printing to stdout
t57042
printing to stdout
Post by t57042 »
How can I print a string to stdout?
Richard
Re: printing to stdout
Hello Richard
First, welcome aboard; regards from Turkey :)
And then, AFAIK in the GUI environment we haven't a "stdout" :(
For anything to "out" (print), you have defined a "place"; usually a form (window).
If you are about console mode, everything is as usual: print commands are ? or ?? and print functions are QOUT() and QQOUT().
I hope this will be helpful for you.
Regards / Cordialement :D
t57042
Post by t57042 »
Thanks,
and how can I send a string to the clipboard??
Richard
t57042
Post by t57042 »
The only thing that seems to do the trick is : outstd().
It displays "press any key to continue" - can that be avoided??
Richard
t57042 wrote:Thanks,
Richard
system.clipboard := cString
t57042 wrote: The only thing that seems to do the trick is : outstd().
Richard
Did you tried ? or QOUT() instead of outstd() ?
t57042
Post by t57042 »
Yes, I did.
May be "press any key to continue" message come from system (OS, CMD of win); not your program.
t57042
Post by t57042 »
Probably, but isn't it possible to write to the console without that?
I guess no !
In general, my console prgs run in "terminate and close cmd window" fashion and I have add WAIT command in prg or PAUSE command in the .bat file that call my prg.
Could you send a simple example ?
