With a little help of the forum...
I'm creating an alternate version of HMG-IDE to make it able to work with HMG.4 (in fact with any hbmk2 project).
A minimal modification is required in buildapp.bat.
The line invoking hbmk2, must be modified as follows to make it able to find .fmg files in the project folder (it's the same for HMG3):
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -i.
But the true problem is that HMG.4 is unable to build the basic application generated by IDE at project creation.
Load Window Main
Main.Center <-- SYNTAX ERROR HERE
Main.Activate <-- SYNTAX ERROR HERE
If anyone has a clue about that and can solve it, I'll publish the new IDE (HMG.4 enabled) version.
Attached to this message is the complete project.
TIA.
sample.zip
(1.1 KiB) Downloaded 290 times
Re: With a little help of the forum...
Hi Maestro
I guess need () after Center and Activate
        Main.Center    ==>    Main.Center()
        Main.Activate  ==>    Main.Activate()
Best regards
esgici wrote:Hi Maestro
Best regards
The program compiles with such changes, but it does not run...
Roberto Lopez wrote: The program compiles with such changes, but it does not run...
Yes, like Activate doesn't exist :(
mrduck
Post by mrduck »
Hi Roberto,
I can't check now since I'm leaving.
Please try adding
-DHMG3 on cth hbmk2 command line
This will include hmg3.ch file where there are some other defines needed for hmg3 compatibility
Please also add these 2 lines at the top of source code:
hbqt_errorsys() // to enable error system
hmg3(.T.) // to enable better hmg3 compatibility
I started to do some commits yesterday, I have others to do later today, also about the ide in hmg4
Francesco
Hi Maestro
I guess you have find, but I find new and I want share with other friends too.
Problem is : ICON clause in DEFINE WINDOW statement doesn't work ( probably for now ).
Program run after extracting ICON clause ( added by IDE automatically ).
Apparently, we have begin a re-learn course for converting HMG3 applications to HMG4 :(
f.e. @ <nRow>, <nCol> syntax seems fully abandoned and our programs have tons of them :cry:
A last note for our friend who want begin to HMG4 ( I guess no too many ): Add
HbQt_ErrorSys()
at beginning of every main prg; this will very helpful for understanding an learning HMG4.
f.e. after adding this line error message produced and problem appears:
Set Window Icon error mesage
Please nobody don't misunderstand me; I don't want criticize anybody, anything. My only goal is share my humble experiences with my friends.
I have seen Francesco's response after submitted mine.
I'll try his advises too, thanks.
mrduck
Post by mrduck »
@escigi
The fact that the program compiles means that the @ x,y syntax is fully supported.
The error is about the parameter of ICON. hmg4 is trying to set icon but its parameter is not the expected type. I will check later.
Last summer I was able to compile and execute some .FMG files sent to me by Malek, applying necessary changes to hmg.ch and adding hmg3.ch.
Please note that hmg3.ch is not completed ! there are some things to convert.
esgici wrote: I'll try his advises.
Tried; no change :(
Esgci
mrduck wrote: The fact that the program compiles means that the @ x,y syntax is fully supported.
Sorry, don't understood :( Where is @ x,y syntax in compiled program ?
Please don't repeat said things such your own opinion.
In the example used only parameter is NIL. Does HMG4 don't understand NIL ?
Please also don't repeat known issues. I don't said "announced as 'completed' but left missing".
Only goal is assist you by testing and asking somethings. If you don't like conversations such type, please speak clearly: "I'm closed every kind of critics".
