Browse Scroll
Mario Mansilla
Browse Scroll
Post by Mario Mansilla »
Hola :
En el control browse muestro el estado de la base a medida que agrego items . Necesito aprovechar toda la ventana del browse ya que el scroll solo muestra la mitad de la pantalla del browse . Este efecto en el ejemplo comienza a partir del ingreso del 6 item .
Es posible realizar esto ?
Saludos .
Mario Mansilla
Hi
In the Browser displays the state control of the base as you add items. I need to take full advantage of the browser window as the scroll only shows half the screen browse. This effect in the example starts from receipt of item 6.
It is possible to do this?
Greetings.
Mario Mansilla
Browse.rar
(664.44 KiB) Downloaded 387 times
Re: Browse Scroll
Mario Mansilla wrote: Hi
Greetings.
Mario Mansilla
Hi Mario,
Please be so kind to try the updated sample below:
   SET NAVIGATION EXTENDED
   SET CENTURY ON
   SET BROWSESYNC ON
   Load Window Main
   Main.Center
   Main.Activate
Static Procedure Abrir_Bases()
* Abro Bases
Use Datos Exclusive New
Go Top
Zap
Main.Browse_1.Value := Datos->(Recno())
Static Procedure Cerrar_Bases()
Close Datos
Static Procedure Agregar
Local Contador := Datos->(Recc()) + 1
Static nCode := 1
Datos->(Dbappend())
Replace Cantidad With nCode++
Replace Nombre With "Articulo " + Strzero(Contador,4)
Replace Unitario With 1.00
Replace Importe With 1.00
INSERT_CTRL_END()
Main.Browse_1.Refresh
Main.Browse_1.Value := Recno()
Main.Browse_1.Setfocus
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
HB_FUNC( INSERT_CTRL_END )
   keybd_event
      VK_CONTROL,         // virtual-key code
      0,                // hardware scan code
      0,                // flags specifying various function options
      0                 // additional data associated with keystroke
   keybd_event
      VK_END,           // virtual-key code
   keybd_event
      KEYEVENTF_KEYUP,  // flags specifying various function options
#pragma ENDDUMP
Hope that helps :idea:
Mario Mansilla
Re: Browse Scroll
Hi Grigory :
funciona perfecto , muchas gracias :D
works perfect, thank you very much
Saludos.
Mario Mansilla
Re: Browse Scroll
working fine!
Thanks for this lesson, Grigori :P
Re: Browse Scroll
mol wrote:working fine!
Hi Marek,
There is also the reduced version of this sample without using a C-level function.
   SET CENTURY ON
   SET BROWSESYNC ON
   Load Window Main
   Main.Center
   Main.Activate
Zap
Close Datos
Datos->(Dbappend())
Replace Cantidad With Contador
Replace Unitario With Contador
Replace Importe With Contador
_PushKey( VK_END )
