Hi
Can anyone help?
I need to generate a TXT file
Previously in my Clipper DOS program I could SET Printer to filename
This does not seem to be available in HMG
Creating a text file
Re: Creating a text file
Español:
Hola,
El comando: Set Printer to <filename>
No esta disponible en la Librería HMG, pero si en Harbour
Ingles: (Google)
Hello,
The command: 'Set Printer to <filename>'
In the HMG library is unavailable. But if Harbour.
Slds.
Walter
Hola,
Ingles: (Google)
Hello,
Slds.
Walter
You can use
This works in HMG.
set alternate to 'x.txt'East or West HMG is the Best.
Set Alternate works
My thanks,
Never had the need to use this in Clipper
My thanks,
Este post creo que te vendrá muy bien.
This post will solve your doubts.
viewtopic.php?f=5&t=1192&p=8483&hilit=writefile#p8483
fread() / fwrite() ... etc are low-level functions and I'm always afraid LL approaches
For building a text file programmatically my favorite way is something like this :
Regarding "viewing a text file", IMHO best way is EDITBOX; something like this:
That's all
PS: Don't hesitate about 64 K limit, it left in DOS
Regards / Saludos
cText := ''
<beginning of (probably necessarily) a loop ( FOR / WHILE ... ) >
cLine := <somethings >
cText += cLine + CRLF
<end of loop>
HB_MEMOWRIT( <output file name>, cText )Code: Select all
<NameOfEditboxControl>.value := MEMOREAD( <inputTextFileName> )PS: Don't hesitate about 64 K limit, it left in DOS
Regards / Saludos
Addendum to Esgici,
It is better to have the font of the editbox to be 'Courier New' so that the spacing will be equal between characters. Hmm. Good old days!
Yes my friendrathinagiri wrote: It is better to have the font of the editbox to be 'Courier New' so that the spacing will be equal between characters. Hmm. Good old days!
Or FixedSYS
In addition make background color to black and live a little nostalgia
