Virtual Grid bug?
Virtual Grid bug?
HI :
there is an error when compiling an application with Virtual Grid.
HMG reference say:
DEFINE GRID <ControlName>
VIRTUAL <lValue>
END GRID
Compile OK:
* HMG Virtual Grid Demo
* (c) 2003 Roberto Lopez
	public aElem := {}
	for i:= 1 to 1000
		aadd( aElem, {  i, .T., 1 })
	next
	DEFINE WINDOW Form_1 AT 0,0 ;
		WIDTH 650 HEIGHT 400;
		TITLE 'Hello World!' MAIN
		DEfine  GRID Grid_1
		Parent Form_1
		Row 10
		Col 10
		WIDTH 400
		HEIGHT 330
		HEADERS         {'Number'               ,'Boolean'              ,'Number'}
		WIDTHS          {100                    ,100                    , 100}
		Items aElem
		COLUMNCONTROLS {{'TEXTBOX','NUMERIC'  } ,{'CHECKBOX','Si','No' },{'COMBOBOX',{'Uno','Dos','Tres'}} }
		Value 1
		Virtual .F.
		Itemcount 1000
		End Grid
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
ok virtual_2011-10-25_19-37-47.png (56.33 KiB) Viewed 7095 times
Fail :
	public aElem := {}
	for i:= 1 to 1000
	next
		DEfine  GRID Grid_1
		Parent Form_1
		Row 10
		Col 10
		WIDTH 400
		HEIGHT 330
		Items aElem
		Value 1
		Virtual .T.
		Itemcount 1000
		End Grid
Fail virtual_2011-10-25_19-37-47.png (61.66 KiB) Viewed 7095 times
happens in HMG4?
JosK
Re: Virtual Grid bug?
Post by JosK »
i have made some changes to virtualgrid (first copyéd virtualgrid.prg to jkGrid.prg).
Notes:
with filecompare you can find the change.
* $Id: virtualgrid.prg 806 2011-11-22 12:14:57Z fperillo $
* HMG Source Code
* Copyright 2010 Carlos Bacco <carlosbacco at gmail.com>
* www - http://harbour-project.org
* Copyright 2002-2010 Roberto Lopez <mail.box.hmg@gmail.com>
* http://sites.google.com/site/hmgweb/
* This program is free software; you can redistribute it and/or modify it under
* the terms of the GNU General Public License as published by the Free Software
* Foundation; either version 2 of the License, or( at your option ) any later
* version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
* FOR A PARTICULAR PURPOSE. See the GNU General Public License FOR more details.
* You should have received a copy of the GNU General Public License along with
* this software; see the file COPYING. IF not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA( or
* visit the web site http://www.gnu.org/ ).
* As a special exception, you have permission FOR additional uses of the text
* contained in this release of HMG.
* The exception is that, IF you link the HMG library with other
* files to produce an executable, this does not by itself cause the resulting
* executable to be covered by the GNU General Public License.
* Your use of that executable is in no way restricted on account of linking the
* HMG library code into it.
#include "hbclass.ch"
#include "common.ch"
#include "hbqtgui.ch"
CLASS JKGRID FROM ABSTRACTGRID
* Internal Data
DATA cClass INIT "VIRTUALGRID"
DATA QAbstractItemModel INIT NIL
DATA nCellRowIndex INIT 0
DATA nCellColIndex INIT 0
DATA aStruct INIT {}
DATA QHeaderView INIT NIL
DATA oSize INIT NIL
DATA nCX INIT 0
DATA nCY INIT 0
DATA QAbstractItemDelegate INIT NIL
DATA QItemSelectionModel INIT NIL
DATA nCurrent INIT NIL
DATA nNew INIT NIL
DATA nDiff INIT NIL
DATA nMasterItemNo INIT NIL
DATA nMasterRecNo INIT NIL
DATA nItemCount INIT 0
DATA nRecordCount INIT 0
DATA oQHeaderView INIT NIL
DATA nValue INIT NIL
DATA xValue INIT NIL
DATA lCellNavigation INIT NIL
DATA nLockColumns INIT NIL
* Data Variables FOR in-place edit
DATA oCurrentWidget INIT NIL
DATA xOldValue INIT NIL
DATA lCellActive INIT .F.
DATA lCellChangeActive INIT .F.
DATA oCellQTObject INIT NIL
DATA nOldRow INIT 0
DATA lReturnValueOnEnter INIT .F.
DATA bOnInitCellEditor INIT NIL
* Properties
METHOD Value SETGET
METHOD CellNavigation SETGET
METHOD LockColumns SETGET
METHOD MultiSelect SETGET
METHOD ItemCount SETGET
METHOD ColumnControls SETGET
METHOD Cell SETGET
METHOD Item SETGET
METHOD Items SETGET
* Events
METHOD OnChange SETGET
* Methods
METHOD New
METHOD Create
METHOD OnSave
METHOD OnSelect
METHOD setItemPos
METHOD setRecordPos
METHOD AddColumn
METHOD DeleteColumn
METHOD DeleteItem
METHOD DeleteAllItems
METHOD AddItem
METHOD Refresh
* FOR inplace edit
METHOD DoKeyBoardEvents SETGET
METHOD DefineCellcontrol SETGET
METHOD DoCellKeyBoardEvents SETGET
METHOD CellDoubleClicked SETGET
METHOD CloseCell
ENDCLASS
* Properties
METHOD Value( xValue ) CLASS JKGRID
LOCAL aValue := {}
LOCAL oModelIndex, i, j, nCurrentArea
IF ! ::lCreated
::xValue := xValue
RETURN Self
DO CASE
CASE ::nMODE == ARRAY_MODE
IF Pcount() == 0
IF LEN( ::aItems ) == 0
IF ::lCellNavigation .OR. ::lMultiSelect
RETURN {}
RETURN 0
IF !::lMultiSelect // cellnavigation ON MultiSelect OFF
oModelIndex := ::QItemSelectionModel:currentIndex()
RETURN { oModelIndex:row() + 1, oModelIndex:column() + 1 }
ELSE // cellnavigation ON MultiSelect ON
* Not Implemeted QModelIndexList Therefore dirtyway
* * oModelIndexList := QModelIndexList( ::oQTObject:selectedIndexes() )
* * FOR i := 0 to oModelIndexList:Size() - 1
* * oModelIndex := QModelIndex( oModelIndexList:At( i ) )
* * nRow := oModelIndex:Row() + 1
* * nCol := oModelIndex:Column() + 1
* * aAdd( aValue,{nRow,nCol} )
* * NEXT i
FOR i := 1 TO LEN( ::aItems )
FOR j := 1 TO LEN ( ::aItems[ i ] )
oModelIndex := ::QAbstractItemModel:index( i - 1, j - 1, QModelIndex() )
IF ::QItemSelectionModel:isSelected( oModelIndex )
aadd( aValue, {i,j} )
NEXT j
NEXT i
RETURN aValue
IF !::lMultiSelect // cellnavigation OFF MultiSelect OFF
::setItemPos( ::nCy )
RETURN ::nMasterItemNo
ELSE // cellnavigation OFF MultiSelect ON
* QModelIndexList not yet implemented Hence dirty way
* * IF aScan( aValue,nRow ) == 0
* * aAdd( aValue,nRow )
* * ENDIF
* * NEXT i
IF aScan( aValue,i ) == 0
aAdd( aValue,i )
NEXT j
NEXT i
RETURN aValue
ELSEIF Pcount() == 1
IF !::lMultiSelect // CellNavigation ON MultiSelect OFF
oModelIndex := ::QAbstractItemModel:index( xValue[1] - 1, xValue[2] - 1, QModelIndex() )
::oQTObject:setCurrentIndex( oModelIndex )
ELSE // CellNavigation ON MultiSelect ON
::oQTObject:ClearSelection()
FOR i := 1 to len( xValue )
oModelIndex := ::QAbstractItemModel:index( xValue[i,1] - 1, xValue[i,2] - 1, QModelIndex() )
::QItemSelectionModel:select( oModelIndex, 0x0002 )
NEXT i
::oQTObject:setSelectionModel( ::QItemSelectionModel )
IF !::lMultiSelect // CellNavigation OFF MultiSelect OFF
::oQTObject:selectRow( xValue - 1 )
ELSE // CellNavigation OFF MultiSelect ON
FOR i := 1 TO len( xValue )
FOR j := 1 TO LEN( ::aItems[ xValue[ i ] ] )
oModelIndex := ::QAbstractItemModel:index( xValue - 1, j - 1, QModelIndex() )
NEXT j
NEXT i
CASE ::nMode == DATA_MODE
/* PLEASE BE CAREFUL: NEVER USE A MSGINFO HERE ! */
/* when msginfo exists, Qt redraws the screen and recno()/ordkeyno()/etc ARE WRONG */
IF Pcount() == 0
::setRecordPos( ::nCy )
RETURN ::nMasterRecNo
IF empty( &( ::cWorkArea )->( dbFilter() ) )
&( ::cWorkArea )->( dbGoTo( xValue ) )
::oQTObject:setCurrentIndex( ::QAbstractItemModel:index( &( ::cWorkArea )->( OrdKeyNo() ) - 1 , ::nCX , QModelIndex() ) )
nCurrentArea := Select()
dbselectarea( ::cWorkArea )
dbGoTop()
DO WHILE .not. eof()
IF recno() == xValue
::oQTObject:setCurrentIndex( ::QAbstractItemModel:index( i - 1 , ::nCX , QModelIndex() ) )
EXIT
i++
skip
ENDDO
dbselectarea( nCurrentArea )
ENDCASE
::xValue := xValue
RETURN Self
* Events
* Methods
New
METHOD New( cName, oParent ) CLASS JKGRID
::aItems := {}
::aColumnHeaders := {}
Super:New( cName, oParent )
IF hb_IsObject( ::oParent )
::oQtObject := QTableView( ::oParent:QtParent ) //QTableView( ::oParent:QtObject )
::oQtObject := QTableView()
::oQtFont := ::oQtObject:font()
::oQtObject:setFocusPolicy( Qt_StrongFocus )
// ::oQtObject:setAutoFillBackground( .T. )
// default cell navigation and multiselect .F.
::CellNavigation := .F.
::MultiSelect := .F.
::showHeaders := .F.
::showColHeader( .T. )
RETURN Self
METHOD Create() CLASS JKGRID
LOCAL i
::oSize := QSize( 24,24 )
::lCreated := .T.
DO CASE
IF empty( ::aColumnFields ) .and. ;
empty( ::aColumnHeaders ) .and. ;
empty( ::aColumnWidths ) .and. ;
hb_IsChar( ::cWorkArea )
::aStruct := &( ::cWorkArea )->( DBStruct() )
::aColumnFields := {}
FOR i := 1 to len( ::aStruct )
aadd( ::aColumnFields , ::aStruct[i,1] )
aadd( ::aColumnHeaders, ::aStruct[i,1] )
NEXT i
::aStruct := {}
FOR i := 1 to len( ::aColumnFields )
aadd( ::aStruct , { ::aColumnFields , Type( ::aColumnFields ) , fieldlen( FieldPos( ::aColumnFields ) ), FieldDec( FieldPos( ::aColumnFields ) ) } )
NEXT i
CASE ::nMode == ARRAY_MODE
::aStruct := {}
FOR i := 1 to len( ::aColumnHeaders )
IF hb_IsArray( ::aColumnControls )
DO CASE
CASE upper( ::aColumnControls [i, 1] ) == 'TEXTBOX'
DO CASE
CASE upper( ::aColumnControls [i, 2] ) == 'CHARACTER'
aadd( ::aStruct , { ::aColumnHeaders , 'C' , 0 , 0 } )
CASE upper( ::aColumnControls [i, 2] ) == 'NUMERIC'
aadd( ::aStruct , { ::aColumnHeaders , 'N' , 0 , 0 } )
CASE upper( ::aColumnControls [i, 2] ) == 'DATE'
aadd( ::aStruct , { ::aColumnHeaders , 'D' , 0 , 0 } )
ENDCASE
CASE upper( ::aColumnControls [i, 1] ) == 'COMBOBOX'
CASE upper( ::aColumnControls [i, 1] ) == 'DATEPICKER'
CASE upper( ::aColumnControls [i, 1] ) == 'SPINNER'
aadd( ::aStruct , { ::aColumnHeaders [i] , 'N' , 0 , 0 } )
CASE upper( ::aColumnControls [i, 1] ) == 'CHECKBOX'
aadd( ::aStruct , { ::aColumnHeaders [i] , 'L' , 0 , 0 } )
ENDCASE
IF LEN( ::aItems ) > 0
aadd( ::aStruct , { ::aColumnHeaders [i] , VALTYPE(::aItems[1,i]) , 0 , 0 } )
aadd( ::aStruct , { ::aColumnHeaders [i] , 'C' , 0 , 0 } )
NEXT i
ENDCASE
::QAbstractItemModel := HBQAbstractItemModel( {| t, r, x, y| ::OnQueryData( ::aStruct , t, r, x, y ) } )
::oQTObject:setModel( ::QAbstractItemModel )
::QItemSelectionModel := ::oQTObject:selectionModel()
::QItemSelectionModel:connect( "currentChanged(QModelIndex,QModelIndex)", {| n | ::OnSelect( n ) } )
::oQTObject:verticalHeader():setDefaultSectionSize( 24 )
::QAbstractItemDelegate := ::oQTObject:itemDelegate()
::QAbstractItemDelegate:connect( "commitData(QWidget*)", {| w | ::OnSave( w ) } )
::oQTObject:connect( "doubleClicked(QModelIndex)", {| n | ::CellDoubleClicked( n )} )
::oQTObject:connect( QEvent_KeyPress , {|e|::DoKeyBoardEvents( e )} )
::oQHeaderView := QHeaderView( ::oQTObject:horizontalHeader() )
IF hb_IsArray( ::bOnHeadClick )
::oQHeaderView:disconnect( "sectionClicked(int)" )
::oQHeaderView:connect( "sectionClicked(int)",{|i| if( hb_IsBlock( ::bOnHeadClick[i+1] ), Eval( ::bOnHeadClick[i+1] ),nil ) } )
::Refresh()
FOR i := 1 To Len( ::aStruct )
IF valtype( ::aColumnWidths ) = 'U'
::oQtObject:setColumnWidth( i - 1, ::aStruct[ i, 3 ] * 6 + 60 )
::oQtObject:setColumnWidth( i - 1, ::aColumnWidths [i] )
IF ::nMode == DATA_MODE
::nCurrent := 1
&( ::cWorkArea )->( dbGoTop() )
::nMasterRecNo := &( ::cWorkArea )->( recno() )
IF VALTYPE( ::xValue ) != 'U'
::Value := ::xValue
IF LEN( ::aColumnControls ) > 0
::oQTObject:setEditTriggers( 0 )
IF ::lAllowEdit
msgQuit( "Can't edit cells without setting their type.<br><br>Editing disabled", "Unsupported" )
IF ::Visible()
::oQtObject:show()
RETURN Self
METHOD OnSave( pWidget ) CLASS JKGRID
LOCAL cData
LOCAL nCurrentArea, mVar
LOCAL aStru := ::aStruct
LOCAL nCX := ::nCX
LOCAL nCY := ::nCY
cData := pWidget:text()
DO CASE
::setRecordPos( nCY )
IF hb_IsArray( ::aColumnValid )
IF hb_IsBlock( ::aColumnValid [nCX + 1] )
mVar := 'MemVar' + ::cWorkArea + aStru [ nCX+1 ] [ 1 ]
DO CASE
CASE type( aStru [ nCX+1 ] [ 1 ] ) == 'C'
&mVar := cData
CASE type( aStru [ nCX+1 ] [ 1 ] ) == 'N'
&mVar := val( cData )
CASE type( aStru [ nCX+1 ] [ 1 ] ) == 'L'
&mVar := if( upper( alltrim( cData ) ) == 'Y' , .T. , .F. )
CASE type( aStru [ nCX+1 ] [ 1 ] ) == 'D'
&mVar := ctod( cData )
ENDCASE
IF ! eval( ::aColumnValid [nCX + 1] )
IF hb_IsArray( ::aValidMessages )
IF hb_IsChar( ::aValidMessages [ nCX + 1 ] )
MsgStop( ::aValidMessages [ nCX + 1 ] )
MsgStop( 'Invalid Input!' )
SWITCH aStru[ nCX + 1, 2 ]
CASE "C"
replace &( aStru [ nCX+1 ] [ 1 ] ) with AllTrim( cData )
EXIT
CASE "N"
replace &( aStru [ nCX+1 ] [ 1 ] ) with Val( cData )
EXIT
CASE "L"
replace &( aStru [ nCX+1 ] [ 1 ] ) with Left( cData, 1 ) $ "YyTt"
EXIT
CASE "D"
replace &( aStru [ nCX+1 ] [ 1 ] ) with CToD( cData )
EXIT
ENDSWITCH
::setItemPos( nCY )
DO CASE
CASE aStru [ nCX+1 ] [ 2 ] == 'C'
::aItems [ nCY+1 ] [ nCX + 1 ] := cData
CASE aStru [ nCX+1 ] [ 2 ] == 'N'
::aItems [ nCY+1 ] [ nCX + 1 ] := val( cData )
CASE aStru [ nCX+1 ] [ 2 ] == 'L'
::aItems [ nCY+1 ] [ nCX + 1 ] := if( upper( alltrim( cData ) ) == 'Y' .OR. upper( alltrim( cData ) ) == 'T' , .T. , .F. )
CASE aStru [ nCX+1 ] [ 2 ] == 'D'
::aItems [ nCY+1 ] [ nCX + 1 ] := ctod( cData )
ENDCASE
ENDCASE
METHOD onSelect( qModelIndex ) CLASS JKGRID
LOCAL xValue, oModelIndex, nNewRow, nNewCol
::nCX := qModelIndex:column()
::nCY := qModelIndex:row()
IF ::lCellActive .and. .not. ::lCellChangeActive
nNewRow := ::nCY + 1
nNewCol := ::nCX + 1
IF nNewRow == ::nCellRow .and. nNewCol == ::nCellCol
* Nothing Doing
xValue := ::oCurrentWidget:Value
IF hb_IsBlock( ::aColumnValid[ ::nCellCol ] )
* Restore the cell cursor to old place until columnvalid is ok
::lCellChangeActive := .T.
oModelIndex := ::QAbstractItemModel:index( ::nCellRow - 1, ::nCellCol - 1, QModelIndex() )
IF !Eval( ::aColumnValid[ ::nCellCol ] )
::oCellQTObject:setFocus()
::lCellChangeActive := .F.
::CloseCell( xValue )
::oQTObject:reset()
* ::QAbstractItemModel:reset()
oModelIndex := ::QAbstractItemModel:index( nNewRow - 1, nNewCol - 1, QModelIndex() )
::oQTObject:setFocus()
IF ValType( ::bOnChange ) != 'U' .AND. .NOT. ::lCellChangeActive .AND. ::lCreated
nNewRow := ::nCY
IF !::lCellNavigation // QT gives signal FOR change in columns even in a full row selection mode
IF nNewRow != ::nOldRow
Eval( ::bOnChange )
::nOldRow := nNewRow
Eval( ::bOnChange )
RETURN Self
METHOD setItemPos( nValue ) CLASS JKGRID
IF PCOUNT() == 1 .AND. hb_IsNumeric( nValue )
::nCurrent := nValue + 1
::nMasterItemNo := nValue + 1
RETURN Self
METHOD setRecordPos( nValue ) CLASS JKGRID
&( ::cWorkArea )->( dbGoTo( ::nMasterRecNo ) )
if( nValue + 1 ) == 1
ELSEIF( nValue + 1 ) > ::nRecordCount - 100 // Why 100 ??? Ricci
&( ::cWorkArea )->( dbGoBottom() )
&( ::cWorkArea )->( dbskip( ( nValue + 1 ) - ::nRecordCount ) )
::nNew := nValue + 1
::nDiff := ::nNew - ::nCurrent
IF ::ndiff <> 0
&( ::cWorkArea )->( dbSkip( ::nDiff ) )
::nCurrent := ::nNew
RETURN Self
METHOD CellNavigation( lValue ) CLASS JKGRID
IF Pcount() == 0
RETURN ::lCellNavigation
ELSEIF PCOUNT() == 1 .AND. hb_IsLogical( lValue )
::lCellNavigation := lValue
::oQTObject:setSelectionBehavior( QAbstractItemView_SelectRows )
::oQTObject:setSelectionBehavior( QAbstractItemView_SelectItems )
METHOD LockColumns( nValue ) CLASS JKGRID
IF Pcount() == 0
RETURN ::nLockColumns
ELSEIF PCOUNT() == 1 .AND. hb_IsNumeric( nValue )
::nLockColumns := nValue
METHOD MultiSelect( lValue ) CLASS JKGRID
IF Pcount() == 0
IF ::oQTObject:selectionmode() == 3
RETURN .t.
RETURN .f.
IF lValue
* Multiselect is not allowed in DATA_MODE
IF ::nMode == ARRAY_MODE
::oQTObject:setselectionmode( 3 )
* Not to allow edit while in multiselect mode
::lAllowEdit := .f.
::oQTObject:setSelectionMode( 1 )
::lMultiSelect := lValue
IF ::lCreated
::Refresh()
METHOD ItemCount() CLASS JKGRID
RETURN len( ::aItems )
METHOD ColumnControls( aValue ) CLASS JKGRID
IF Pcount() == 0
RETURN ::aColumnControls
ELSEIF PCOUNT() == 1 .AND. hb_IsArray( aValue )
::aColumnControls := aValue
METHOD Cell( nRow , nCol , xValue ) CLASS JKGRID
IF PCOUNT() == 2 .AND. hb_IsNumeric( nRow ) .AND. hb_IsNumeric( nCol )
RETURN ::aItems[ nRow, nCol ]
ELSEIF PCOUNT() == 3 .AND. hb_IsNumeric( nRow ) .AND. hb_IsNumeric( nCol )
::aItems[ nRow,nCol ] := xValue
IF ! ::lCellActive
::Refresh()
METHOD Item( nRow , xValue ) CLASS JKGRID
LOCAL i
* Item method is allowed only in array mode
IF .NOT. ::nMode == ARRAY_MODE
IF PCOUNT() == 1 .AND. hb_IsNumeric( nRow )
RETURN ::aItems[ nRow ]
ELSEIF PCOUNT() == 2 .AND. hb_IsNumeric( nRow )
FOR i := 1 TO LEN( ::aItems[ nRow ] )
IF LEN( xValue ) >= i
::aItems[ nRow,i ] := xValue[i]
::Refresh()
METHOD AddColumn( nColIndex , cCaption , nWidth , nJustify, cHeaderImage ) CLASS JKGRID
LOCAL i
* AddColumn method is allowed only in array mode
IF PCOUNT() >= 3 .AND. hb_IsNumeric( nColIndex ) .AND. hb_IsChar( cCaption ) .AND. hb_IsNumeric( nWidth )
aSize( ::aStruct, LEN( ::aStruct ) + 1 )
aIns( ::aStruct,nColIndex )
::aStruct[nColIndex] := { cCaption, 'C', 20, 0 }
aSize( ::aColumnHeaders,len( ::aColumnHeaders )+1 )
aIns( ::aColumnHeaders,nColIndex )
::aColumnHeaders[nColIndex] := cCaption
aSize( ::aColumnWidths,len( ::aColumnWidths )+1 )
aIns( ::aColumnWidths,nColIndex )
::aColumnWidths[nColIndex] := nWidth
aSize( ::aColumnJustify,len( ::aColumnJustify )+1 )
aIns( ::aColumnJustify,nColIndex )
::aColumnJustify[nColIndex] := nJustify
IF ValType( ::aHeaderImages ) != 'U'
aSize( ::aHeaderImages,len( ::aHeaderImages )+1 )
aIns( ::aHeaderImages,nColIndex )
aSize( ::aHeaderPixmaps,len( ::aHeaderPixmaps )+1 )
aIns( ::aHeaderPixmaps,nColIndex )
::aHeaderImages[nColIndex] := cHeaderImage
::aHeaderPixmaps[nColIndex] := QPixmap( ::aHeaderImages[nColIndex] )
IF valtype( ::aColumnHeaders ) = 'U' ;
.and. ;
aSize( ::aItems, 0)
::Refresh()
METHOD DeleteColumn( nCol ) CLASS JKGRID
LOCAL i
* DeleteColumn method is allowed only in array mode
IF PCOUNT() == 1 .and. hb_IsNumeric( nCol ) .and. nCol < len( ::aStruct )
aSize( ::aItems, 0)
::Refresh()
aDel( ::aStruct,nCol )
aSize( ::aStruct,len( ::aStruct )-1 )
aDel( ::aColumnHeaders,nCol )
aSize( ::aColumnHeaders,len( ::aColumnHeaders )-1 )
aDel( ::aColumnJustify,nCol )
aSize( ::aColumnJustify,len( ::aColumnJustify )-1 )
aDel( ::aColumnWidths,nCol )
aSize( ::aColumnWidths,len( ::aColumnWidths )-1 )
aDel( ::aHeaderImages,nCol )
aSize( ::aHeaderImages,len( ::aHeaderImages )-1 )
aDel( ::aHeaderPixmaps,nCol )
aSize( ::aHeaderPixmaps,len( ::aHeaderPixmaps )-1 )
.and. ;
::Refresh()
METHOD DeleteItem( nRow ) CLASS JKGRID
* DeleteItem method is allowed only in array mode
aDel( ::aItems, nRow)
aSize( ::aItems, LEN( ::aItems ) - 1 )
::Refresh()
METHOD DeleteAllItems() CLASS JKGRID
* DeleteAllItems method is allowed only in array mode
aSize( ::aItems, 0 )
::Refresh()
METHOD AddItem( aValue ) CLASS JKGRID
* AddItem method is allowed only in array mode
aadd( ::aItems, aValue )
::Refresh()
METHOD ITEMS( aValue ) CLASS JKGRID
* Items method is allowed only in array mode
msgquit( "virtualgrid:items() not in ARRAY_MODE" )
IF Pcount() == 0
RETURN ::aItems
::aItems := aClone( aValue )
::Refresh()
METHOD OnChange( bValue ) CLASS JKGRID
IF Pcount() == 0
RETURN ::bOnChange
ELSEIF PCOUNT() == 1 .AND. hb_IsBlock( bValue )
::bOnChange := bValue
METHOD CellDoubleClicked( qModelIndex ) CLASS JKGRID
LOCAL nNewRow,nNewCol
nNewRow := qModelIndex:row() + 1
nNewCol := qModelIndex:column() + 1
* If already cell edit is in process, don't process anything here
IF ::lCellActive
* process on dblclick event IF any
IF ValType( ::bOnDblClick ) != 'U'
Eval( ::bOnDblClick )
* FOR inplace edit
IF !::lAllowEdit .or. ::lMultiSelect
* Nothing doing
IF ValType( ::aColumnControls ) == 'U' // no inplace edit required.
::nCellRow := nNewRow
::nCellCol := nNewCol
IF hb_IsArray( ::aColumnWhen )
IF hb_IsBlock( ::aColumnWhen[ ::nCellCol ] )
IF !Eval( ::aColumnWhen[ ::nCellCol ] )
RETURN .T.
* Inplace edit area
::DefineCellControl()
METHOD DoKeyBoardEvents( e ) CLASS JKGRID
LOCAL oKeyEvent := e
LOCAL nKey := oKeyEvent:key()
LOCAL nModifiers := oKeyEvent:modifiers()
IF ::lCellActive //Already cell edit is in process, so don't process any key here
//functie-toetsen zou moeten mogen ?
RETURN .T.
* Nothing doing
RETURN .F.
RETURN .T.
::nCellRow := ::nCY + 1
::nCellCol := ::nCX + 1
IF hb_isBlock(::aColumnWhen[::nCellCol])
IF !Eval( ::aColumnWhen[::nCellCol] )
IF ::nCellCol == len( ::aColumnWhen )
RETURN .F.
::nCellCol++ // to navigate to NEXT cell IF columnwhen is not allowed
* Inplace edit area
If( nKey == Qt_Key_Return .and. nModifiers == Qt_NoModifier ) .or.( nKey == Qt_Key_Enter .and. nModifiers == Qt_KeypadModifier ) .or.( nKey == Qt_Key_F2 .and. nModifiers == Qt_NoModifier )
RETURN .F.
METHOD DefineCellControl CLASS JKGRID
LOCAL oModelIndex, nCurrentArea
* Preserve old value to restore IF escape key is pressed or editing cancelled.
DO CASE
::setRecordPos( ::nCellRow - 1 )
::xOldValue := &( ::cWorkArea )->( &( ::aStruct [ ::nCellCol ] [ 1 ] ) )
::xOldValue := ::Cell( ::nCellRow, ::nCellCol )
ENDCASE //er stond ENDCASEw
::s_lGridCellFlag := .t.
DO CASE
CASE upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'TEXTBOX'
::oCurrentWidget := TextBox():New()
* Finding the datatype and textbox type
DO CASE
CASE upper( alltrim( ::aColumnControls[::nCellCol][2] ) ) == 'NUMERIC'
::oCurrentWidget:DataType := TXT_NUMERIC
CASE upper( alltrim( ::aColumnControls[::nCellCol][2] ) ) == 'DATE'
::oCurrentWidget:DataType := TXT_DATE
OTHERWISE
::oCurrentWidget:DataType := TXT_CHARACTER
ENDCASE
IF !::oCurrentWidget:DataType == TXT_DATE
IF len( ::aColumnControls[::nCellCol] ) > 2
IF ValType( ::aColumnControls[::nCellCol] [3] ) != 'U'
IF Len( alltrim( ::aColumnControls[::nCellCol][3] ) ) > 0 // inputmask
::oCurrentWidget:InputMask := ::aColumnControls[::nCellCol][3]
IF ::oCurrentWidget:DataType == TXT_NUMERIC
IF len( ::aColumnControls[::nCellCol] ) > 3
IF ValType( ::aColumnControls[::nCellCol][4] ) != 'U'
IF Len( alltrim( ::aColumnControls[::nCellCol][4] ) ) > 0 // format
::oCurrentWidget:Format := ::aColumnControls[::nCellCol][4]
* Right align the cell if column justification is right
IF valtype( ::aColumnJustify ) <> 'U'
IF ::aColumnJustify[::nCellCol] == GRID_JTFY_RIGHT
::oCurrentWidget:Alignment := TXT_RIGHT
CASE upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'CHECKBOX'
::oCurrentWidget := CheckBox():New()
* set the initial value to edit ie., old value
::oCurrentWidget:Caption := if( ::xOldValue,::aColumnControls[::nCellCol][2],::aColumnControls[::nCellCol][3] )
::oCurrentWidget:OnChange := {|| If( ::oCurrentWidget:Value,::oCurrentWidget:Caption := ::aColumnControls[::nCellCol][2],::oCurrentWidget:Caption := ::aColumnControls[::nCellCol][3] )}
CASE upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'DATEPICKER'
::oCurrentWidget := DatePicker():New()
IF upper( alltrim( ::aColumnControls[::nCellCol][2] ) ) == 'UPDOWN'
::oCurrentWidget:UpDown := .t.
::oCurrentWidget:UpDown := .f.
CASE upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'SPINNER'
::oCurrentWidget := Spinner():New()
::oCurrentWidget:RangeMin := ::aColumnControls[::nCellCol][2]
::oCurrentWidget:RangeMax := ::aColumnControls[::nCellCol][3]
CASE upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'COMBOBOX'
* ComboBox creation & initialization started
::oCurrentWidget := ComboBox():New()
::oCurrentWidget:Items := ::aColumnControls[::nCellCol][2]
ENDCASE
::oCurrentWidget:Value := ::xOldValue
IF upper( alltrim( ::aColumnControls[::nCellCol][1] ) ) == 'TEXTBOX'
* To set the inputmask & format
::oCurrentWidget:Create()
// ::oCellQTObject:selectAll()
* store qt object and set the same to the cell of the grid
::s_lGridCellFlag := .f.
::oCellQTObject := ::oCurrentWidget:QTObject
::oCellQTObject:setAutoFillBackground( .t. )
* connect keypress event of the datepicker FOR processing enter and escape key
::oCellQTObject:connect( QEvent_KeyPress , {|e|::DoCellKeyBoardEvents( e )} )
::oQTObject:setIndexWidget( oModelIndex, ::oCellQTObject )
* cell is activated
::lCellActive := .T.
if ::bOnInitCellEditor != NIL
eval( ::bOnInitCellEditor, Self, ::oCurrentWidget, ::aColumnControls[::nCellCol][1] )
METHOD DoCellKeyBoardEvents( e ) Class JKGRID
//flags en enum QT::KeyboardModifiers : QT_NoModifier = geen shift, ctrl, alt, keypad en geen meta (meta is bijvb start mail)
LOCAL xValue
LOCAL oModelIndex, nRecNo , nArea
* dit was voor de help/f10 !?
* ook insert bInsToggle
if(jkBlock:=setkey(nkey) !=NIL)
eval(jkBlock, procname(1), procline(1),'')
//was loop maar hier return .f.
// de eval is uitgevoerd en we willen nieuwe nKey
return .f.
DO CASE
CASE nKey == Qt_Key_Escape //.and. nModifiers == Qt_NoModifier
::lCellActive := .F.
::oCellQTObject:close()
::oQTObject:reset()
CASE(nKey == Qt_Key_Up).or.;
(nKey == Qt_Key_Down).or.;
(nKey == Qt_Key_Right).or.;
(nKey == Qt_Key_Left).or.;
(nKey == Qt_Key_Home).or.;
(nKey == Qt_Key_PageDown).or.;
(nKey == Qt_Key_PageUp).or.;
return .f.
CASE (nKey == Qt_Key_Return .and. nModifiers == Qt_NoModifier ) .or. ( nKey == Qt_Key_Enter .and. nModifiers == Qt_KeypadModifier )
* na enter op veld krijg je de edit mode
RETURN .T.
* Move on to the next cell
IF ::nCellCol < LEN( ::aColumnControls )
::nCellCol++
DO CASE
IF ::nCellRow < LEN( ::aItems )
::nCellRow++
::nCellCol := 1
IF ( empty( &( ::cWorkArea )->( dbFilter() ) ) ) .and.( .Not. Set( _SET_DELETED ) )
::nRecordCount := &( ::cWorkArea )->( OrdKeyCount() )
nArea := Select()
nRecNo := recno()
dbSelectArea( ::cWorkArea )
COUNT TO ::nRecordCount
dbSelectArea( nArea )
dbgoto( nRecNo )
//jk IF ::nCellRow < LEN( ::nRecordCount )
IF ::nCellRow < ::nRecordCount
::nCellRow++
::nCellCol := 1
//msg add line ?
ENDCASE
::oQTObject:reset()
::oQTObject:setCurrentIndex( oModelIndex ) //jk: kreeg ERROR na RETURN input laatste veld; RETURN en NoModifiers (numlock stond aan maar valt niet onder NoModi
RETURN ::lReturnValueOnEnter
CASE nModifiers == Qt_NoModifier .or. nModifiers == Qt_KeypadModifier
* geen alt/shift/meta dit gaan we nog wel wijzigen
ENDCASE
RETURN .F.
METHOD Refresh() CLASS JKGRID
IF ::lCreated .and. ! ::lCellActive
METHOD CloseCell( xValue ) CLASS JKGRID
LOCAL nCurrentArea
DO CASE
::Cell( ::nCellRow,::nCellCol,xValue )
replace &( ::aStruct [ ::nCellCol ] [ 1 ] ) with xValue
ENDCASE
* To remove the widget from QTableView
JosK
Post by JosK »
also some changes to abstractgrid ..
Most imported reasen: when was evalued everty time. Also when the table was not yet stable.
This is my version:
* $Id$
* HMG Source Code
* version.
CLASS ABSTRACTGRID FROM CONTROL
* Internal Data
DATA cClass INIT "ABSTRACTGRID"
DATA nMode INIT ARRAY_MODE
DATA cWorkArea INIT NIL
DATA aColumnFields INIT NIL
DATA aItems INIT NIL
DATA aColumnHeaders INIT NIL
DATA aColumnWidths INIT NIL
DATA aColumnJustify INIT NIL
DATA aDynamicBackColor INIT NIL
DATA aDynamicForeColor INIT NIL
DATA aDynamicDisplay INIT NIL
DATA bOnHeadClick INIT NIL
DATA bOnDblClick INIT NIL
DATA aHeaderImages INIT NIL
DATA aHeaderPixMaps INIT NIL
DATA lAllowEdit INIT .F.
DATA lLines INIT .T.
DATA lVScrollBar INIT .T.
DATA aColumnWhen INIT NIL
DATA aColumnValid INIT NIL
DATA aValidMessages INIT NIL
DATA lShowColHeader INIT NIL
DATA lShowHeaders INIT NIL
DATA lShowRowHeader INIT NIL
DATA aColumnControls INIT NIL
DATA nCellRow INIT 0
DATA nCellCol INIT 0
* Properties
METHOD WorkArea SETGET
METHOD ColumnFields SETGET
METHOD ColumnHeaders SETGET
METHOD ColumnWidths SETGET
METHOD ColumnJustify SETGET
METHOD DynamicBackColor SETGET
METHOD DynamicForeColor SETGET
METHOD DynamicDisplay SETGET
METHOD Header SETGET
METHOD HeaderImages SETGET
METHOD AllowEdit SETGET
METHOD Lines SETGET
METHOD VSCrollBar SETGET
METHOD ColumnWhen SETGET
METHOD ColumnValid SETGET
METHOD ValidMessages SETGET
METHOD CellRowIndex SETGET
METHOD CellColIndex SETGET
METHOD ShowColHeader SETGET
METHOD ShowHeaders SETGET
METHOD ShowRowHeader SETGET
* Events
METHOD OnDblClick SETGET
METHOD OnHeadClick SETGET
* Methods
METHOD CreateLocal
METHOD OnQueryData
METHOD StandardItemDisplay
METHOD StandardFieldDisplay
ENDCLASS
* Properties
METHOD ColumnWhen( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aColumnWhen
ELSEIF Pcount() == 1 .AND. hb_Isarray( aValue )
::aColumnWhen := aValue
RETURN Self
METHOD ValidMessages( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aValidMessages
::aValidMessages := aValue
RETURN Self
METHOD ColumnValid( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aColumnValid
::aColumnValid := aValue
RETURN Self
METHOD ColumnJustify( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aColumnJustify
::aColumnJustify := aValue
RETURN Self
METHOD AllowEdit( lValue ) CLASS ABSTRACTGRID
//FP nella Browse non e' implementato
IF Pcount() == 0
RETURN ::lAllowEdit
ELSEIF Pcount() == 1 .AND. hb_IsLogical( lValue )
::lAllowEdit := lValue
RETURN Self
// FP e' per il This.
METHOD CellRowIndex( nValue ) CLASS ABSTRACTGRID
IF Pcount() == 1 .AND. hb_IsNumeric( nValue )
::nCellRowIndex := nValue
RETURN ::nCellRowIndex
METHOD CellColIndex( nValue ) CLASS ABSTRACTGRID
::nCellColIndex := nValue
RETURN ::nCellColIndex
METHOD WorkArea( cValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::cWorkArea
ELSEIF Pcount() == 1 .AND. hb_IsChar( cValue )
::cWorkArea := cValue
::nMode := DATA_MODE
METHOD ColumnFields( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aColumnFields
::aColumnFields := aValue
METHOD Lines( lValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::lLines
::lLines := lValue
::oQTObject:setShowGrid( ::lLines )
RETURN Self
METHOD VSCrollBar( lValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::lVScrollBar
::lVScrollBar := lValue
IF ::lVScrollBar
::oQTObject:setVerticalScrollBarPolicy( 2 )
::oQTObject:setVerticalScrollBarPolicy( 1 )
RETURN Self
METHOD Header( nCol , cValue ) CLASS ABSTRACTGRID
IF Pcount() == 1 .AND. hb_IsNumeric( nCol )
RETURN ::aColumnHeaders[nCol]
ELSEIF Pcount() == 2 .AND. hb_IsChar( cValue )
::aColumnHeaders[nCol] := cValue
::Refresh() // FP: only if lCreated = T ?
METHOD HeaderImages( aValue ) CLASS ABSTRACTGRID
LOCAL i
IF Pcount() == 0
RETURN ::aHeaderImages
::aHeaderImages := aValue
::aHeaderPixmaps := array( len( ::aHeaderImages ) )
FOR i := 1 to len( ::aHeaderImages )
::aHeaderPixmaps := QPixmap( ::aHeaderImages )
NEXT i
RETURN Self
METHOD DynamicBackColor( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aDynamicBackColor
::aDynamicBackColor := aValue
RETURN Self
METHOD DynamicForeColor( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aDynamicForeColor
::aDynamicForeColor := aValue
RETURN Self
METHOD DynamicDisplay( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aDynamicDisplay
::aDynamicDisplay := aValue
RETURN Self
METHOD ColumnWidths( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::aColumnWidths
::aColumnWidths := aValue
METHOD ColumnHeaders( aValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
::aColumnHeaders := aValue
METHOD ShowColHeader( lValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::lShowColHeader
IF lValue
::oQTObject:horizontalHeader():Show()
::oQTObject:horizontalHeader():Hide()
::lShowColHeader := lValue
METHOD ShowHeaders( lValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::lShowHeaders
IF lValue
::oQTObject:verticalHeader():Show()
::oQTObject:verticalHeader():hide()
::oQTObject:horizontalHeader():hide()
::lShowHeaders := lValue
METHOD ShowRowHeader( lValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::lShowRowHeader
IF lValue
::oQTObject:verticalHeader():Hide()
::lShowRowHeader := lValue
* Events
METHOD OnDblClick( bValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::bOnDblClick
ELSEIF Pcount() == 1 .AND. hb_IsBlock( bValue )
::bOnDblClick := bValue
METHOD OnHeadClick( bValue ) CLASS ABSTRACTGRID
IF Pcount() == 0
RETURN ::bOnHeadClick
::bOnHeadClick := bValue
RETURN Self
* Methods
METHOD CreateLocal() CLASS ABSTRACTGRID
LOCAL i
::lCreated := .T.
DO CASE
IF valtype( ::aColumnFields ) == 'U' ;
.and. ;
valtype( ::aColumnHeaders ) == 'U' ;
.and. ;
valtype( ::aColumnWidths ) == 'U' ;
.and. ;
::aStruct := {}
aadd( ::aStruct , { ::aColumnFields , Type( ::aColumnFields ) , 0 , 0 } )
NEXT i
::aStruct := {}
DO CASE
DO CASE
ENDCASE
ENDCASE
NEXT i
ENDCASE
::Refresh()
::oQTObject:connect( QEvent_KeyPress , {|e|Self:DoKeyBoardEvents( e )} ) //deze staatin grid, virtualgrid en virtualwindow=dochter
::Refresh()
// ::oParent:ChildAdd( ::cName , Self )
IF ValType( ::lVisible ) != 'U'; Self:Visible := ::lVisible ; ELSE ; ::oQTObject:show() ; ENDIF
::nCurrent := 1
::Value := ::xValue
RETURN Self
METHOD OnQueryData( aStru, t, role, x, y ) CLASS ABSTRACTGRID
LOCAL aRetVal , aColor, nRetVal, nRecNo , nArea
// msginfo("onquerydata")
SWITCH t
CASE HBQT_QAIM_flags
IF ::lAllowEdit
nRetVal := Qt_ItemIsEnabled + Qt_ItemIsSelectable
IF hb_IsBlock( ::aColumnWhen [x+1] )
DO CASE
::setRecordPos( y )
::setItemPos( y )
ENDCASE
//DEZE EVAL DOEN WE ALLEEN BIJ INVOEREN EN NIET BIJ OPBOUWEN SCHERM
//IF eval( ::aColumnWhen [x+1] )
nRetVal += Qt_ItemIsEditable
//ENDIF
RETURN nRetVal
RETURN Qt_ItemIsEnabled + Qt_ItemIsSelectable
CASE HBQT_QAIM_data
// msginfo( "QAIM_DATA" )
SWITCH role
CASE Qt_DisplayRole
DO CASE
::setRecordPos( y )
::setItemPos( y )
ENDCASE
IF valtype( ::aDynamicDisplay ) = 'U'
DO CASE
RETURN ::StandardFieldDisplay( aStru, x )
RETURN ::StandardItemDisplay( aStru, x, y )
ENDCASE
IF hb_IsBlock( ::aDynamicDisplay [ x+1 ] )
RETURN Eval( ::aDynamicDisplay [ x+1 ] )
DO CASE
ENDCASE
CASE Qt_EditRole /* Here we can specify different formats FOR editing*/
DO CASE
::setRecordPos( y )
SWITCH aStru[ x + 1, 2 ]
CASE "C"
RETURN AllTrim( &( ::cWorkArea )->( &( aStru [ x+1 ] [ 1 ] ) ) )
CASE "N"
RETURN hb_NToS( &( ::cWorkArea )->( &( aStru [ x+1 ] [ 1 ] ) ) )
CASE "L"
RETURN IIf( &( ::cWorkArea )->( &( aStru [ x+1 ] [ 1 ] ) ), "Y", "N" )
CASE "D"
RETURN DToC( &( ::cWorkArea )->( &( aStru [ x+1 ] [ 1 ] ) ) )
ENDSWITCH
RETURN "?"
::setItemPos( y )
CASE "C"
RETURN AllTrim( ::aItems [ y+1 ] [ x+1 ] )
CASE "N"
RETURN hb_NToS( ::aItems [ y+1 ] [ x+1 ] )
CASE "L"
RETURN IIf( ::aItems [ y+1 ] [ x+1 ] , "Y", "N" )
CASE "D"
RETURN DToC( ::aItems [ y+1 ] [ x+1 ] )
ENDSWITCH
RETURN "?"
ENDCASE
CASE Qt_ForegroundRole
IF hb_IsArray( ::aDynamicForeColor )
DO CASE
::setRecordPos( y )
::setItemPos( y )
ENDCASE
::nCellRowIndex := y + 1
::nCellColIndex := x + 1
aColor := eval( ::aDynamicForeColor [ x + 1 ], y + 1 )
aRetVal := qColor( aColor [1] , aColor [2] , aColor [3] )
aRetVal := NIL
RETURN aRetVal
CASE Qt_BackgroundRole
IF hb_IsArray( ::aDynamicBackColor )
DO CASE
::setRecordPos( y )
::setItemPos( y )
ENDCASE
aColor := eval( ::aDynamicBackColor [ x + 1 ], y + 1 )
aRetVal := NIL
RETURN aRetVal
CASE Qt_TextAlignmentRole
IF valtype( ::aColumnJustify ) = 'U'
CASE "C"
RETURN Qt_AlignVCenter + Qt_AlignLeft
CASE "N"
RETURN Qt_AlignVCenter + Qt_AlignRight
ENDSWITCH
RETURN Qt_AlignCenter
RETURN Qt_AlignVCenter + ::aColumnJustify [ x+1 ]
ENDSWITCH
CASE HBQT_QAIM_headerData
SWITCH role
CASE Qt_DisplayRole
IF x == Qt_Horizontal
IF hb_IsArray( ::aColumnHeaders )
RETURN ::aColumnHeaders[ y + 1 ]
RETURN aStru[ y + 1, 1 ]
IF ::nCy == y
RETURN '>'
RETURN ''
CASE Qt_SizeHintRole
RETURN ::oSize
CASE Qt_DecorationRole
IF ValType( ::aHeaderPixmaps ) != 'U'
RETURN ::aHeaderPixmaps[y+1]
ENDSWITCH
CASE HBQT_QAIM_rowCount
DO CASE
nArea := Select()
nRecNo := recno()
dbgoto( nRecNo )
RETURN ::nRecordCount
IF hb_IsArray( ::aItems )
::nItemCount := LEN( ::aItems )
::nItemCount := 0
RETURN ::nItemCount
ENDCASE
CASE HBQT_QAIM_columnCount
DO CASE
RETURN &( ::cWorkArea )->( Len( aStru ) )
RETURN Len( aStru )
ENDCASE
ENDSWITCH
METHOD StandardItemDisplay( aStru , x, y ) CLASS ABSTRACTGRID
LOCAL cText, nCol, xValue
nCol := x + 1
xValue := ::aItems[ y + 1, x + 1 ]
// msginfo("stabd: " +str(y)+" "+str(x) )
IF valtype( ::aColumnControls ) != 'U'
DO CASE
CASE upper( alltrim( ::aColumnControls[nCol][1] ) ) == 'TEXTBOX'
DO CASE
CASE upper( alltrim( ::aColumnControls[nCol][2] ) ) == 'NUMERIC'
IF len( ::aColumnControls[nCol] ) > 2 // with inputmask|format
IF ValType( ::aColumnControls[nCol] [3] ) != 'U'
IF len( ::aColumnControls[nCol] [3] ) > 0
cText := Transform( xValue ,( ::aColumnControls[nCol] [3] ) )
cText := Alltrim( Str( Int( xValue ) ) )
CASE upper( alltrim( ::aColumnControls[nCol][2] ) ) == 'DATE'
cText := rtrim( dtoc( xValue ) )
OTHERWISE
cText := xValue
ENDCASE
CASE upper( alltrim( ::aColumnControls[nCol][1] ) ) == 'CHECKBOX'
IF xValue
cText := ::aColumnControls[nCol][2]
cText := ::aColumnControls[nCol][3]
CASE upper( alltrim( ::aColumnControls[nCol][1] ) ) == 'DATEPICKER'
cText := DtoC( xValue )
CASE upper( alltrim( ::aColumnControls[nCol][1] ) ) == 'SPINNER'
cText := alltrim( Str( int( xValue ) ) )
CASE upper( alltrim( ::aColumnControls[nCol][1] ) ) == 'COMBOBOX'
cText := ::aColumnControls[nCol][2][xValue]
ENDCASE
RETURN cText
CASE "C"
CASE "N"
CASE "L"
RETURN IIf( ::aItems [ y+1 ] [ x+1 ] , "Yes", "No" )
CASE "D"
CASE "M"
RETURN '<memo>'
ENDSWITCH
RETURN "?"
METHOD StandardFieldDisplay( aStru , x ) CLASS ABSTRACTGRID
CASE "C"
CASE "N"
CASE "L"
RETURN IIf( &( ::cWorkArea )->( &( aStru [ x+1 ] [ 1 ] ) ), "Yes", "No" )
CASE "D"
CASE "M"
RETURN '<memo>'
ENDSWITCH
RETURN "?"
JosK
Post by JosK »
My example of jkgrid.prg with tab pages en also set key en the use of layoutbox:
#include "hbgtinfo.ch"
#include "std.ch"
SET DATE TO ANSI
SET EPOCH TO 1950 //KAN OOK CENTURY DOEN MAAR DAN 4 POSITIES..
SET CENTURY OFF
SET WRAP ON && ref 'menu to ...'
SET TALK OFF &&
SET BELL OFF &&
SET DELETED ON &&
SET SAFETY OFF &&
SET HEADING OFF &&
SET DELIMITERS OFF &&
SET SCOREBOARD OFF && geen Num, Ins, enz op lijn 0.
SET INTENSITY ON
SET DELIMITERS OFF
SET EXACT OFF
SET CURSOR OFF //KENT HMG NIET daar std.ch
SET DELETED ON && alleen btw bestand word direct gepackt ivm reccount()
SET EXCLUSIVE ON
setcancel(.f.)
FUNCTION Main()
Public oTLB //oTabpageLayoutBox
HbQt_ErrorSys()
wMain :=MaakMain("wMain")
oCW :=Widget():New("oCW",wMain)
oCW :CentralWidgetOF(wMain)
oLB :=LayoutBox():New("oLB",oCW,LAYOUT_TOPTOBOTTOM)
with object oTab:=Tab():New("oTab")
MaakTP1("oTP1",oTab)
MaakTP2("oTP2",oTab)
end
oLB:add(oTab)
oLB:SetLayout()
ON KEY F10 OF WMAIN ACTION {|| MSGSTOP("f10 binnen wmain")}
ON KEY F8 OF WMAIN ACTION {|| MSGSTOP(str(OTLB:direction()))}
//0=l->r, 1=r-l, 2=t-b, 3=b-t, 4=form, 5=grid
ON KEY F9 OF WMAIN ACTION {|| if( (x:=oTLB:Direction())==3,oTLB:Directon(0),oTLB:Direction(x+1))}
wMain:Activate()
Return NIL
STATIC FUNCTION MaakMain(c)
static o
if o==nil
o:= MAINWINDOW():New(c)
o:Title := "Maak Main Demo"
return o
STATIC FUNCTION MaakTab(c,oParent,nRow)
local o
o:=Tab():New(c,oParent)
return o
FUNCTION MaakTP1(c,oParent)
static o
if o=Nil
o:=TabPage():New(c,oParent)
o:caption:="&Tabpage1"
oTLB:=LayoutBox():New("oTLB",o)
oTLB:direction(0)
oB1:=Button():New()
oB1:caption("Button1")
oT1:=TextBox():New()
oB2:=Button():New()
oB3:=MaakBtn("oB3")
oTLB:add(oB1)
oTLB:insertstretch(1,10)
oTLB:add(oT1)
oTLB:insertstretch(2,10)
oTLB:add(oB2)
oTLB:insertstretch(3,10)
oTLB:add(oB3)
oTLB:setLayout()
return o
STATIC FUNCTION MaakBtn(c,oParent)
static o
o:=Button():New(c,oParent)
o:MaxWidth :=300
o:Caption := "Current Language"
o:OnClick := { || Bt1_OnClick() }
RETURN o
STATIC FUNCTION Bt1_OnClick()
MsgInfo( "Current Language is " + hb_ValToExp( HMGAPP():Language() ), "Language" )
FUNCTION MaakTP2(c,oParent)
static o
use c:\hmg.4\svn\samples\t\demo alias demo
go top
if o=Nil
o:caption:="&RekSchema"
oTLB:=LayoutBox():New("oTLB",o,LAYOUT_TOPTOBOTTOM)
oBrowse:=MaakBrowse("oBrowse")
oTLB:add(oBrowse)
oTLB:setlayout()
return o
function MaakBrowse(c)
static o
static bColor := { || IF ( ordkeyno()/2 == INT(ordkeyno()/2) , { 222,222,222 } , { 255,255,255 } ) }
static fColor := { || IF ( ordkeyno()/2 == INT(ordkeyno()/2) , { 255,0,0 } , { 0,0,255 } ) }
o:=jkGrid():New(c)
o:Row := 10
o:Col := 10
o:Width := 690
o:Height := 615
o:WorkArea := 'demo'
//o:OnChange :={||MsgInfo( "Andere cell/regel geselecteerd!" )}
//o:ONDBLClick :={||MsgInfo( "We gaan cell editten!" )}
* 'First','Last','Street','City','State','Zip','Hire Date','Married' ,'Age', Salary' , 'Notes'}
* '1,2,3,4,5,6Zip,7H,8'Married',9Age',10Salary' , 11Notes'}
//kreeg een error er daarom columnHeader toegevoegd
o:ColumnHeaders := { 'First' , 'Last' , 'Street' , 'City' , 'State' , 'Zip' , 'HireDate' , 'Married' , 'Age' , 'Salary' , 'Notes' }
o:ColumnFields := { 'First' , 'Last' , 'Street' , 'City' , 'State' , 'Zip' , 'HireDate' , 'Married' , 'Age' , 'Salary' , 'Notes' }
o:ColumnWidths := { 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 }
// ColumnJustify {GRID_JTFY_LEFT,GRID_JTFY_RIGHT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_RIGHT,GRID_JTFY_LEFT}
// brw_left etc is idem als grid_jtfy_left
o:ColumnJustify := { BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT }
o:DynamicBackColor := { bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor }
o:DynamicForeColor := { fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor }
o:DynamicDisplay := { { || UPPER(First) } , NIL , NIL , NIL , NIL , NIL , NIL , { || IF(married,'Married','Not Married' ) } , NIL , NIL , NIL }
o:OnHeadClick := { { || MsgInfo( 'Click 1' ) } , , { || MsgInfo( 'Click 3' ) } , { || MsgInfo( 'Click 4' ) } , { || MsgInfo( 'Click 5' ) } , { || MsgInfo( 'Click 6' ) } , { || MsgInfo( 'Click 7' ) } , { || MsgInfo( '8' ) } , ,}
o:HeaderImages := { 'new.png' , 'open.png' , 'paste.png' , 'save.png' , 'new.png' , 'open.png' , 'paste.png' , 'save.png' , 'new.png' , 'open.png' , 'paste.png' }
//1.1= textbox,checkbox
//1.2=nummeric,date,character
//1.3=imputmask
//1.4=format alleen bij nummeric
// justify via andere array
//1="checkbox", caption=2of3,onchange=2of3 hij checkt op wel/niet block!?
//1="datepicker",2="UPDOWN" else updown=f
//1="spinner",2=RangeMin, 3=RangeMax
//1="combobox",2=items=array
o:ColumnControls :={{'TEXTBOX','CHARACTER'},;
{'TEXTBOX','CHARACTER','@K'},;
{"SPINNER",1,1000},;
{"COMBOBOX",{"January","February","March","April","May","June","July","August","September","October","November","December"}},;
{'TEXTBOX','CHARACTER',"@K"},;
{"DATEPICKER","UpDown"},;
{'CHECKBOX','Yes','No'},;
{'TEXTBOX','NUMERIC','99'},;
{'TEXTBOX','NUMERIC','999.99'},;
{'TEXTBOX','CHARACTER'};
o:MultiSelect := .F. //bij true = geen edit , alleen display
o:AllowEdit := .T. //alleen indien columnControls is ingevuld
o:Lines := .F.
o:VScrollBar := .F.
o:ColumnWhen := { { || UPPER(LEFT(first,1) ) == 'A' } ,;
//msgstop wordt bij opbouwen scherm bij iedere regel getoond
//bij when en browse problem want werd bij iedere regel werd when uitgevoerd; ook bij opbouwen scherm
//er moet een block in staan want anders error na intoetsen key
//o:ColumnWhen := { { || UPPER(LEFT(first,1) ) == 'A' } , , , , , , , , , , }
//o:ColumnValid := { { || !EMPTY(memvar.demo.first) } , , , , , , , , , { || demo->salary > 100 } , }
o:ColumnValid := { { || !EMPTY(demo.first) } , , , , , , , , , { || demo->salary > 100 } , }
o:ValidMessages := { "First name can't be EMPTY" , , , , , , , , , "Salary mus be greater than 100" , }
x1:=len(o:ColumnControls())
x2:=len(o:ColumnValid())
x3:=len(o:ValidMessages())
if x1#x2.or.x1#x3
msgstop("x1="+str(x1) + " x2="+str(x2)+ " x3="+str(x3))
return o
JosK
Post by JosK »
F9 does'nt work grrrr ;-)
so change line 41
maakTP2(...
//maakTP2(..
After this change F9 works ... a little bit ;-)
There is still a bug ... Direction(0) is not stored!?
JosK
Post by JosK »
For the record ;-)
i'm working with hmg 4 2011.11.23
