HMG4 - anybody know how to make a dynamic menu ?
ClaudioGalera
Post by ClaudioGalera »
Hi ! :)
I need make a main menu dinamic from file dbf in HMG4.Like as menudbf from Minigui (\minigui\samples\basic\menudbf) - I try compile this example but it make error :(
Thank you
Claudio Galera
(Ignore the error defined by the window, please)
MenuDBF.zip
(12.17 KiB) Downloaded 953 times
Re: HMG4 - anybody know how to make a dynamic menu ?
Hola Claudio:
ya quedo el codigo sin errores para HMG.0.3.40
#include 'hmg.ch'
#include 'common.ch'
#define CrLf       chr(13)+chr(10)
#define cAcercaDe  "Ejemplo de definición de menú"+CrLf+"en tiempo de ejecución"+CrLf+CrLf+cVersion+CrLf+CrLf+chr(174)+" Abril 2006, Roberto Sánchez"+CrLf+CrLf+MiniGUIVersion()+CrLf+Version()
#define cFaltaMenu "Falta la tabla MenuDBF.DBF","Falta Archivo"
#define cVersion   "Versión 00.00.01"
Static aListItens:={}
Function Main()
	Public cm_tipo
	Public cm_caption
	Public cm_action
	Public cm_name
	Public cm_image
	Public cm_checked
	Public cm_Disabled
	Public cm_Message
	Public bManejadorError, bUltimoManejador, objErr,wret:=.F.
	Public cFile:="Menu.DBF"
	Public c1, c_dbf, f
	Public cm_Idioma:=2
	Public lescolha:= .t.
    Set exclusive off
	If file(cfile)
		C1:=RAT(".",CFILE)
		C_DBF:=LEFT(CFILE,C1-1)
		USE &C_DBF NEW
		INDEX ON descend(FIELD->LINHA) TO &C_DBF
		Do while !eof()
			AADD(aListItens,{"","","","","","","","","","",.F.,.F.})
			Ains(aListItens,1)
			aListItens[1]:={(Alias())->TIPO,;		// 1
							(Alias())->CAPTIONP,;	// 2
							(Alias())->CAPTIONE,;	// 3
							(Alias())->CAPTIONI,;	// 4
							(Alias())->NOME,;		// 5
							(Alias())->ACTION,;		// 6
							(Alias())->IMAGE,;		// 7
							(Alias())->MESSAGEP,;	// 8
							(Alias())->MESSAGEE,;	// 9
							(Alias())->MESSAGEI,;	// 10
							(Alias())->CHECKED,; 	// 11
							(Alias())->DISABLED}	// 12
			skip
		Enddo
		USE
		DEFINE WINDOW WinMain AT 0, 0 WIDTH 800 HEIGHT 600 TITLE "Menu DBF en tiempo de ejecución" MAIN
			DEFINE MAIN MENU
	        FOR f:= 1 to len(aListItens)
				cm_tipo     :=aListItens[f][1]
				cm_caption  :=ALLTRIM(aListItens[f][2+cm_Idioma])
				cm_name     :=ALLTRIM(aListItens[f][5] )
				cm_action   := iif(EMPT(ALLTRIM(aListItens[f][6])),Nil,alltrim(aListItens[f][6]))
				cm_image    :=IIF(EMPT(ALLTRIM(aListItens[f][7])),NIL,ALLTRIM(aListItens[f][7]))
				cm_Message  :=IIF(EMPT(ALLTRIM(aListItens[f][8+cm_Idioma])),NIL,ALLTRIM(aListItens[f][8+cm_Idioma]))
				cm_checked  :=aListItens[f][11]
				cm_Disabled :=aListItens[f][12]
		        If cm_tipo = "DEFINE POPUP"
					DEFINE POPUP cm_caption NAME cm_name
				ELSEIF cm_tipo = "MENUITEM"
					If !cm_checked
						IF cm_Disabled
							if cm_action = nil
								MENUITEM cm_caption ACTION nil Name cm_name IMAGE cm_image
								MENUITEM cm_caption ACTION { || &cm_action }
						Else
							if cm_action = nil
								MENUITEM cm_caption ACTION nil  NAME cm_name IMAGE cm_image
								MENUITEM cm_caption ACTION { || &cm_action } NAME cm_name IMAGE cm_image
							Endif
						Endif
					Else
						IF cm_Disabled
							if cm_action = nil
								MENUITEM cm_caption ACTION nil NAME cm_name IMAGE cm_image CHECKED
								MENUITEM cm_caption ACTION { || &cm_action } NAME cm_name IMAGE cm_image CHECKED
							if cm_action = nil
					Endif
				ELSEIf cm_tipo = "SEPARATOR"
					SEPARATOR
				ELSEIF cm_tipo = "END POPUP"
					END POPUP
				Endif
			next
			END MENU
			DEFINE STATUSBAR
				STATUSITEM ""
				CLOCK WIDTH 85
				DATE
			END STATUSBAR
		Center Window WinMain
		Activate Window WinMain
	Else
		MsgStop(cFaltaMenu)
	Endif
* Ejemplo de definición de menú partiendo de una tabla
* (r) 2006, Roberto Sánchez
Function Salir()
  Release Window All
Function AcercaDe()
  MsgInfo(cAcercaDe)
Last edited by danielmaximiliano on Fri Nov 18, 2011 10:09 pm, edited 1 time in total.
gvaronas
Post by gvaronas »
Parece que el nombre de la función esta mal, dice MGSINFO y supongo que debe ser MSGINFO
Salu2,
GVS
Hola de nuevo, sinceramente no modifique el comentario de Gvaronas en el codigo, solo modifique la tabla demo.dbf agregando 'Nil' al campo Action, modifique 'Local xxxxx' por 'Public xxxxx' y el codigo funciona bien
pero miren estas imagenes y veran algo raro.
Propiedades de
Propiedades de
Propiedades IDE_2011-11-18_19-06-15.png (30.11 KiB) Viewed 27980 times
pero el Acerca de
Acerca de ?????
Acerca de ?????
Comentarios ?????
Descargas aqui
MenuDBF.rar
Artchivos
(15.15 KiB) Downloaded 931 times
Sin embargo
*msginfo(GetCurrentFolder())
	Else
		MsgStop(cFaltaMenu)
	Endif
error
error
Menu DBF en tiempo de ejecución_2011-11-18_19-42-59.png (54.67 KiB) Viewed 27979 times
Ok si
	Else
		MsgStop(cFaltaMenu)
	Endif
Compilacion OK
Compilacion OK
Menu DBF en tiempo de ejecución_2011-11-18_19-49-19.png (48.16 KiB) Viewed 27979 times
algo raro, no ?
ClaudioGalera
Gracias Daniel Maximiliano por responder y adaptarlo :)
Como has visto este demo bajo HMG3 funciona perfectamente. De hecho, lo he implementado en mis sistemas desde hace mucho tiempo.
Ahora al compilarlo bajo HMG4, cambia un poco por el tema de la estructura With Object .... END, ya que el preprocesador cambia el "END POPUP" por "END" y ahi es donde se descontrola todo :(
IF ..............................................
  END POPUP
Endif
por...
With Object MENUPOPUP():New( "cm_name",, cm_caption )
  end
Endif
Nuevamente gracias
Claudio
