File Creation Date
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
File Creation Date
Post by karweru »
Hi everyone,
Anyone knows how to extract a file creation date? Kindly assist me.
Kind regards,
Gilbert.
tave2009
Re: File Creation Date
Post by tave2009 »
Hello Kaweru:
This exists in Harbour and is:
? FILEDATE("C:\TEXT\TEXT.TXT") // The date
Show the date of a particular file. :lol:
Hope this helps.
Walter
karweru
Post by karweru »
Thanks Walter. The function however seems to return the date the file was last changed, not created.
Kind regards,
Gilbert.
I think we have to use Win32 API function calls for this.
http://support.microsoft.com/kb/188977
This article (for FoxPro) may help.
karweru wrote:Thanks Walter. The function however seems to return the date the file was last changed, not created.
Have you tried the function FileStats() from harbour contrib library xHb :?:
PROCEDURE ShowStats( cFile )
   LOCAL cAttrib, nSize, dCDate, nCTime, dMDate, nMTime
   LOCAL cColor
   IF FileStats( cFile, @cAttrib, @nSize, @dCDate, @nCTime, @dMDate, @nMTime )
      @10,2 SAY "File name:  " + cFile
      @11,2 SAY "Attributes: '" + cAttrib + "'"
      @12,2 SAY "File size:  " + Alltrim( Str( nSize ) )
      @13,2 SAY "Created:    " + DtoC( dCDate ) + " " + TimeOfDay( nCTime )
      @14,2 SAY "Modified:   " + DtoC( dMDate ) + " " + TimeOfDay( nMTime )
      cColor = SetColor( "r+/b" )
      @10,2 SAY "NOT FOUND: " + cFile
      SetColor( cColor )
Hope that helps :idea:
Thanks Grigory. :)
karweru
Post by karweru »
Thank you so much Grigory.
Kind regards,
Gilbert.
"Ohh, quien podra salvarme"
Yoooo el chapulin colorado!!!
Grigory, gracias por el dato, siempre contamos con su ayuda.
Translata Google:
"Ohh, who can be saved"
I´the chapulin colorado!!!
Grigory, thanks for the tip, always have your help.
