I´m sure it´s quiet easy but I did´nt get it:
I like to open a child window from my main window (via a button) and close the child from the main window (via another button). The child should not have a sysmenu (:SysMenu isn´t working).
opening and closing a childwindow from main
Re: opening and closing a childwindow from main
Hi Ricci.
In this moment CHILD form it's not implemented: only MAIN, MODAL and STANDARD.
But I'm working on it.....and perhaps I found .....solution
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
OK, I will wait.
I´m working on a onmouseover event for controls: when the cursor is over a control, a popup window should appear and close when the cursor leaves the control. Everything is working except the popup (child) window.
Hi Ricci, very good and many thanks.
ASAP we will describe a possible evolution.
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Do you need a window or a tooltip is enough ? tooltip can include html text....Ricci wrote:OK, I will wait.
[quote="mrduck"Do you need a window or a tooltip is enough ? tooltip can include html text....[/quote]
I want to display a graphical diagram, so I need a window.
