDE to make it HMG.4 compatible and I've attached to this message.
To make it work, you must be sure that hmg.ini file point to the right location (by default it is 'C:\HMG.4\SVN') and that you have the current HMG.4 sources (at least 2011.11.20).
Some important things:
- The way in that HMG 3 IDE form designer generates code IS NOT the recommended way to code semi-oop in HMG.4. It reflects the status of HMG at first IDE release in 2004 (MiniGUI library at that time). That style will be supported for backwards compatibility only.
I'm talking about (specifically) of DEFINE WINDOW, DEFINE TAB, DEFINE TREE and other commands that requires that all properties (clauses) be specified in the same line.
This way of coding is considered DEPRECATED (backwards compatible only) in HMG.4.
The preferred semi-oop way is shown in this sample (one property by line):
   DEFINE MAINWINDOW MainForm
       ROW         10
       COL         10
       WIDTH       600
       HEIGHT      600
       TITLE       "CHILD window demo"
       ONINIT      MainFrmOnInit()
- This IDE.4 is only temporary, until the new IDE be finished.
- The only example I've tested is the one included. It contains a module and a form exactly as they are created when 'New Project' command is used to create a project.
- Is highly probable that many of control code generated by IDE be not compatible with HMG.4 yet. Please do not complain about that :). Just inform us and (if possible) give us some ideas about which the problem is.
Thanks!
ide4.zip
(959.51 KiB) Downloaded 677 times
Re: HMG.4 IDE Test
I'm amazed, since most used controls code generated by IDE was compiled ok.
I've found a problem with RADIOGROUP (apparently) related with FontSize property (image attached to this message).
Re: HMG.4 IDE Test
Roberto Lopez wrote:Hi All,
This is the RADIOGROUP code:
    DEFINE RADIOGROUP RadioGroup_1
        ROW    210
        COL    210
        WIDTH  120
        HEIGHT 50
        OPTIONS { 'Option 1','Option 2'}
        VALUE 1
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        SPACING 25
        BACKCOLOR Nil
        FONTCOLOR Nil
        READONLY Nil
        HORIZONTAL .F.
    END RADIOGROUP
mrduck
Re: HMG.4 IDE Test
Post by mrduck »
I'm amazed,
I'm not .... :-) :-) :-)
I also noted this in the past... I will investigate...
Re: HMG.4 IDE Test
Hi Roberto!
Nice to see your back at work on HMG!
Marek
Re: HMG.4 IDE Test
I've found the cause.
If you eliminate the 'spacing' property line it looks ok.
So... I guess that could be a problem with SPACING property only or between SPACING and HEIGHT properties.
mrduck
Re: HMG.4 IDE Test
Post by mrduck »
Yes, it's spacing, because I don't know why the author of this code used a qboxlayout... perhaps we should avoid spacing...
Re: HMG.4 IDE Test
mrduck wrote:Yes, it's spacing, because I don't know why the author of this code used a qboxlayout... perhaps we should avoid spacing...
In WIN32 I've implemented spacing in an extremely simple way. Each radio button is created at last button row+spacing. Just that.
Until more research about this be made, we could simply disable spacing.
Re: HMG.4 IDE Test
Francesco,
There is still some problems that can be solved changing buildapp.bat as follows:
@echo off
REM
REM $Id$
REM
IF DEFINED HMGPATH GOTO HmgPathDefined
SET HMGPATH=c:\hmg.4
SET PATH=%HMGPATH%\harbour\bin;%HMGPATH%\harbour\comp\mingw\bin;%PATH%
SET HB_WITH_QT=%HMGPATH%\harbour\include
:HmgPathDefined
if "%1"=="/3" goto compatible
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -w3 -es2
goto end
:compatible
shift
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -DHMG3 -i. -run
pause
:end
The optional /3 parameter will make the required things to make the HMG3 projects work.
Could be you (or someone else) so kind to upload it?
Thanks in advance.
mrduck
Re: HMG.4 IDE Test
Post by mrduck »
Roberto,
I'm preparing a new commit with all the stuff... I want to ask: do you need to change vertical/horizontal alignment of radiobuttons at run time ? Or when we open the form we can assume they are in the proper orientation ?
