Tree within a Grid
Rossine
Tree within a Grid
Post by Rossine »
Hello,
In hmg.4, can use the object tree in a grid ?
Rossine.
mrduck
Re: Tree within a Grid
Post by mrduck »
Can you please explain what you want to do ?
Rossine wrote:Hello,
Rossine.
Rossine
Post by Rossine »
Hello Francesco,
Please, seek this link: http://www.codeproject.com/KB/grid/treegridctrl.aspx
In fivewin exist xbrowse + tree. See thiw image:
Rossine.
Ricci
Post by Ricci »
Rossine, you can do this with the QTreeWidget Class using more than one column: http://doc.qt.nokia.com/stable/qtreewidget.html
The best way may be by overloading the HMG4 tree class not by using the grid class.
Rossine
Post by Rossine »
Hi Ricci,
Many thank´s for this explanation.
It would be possible to have a class/command in hmg.4 to do this ?
Rossine.
Ricci
Post by Ricci »
If you find someone who will build this class ....
mrduck
Post by mrduck »
Rossine wrote: It would be possible to have a class/command in hmg.4 to do this ?
Why don't you try yourself ? Clone tree.prg and start adapting the code... Creating core code for HMG4 is way way easier than create code for Hmg3...
In 3 weeks Ricci moved from saying that he would not use HMG4 to contributing core code...
Rossine
Post by Rossine »
I've got some progress with the tree-multcolumn :D
1) Create multi columns
2) Sort Column
3) Icons in all columns
4) Tooltip for coluna
See this image:
Then try to adapt the class to accept one or more columns ;)
Many thank´s to all,
Rossine.
l3whmg
Post by l3whmg »
Hi Rossine.
I'm very happy to see your job and I wait for your code 8-)
Luigi from Italy
www.L3W.it
mrduck
Post by mrduck »
Rossine wrote:Hi All,
2) Sort Column
Really good !
Would you share the code so that we can add to hmg4 ?
